Clunking noise from suspension area
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by devin_d123, Mar 31, 2021.
  1. devin_d123
    devin_d123 New Member
    Fresno, CA
    A few months ago I noticed a clunking noise coming from under the car when driving at lower speeds over uneven pavement or bumps. I don't hear anything when driving at higher speeds. Today I rocked the car on all 4 ends to isolate the noise. It's coming from the suspension area next to the wheel on the front end passenger side. Any feedback on what's wrong and how urgent it is to fix it would be much appreciated. Here's a video of the noise it made when I rocked the car:
    #1 devin_d123, Mar 31, 2021
    kenoarto likes this.
    49,397
    you probably need new bushings, not urgent. look around for a suspension shop.
  3. Mdv55
    Mdv55 Active Member
    246
    181
    Boston
    You really need to raise the car and start grabbing parts to see what has play. Sway bar links would be my first stop since they're cheap and knock like that when they're worn. It could be a lot of things though. You need to dig a little deeper. That video isn't going to help with a definitive diagnosis.
    Fostel likes this.
  4. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    Stabilizer links
  5. Paul E. Highway
    Paul E. Highway Active Member
    200
    127
    Hawaii
    Sway bar links aka stabilizer links aka stab links. Sways bar bushings while you're at it. Cheap and easy.
  6. wingfeathers
    wingfeathers Junior Member
    16
    If it helps future visitors to this discussion, I had a similar issue which I was finally able to resolve! I had the vehicle inspected by technicians twice, who couldn't find anything loose with the suspension or steering. I poked around and found two possible sources: the plastic wheel well liners and the heat shield towards the front of the cat. Each of these items were slightly loose when I pushed on them. I placed some rubber padding between the liners, and for the heat shield I installed new fasteners. My clunk is gone. Hope this helps someone!
    Paul E. Highway likes this.
  7. wingfeathers
    16
    Forgot to add, it could also be sway bar links. I noticed the rubber boots on mine were torn. Check those if the above post didn't help
  8. America964
    America964 Junior Member
    I have a clunking noise. Mechanic said it was the shocks and he couldn't do right away so I bought front and rears and did the job myself. Noise still there so I replaced the sway bar bushings, clunk still there. The sway bar links looks in great shape, but think that might be the only thing left I haven't tried. The clunking noise sounds like a dribble and at higher speeds the noise goes away. Any other source of the noise. Ordering the links now
  9. Canada 509
    Canada 509 New Member
    Csnada
    I got exactly same issues (noise on small bumps only)and exactly same steps to fix it. How did you end up? Was it sway bars?
    #9 Canada 509, Jun 15, 2023
  10. AdRoc
    AdRoc New Member
    Tennessee
    Also suffering from this hell, did this fix it?
  11. ILIA DEMIDOV Los angeles
    Los angeles
    I’ve got this struggle this week , gonna find and fix it and post here . I just changed 1 sway bar link last week , but it looks solid . Maybe heat shield . These sounds are annoying!
  12. ILIA DEMIDOV Los angeles
    Los angeles
  13. ILIA DEMIDOV Los angeles
    Los angeles
    I’ve got this sound a few days after change a sway bar link that looked solid . However problem of knocking sound was because the bolt on sway bar link was not fully tightened.when I was shaking sway bar link from left to right it was solid , but then I tried to push it up and then again from down to up , it knocked . I tighted up bolt on the top of sway link and it worked !
