Cluster lights out/ no energy data on MFD
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Priusprofit, Jul 7, 2018.
  1. Priusprofit
    Priusprofit Member
    96
    32
    Long island
    Hello everyone! I recently purchased my 7th prius! It is a 2005 with 264k miles.
    The car needed a lot of small repairs that I've done on other priuses before (strut, ignition coil, coolant temperature sensor, coolant flow control valve, oxygen sensor)
    BUT! This morning I got into the car to begin working on them all and 90% of the cluster lights were out and the MFD had no energy data.
    The cluster only displays the check engine light and turn signal arrows when turned on. Everything on the MFD works it just does not display energy information.
    I have removed a prius cluster before and it was terrible so I'm really hoping that's not the case with this prius.
    Any insight to what might be causing this issue is greatly appreciated.
    The check engine light is coolant/o2 sensor related and the car still runs and drives.
  2. hchu1
    hchu1 Active Member
    316
    128
    Houston, Tx.
    2014 Prius v wagon
    You have a dead combo meter. You can check the many threads on the forum. I understand these guys do good work, check them out, give them a call.
    Prius Speedometer Replacement
    Priusprofit and ITBland like this.
    52,391
    start with the 12 volt. if that is okay, you might be sool.:unsure:
    Priusprofit likes this.
