Clusterboard Problem: Related to Very Low MPG?
Discussion in 'Gen 2 Prius Fuel Economy' started by skylinedrive804, Jul 14, 2018.
  1. skylinedrive804
    skylinedrive804 New Member
    Daly City, California
    Hello,
    184K miles. Car dash says I'm getting 40 MPG, my calculations say I'm getting 25 MPG. My cluster board only turns on 50% of the time, and has been like this for a year. Haven't switched it out just to save money, figuring it doesn't affect the driving.
    **Few days ago, switched to a "new" [See: refurbished/re-built] $600 main battery, since Toyota said to replace mine ASAP. Hasn't greatly helped the MPG.
    Will try thinner oil, putting LRR tires on the front, and will check the 12volt battery (a local mechanic said I shouldn't worry about it with MPG: this forum says different). Have heard new spark plugs help, as does replacing the inverter coolant (?).
    52,847
    the car is reporting correctly. (despite the fact that it tends to be optimistic) so you are probably getting high thirties mpg.
    your problem is the gas tank bladder, which often doesn't allow consistent fill amounts.
    you need to start tracking your measurements at the pump, and averaging them out.
    another problem will be the $600. rebuilt battery, which likely won't last very long.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    It's hard to think of just one thing that would give you that bad of fuel economy short of towing a fully loaded tractor-trailer rig behind your Prius.
    Not having LRR tires will hurt pretty badly. So will dragging brakes. Hard stopping is a tremendous fuel waster. Hard acceleration is almost as bad. A low 12V battery will also be a power drain since the car is working harder to charge it, but not all that much.
    I don't see how a bad CM will affect your efficiency, but I would get it replaced so you know if you should expect flashing red and blue lights in your rear view mirror, if nothing else. Another thing to keep in mind is that I don't think the odometer is working when the CM isn't working. So you're probably going a lot farther on a tank than the odometer says on those occasions when the odo lights up. I could be wrong about this, though.
    As @bisco said, a rebuilt battery is one of the surest ways to buy trouble. What you have isn't likely to be hurting you now, but it will do so way sooner than you will like.
  4. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    The clusterboard has know bad solder problems, try toyota for a possible warranty
    The traction battery....
    If replaced with a new Toyota traction battery 2,500$ (Installed) will give five years of like new mpg’s, as long as the wheel bearings aren’t seized
    #4 Lucifer, Jul 14, 2018
  5. bisco
    52,847
    glad to see you upped the battery cost.:)
  6. JC91006
    16,936
    8,647
    How often do you change oil?
  7. Texas Hybrid Batteries
    Texas Hybrid Batteries Senior Member
    271
    564
    Dallas -Fort Worth
    I think Jerry is probably right that you're driving further on a tank than you think you are and that's why your calculations are so low. Miles are not added to the odometer when you drive without the combination meter working.
    ITBland and jerrymildred like this.
  8. jerrymildred
    11,517
    14,167
    Tampa, FL
    Thanks for the verification. I had assumed that the storage of the miles driven was dependent on the CM.
  9. skylinedrive804
    I don't think the odometer stops when the dashboard goes dark, because I note the odometer AND create a new 'Trip A' to run parallel with the odometer after each fill. When the dash comes back on, the readings are still aligned. This last fill, after 2 days of the dash going dark, gave me 11 MPG. The full before that, when the dash was on, gave me 44 MPG. When the dash goes dark, it feels like it's constantly in B mode: the car seems to be pulling more. I never let the gas gauge below 3 squares because it's faulty and has left me on empty a few times on the road. *last week, when I manually reset the MAINT REQD light, the MPG jumped up to 44 MPG, as it did this morning after filing it up, lights newly back on. Thoughts, anyone? Appreciate you guys. I wonder if replacing the fuel tank and cluster board would help this huge difference in MPG. Changed the air filter a while ago. The 600 battery helped bring it up from 25 mpg.
    on
  10. skylinedrive804
    I hope you're right about the odometer not tracking when the dash goes dark...that could mean there may not be an MPG problem after all
    If I were to fix only one of the two recommended things (fuel tank switch or cluster board), I'm guessing the CB would be better? (I'm cheap)
  11. skylinedrive804
    Every 3-4,000. I might be using oil that's too thick. I ask for standard.
  12. skylinedrive804
    I was told my two front tires aren't LRR. I get them rotated every 3,000 miles. Not sure if it'd be cost efficient to change the two out.
  13. jerrymildred
    11,517
    14,167
    Tampa, FL
    I can't think of stronger evidence that the odometer DOES NOT work when the dash is out. If it did work, your mileage would be the same. Also, I would pay heed to @Texas Hybrid Batteries comment. He fixes CMs so should know more than either of us about how they work.
    dolj likes this.
  14. dolj
    dolj Senior Member
    8,641
    4,393
    Wellington, New Zealand
    No. Fix your combination meter first, then look at other things, if there is still problem. Even then, I would wait until the tires were worn out before changing them. Just get the best LRR you can justify at that point. It would not be cost effective to change out the tires just because they are not LRR.
    Let me repeat that.
    I can't think of stronger evidence that the odometer DOES NOT work when the dash is out. If it did work, your mileage would be the same. Also, I would pay heed to Texas Hybrid Batteries comment. He fixes CMs so should know more than either of us about how they work.
    jerrymildred likes this.
