Cluster Panel Glass
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by ThatOddMan, Jan 19, 2021.
  1. ThatOddMan
    ThatOddMan Junior Member
    61
    24
    Alhambra, CA
    2014 Prius Plug-in
    The OCD in me wants to replace the "foggy" glass on the cluster panel of my PiP.
    Is this part number 55403-47040 the outer most part of the cluster panel-the outer glass?
    I checked ebay and the only ones being sold are the complete assembly of the cluster panel.
  2. jerrymildred
    jerrymildred Senior Member
    11,508
    14,109
    Tampa, FL
    It might just need a good cleaning. I had something like that on a couple Gen 2 panels. When I took apart the dash and got the plastic off, it was fine. Turned out that it was the face of the combination meter itself. A little polishing and it was good to go.
  3. ChapmanF
    15,508
    Sometimes it's helpful to remember that meter really projects upward through a window in the dash, so if there have ever been sticky LifeSavers rolling around up there or something (eww), a little cleaning might be in order.
  4. QuantumFireball
    QuantumFireball Active Member
    419
    268
    Ireland
    And also note the screen at the top (facing you) is acrylic, not glass - so don't use window cleaner on it unless you want it to be foggy :)
