Clueless NYT reporter manages to get stranded in Model S
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by lensovet, Feb 10, 2013.
  1. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    He had to slow down and turn down the cabin heat; AND drain the battery to reach Milford. Note that I (somewhat) specified parameters in my earlier post when I said the 'S' is not a 200 mile / charge car.
    I cannot help but imagine an advert spoof along these lines:
    • All EV
    • All the time !
    • Anywhere you want to go!
    • Some restrictions apply*
    *Average speed 25 mph for 6 hours a day of drivng and/or charging.
  2. Zythryn
    Zythryn Senior Member
    6,408
    4,407
    I find that statement very curious, as he successfully made that leg of the journey.
    The biggest criticism I have of the reporter is not the missed opportunities, it is his misinformation.
    For example, he wrote that he limped along at 45 mph, when logs show that was not true.
    He stated he set the cruise control at 54mph, a very specific number. But the logs show cruise control set between 60-65.
    Stating these things as hard fact (no adjectives like 'about', 'in the range of', etc) when they are not brings into question what other embellishments there were.
    JMD and lensovet like this.
  3. lensovet
    2,615
    496
    Burlington, NJ
    Also if he had set his heater to 65 and used the heated seats, he would have had plenty of range remaining by the time he got to Milford. I love he says that he "precipitously" changed the heater and was supposedly freezing…somehow 65 doesn't sound like freezing to me.
    It's also a mystery why Tesla graphed the climate control settings so poorly. The bottom of the y-axis should have been 0 degrees or maybe 32 degrees.
  4. SageBrush
    11,627
    2,533
    Southwest Colorado
    For the umpteenth time ...
    He made it by 1, draining the battery; 2, driving well below the speed limit; and 3, by turning down the cabin heat to a level he found uncomfortable.
    You know, a Prius can drive about 1400 miles on one tank of fuel. The thing is, you have to travel about 25 mph and not let the car cool down, so Toyota is not fool enough to use that range success as a marketing tool. Tesla apparently is willing to advertise ranges per charge that are not reliably acheived by pretty reasonable drivers.
  5. lensovet
    2,615
    496
    Burlington, NJ
    Can we define well? Is it 5, 10, 15 mph below the speed limit? Do you know what the speed limits on the highways where he drove are?
    You keep bringing up this 300 mile number. Have you actually seen it? Every time it's mentioned on the website, it says right next to it: driving at a constant speed of 55 mph.
    And the only number that's actually prominent is the EPA rated mileage of 265 miles, with the text "up to" next to it.
    But you're absolutely right about one thing: almost no gas car advertises its range.
  6. SageBrush
    11,627
    2,533
    Southwest Colorado
    I define well as a speed rarely driven by US drivers on highways unless congestion slows them down. Hell, even *I* drive faster than the speeds the reporter had to drop down to.
    You are confused -- I do not 'keep bringing up this 300 number.' I cannot even remember mentioning it once. I read yesterday that a driver managed 436 miles on a charge. So Tesla can change their advert now to "up to 436 Miles a charge!!" I'd say the marketing is ill advised though.
    Petrol cars do not mention range for a good reason: within the lower 48 states it is probably unlimited with the proviso of a couple minute fuel stops every 300-500 miles.
    I'm tired of arguing with you fan boys, so I'll just state the obvious one last time: The 85 khw Tesla 'S' is not a reliable 200 mile/charge car in the winter when driven at highway speed limits and cabin heat is used.
  7. lensovet
    2,615
    496
    Burlington, NJ
    Well given the results CNN obtained, your statement doesn't seem all that obvious. I guess it'd be nice to quantify what exactly qualifies as "winter" too.
    But this whole thread wasn't really ever about this. It was about how a reporter set out to write a story rather than report on the facts and how apparently, quite a few people see nothing wrong with that. I guess my unhappiness with the fact makes me a "fanboy".
    JMD likes this.
  8. SageBrush
    11,627
    2,533
    Southwest Colorado
    I repost the first couple sentences of the NYT article for your edification. Bolding is mine.
    This is the crux of the article, and the only point the reporter really cared to write about. It also just so happens to be true. This does not make the Tesla 'S' a bad car in any way (except for the price,) it just means the car has a limit that Tesla is being less than upfront in acknowledging.
  9. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    If that's the point of your argument, you are right. But you haven't fully defined your terms. On Tesla's website, you can play with the numbers. Highway driving at 65 mph, with ambient temperatures at 32 deg and the heat on, Tesla claims a maximum range of 218 miles on the 85 kwh Tesla S.
    Broder only charged to 90% SOC. Whether he knows how to use the car or not is irrelevant. The vehicle is not at full charge. The car can only go 196.2 miles by Tesla's claims. He also drives at speeds upwards of 81 mph. He then decides to take a couple hours detour through Manhattan. Granted it's only 2 miles out of the way but city driving is not highway driving and a gasoline car would have its fuel economy decimated by that detour. Ditto for the Tesla with the heat on. That he made it the Milford Supercharger is a feat of engineering.
    Now, I define a fully charged up car to show 100% SOC. I define highway speeds at 65 mph. I also would like some heat. The Tesla S delivers as evidenced by the CNN test drive. If you define a fully charged Tesla as Broder then the Tesla S is not 200 mile/charge vehicle.
    *Edit* Oh, on the Tesla website, you can define the wheel size to 21" size. This further decreases range. 19" wheels actually helped Broder go further.
    lensovet likes this.
  10. iClaudius
    iClaudius Active Member
    435
    135
    Kansas
    Musk did the right thing because the much bigger story was "Tesla logs prove NY Times reporter lied" gleefully carried by NYTimes media competitors.
  11. ystasino
    ystasino Active Member
    793
    50
    Tucson, Arizona
    lensovet and JMD like this.
  12. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    Very true, and I don't see that as a spoof, but as the real marketing approach of the future. But this is how everything is marketed in life. Also, as well as marketing lies, there are reporting lies. The reporter's "discovery" that lack of common sense mixed with a lack of physics knowledge can be reported as a faulty car is the issue here.
  13. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    I say Broder violated the Ethics of his Profession and should be held accountable.
  14. John H
    John H Senior Member
    2,208
    558
    If he was testing the capability of the supercharger network, then why did he purposefully neglect to fully charge each time?
    It's like flying a plane from NY to LA and only putting in just enough fuel, then having some headwinds, landing in LV and because your running late only getting a few gallons to get to LA.
  15. JMD
    3,779
    1,282
  16. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    reposted in EV section
  17. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
  18. Zythryn
    6,408
    4,407
    I think that would be a great discussion to have in another thread so as to not take this one off topic.
  19. Zythryn
    6,408
    4,407
    Completely false.
    Tesla has far more range estimates and tools for both owners and prospective buyers than any other car company.
    The fact that cold limits range is well known.
    The stated focus of the NYT'S article was a test of the supercharger system which is in the early stages of being built. The reporter failed to use the superchargers to fully fill the tank (he didn't even fill to the full standard charge setting at the second stop).
    It would be as if a reporter didn't fill the Prius tank and then complained when the tank of the Prius only delivered 200 miles.
    And yes, there is no question that filling the 'tank' of an EV takes more time than filling a gas car. But that wasn't the point, was it.
  20. wjtracy
    wjtracy Senior Member
    11,367
    3,608
    Northern VA (NoVA)
    Hey this NYTimes article reminds me the EV point I have been trying to make all along: that is Broder was probably putting out more CO2 and other emissions in his trip compared to a Prius. He had to dump quite a few electrons in that Model S, to make that winter trip. Can you imagine CO2 if he drove like everyone else on the NJ Turnpike: min 75 MPH with heat on?
