Clutch damper failure? Engine cutting out
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by totalimpact, Jul 5, 2019.
  1. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    True.
    Safest bet is buy them from Toyota dealer online. Little cheaper.
    I like Olathe.
  2. johnnychimpo
    johnnychimpo Active Member
    522
    112
    Monterey
    Yup denso injectors new ngk and back to denso spark plugs and finally oem coils from Toyota no change still missfire. Oh compression test 160 psi all 4 cylinders. I'm out of ideas.
  3. johnnychimpo
    522
    112
    Monterey
    Im stil getting a clink clank when in maintenance mode and I put it in neutral only in neutral do I get this noise. I hope that it is the misfire causing a minor knock at the motors and engine try to sync back up again but then again its in neutral. in any case im taking it to a prius specialist who told me they have never seen a bad damper. Will report back next week.
  4. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Can’t remember any on this site. If it fails the engine is no longer connected to the trans so .....
  5. ChapmanF
    19,008
    If it fails in the form of the central coil springs fragmenting and falling to the bottom of the bell housing, the engine is definitely still connected to the trans, except that speed fluctuations now make very loud bonks. Photos of such dampers have been posted on PriusChat. I don't think I have URLs saved to any of those threads, but they were definitely on this site and that's how I saw them.
  6. UncleLee
    UncleLee New Member
    You didn't report back "next week"
    Check to see if your "clink/clank" is the front wheels trying to turn. Similar issue turned out to be the ECM/PCM short inside caused injector failure and one symptom was the wheels trying to go move while it park with a loud "clink/clank".
    He asks: "what was the outcome?"
    Then fails to list what was his own outcome....
    #26 UncleLee, Mar 26, 2022
  7. johnnychimpo
    522
    112
    Monterey
    I ended up swapping the trans. in the post mortem/headgasket saga I guess my car did too much morning shutter and I think damaged something in the trans. I think all Prius do it ... a slight thunk when they start. my may have been way out of specs so I found a used trans with 60k on it and the sound when away. One other thing my old trans made a metallic popcorn sound along with the clank at start. both went away after the trans swap.
  8. Another
    Another Senior Member
    1,819
    520
    Naples, Florida
    How much work was it to swap the transmission? Time, etc?
  9. johnnychimpo
    522
    112
    Monterey
    YOu need to pull the engine. its a project but doable it took me two day. basically the weekend by myself except Grandpa helping with the cherry picker adjusting it lowering as I kick the engine into place from the side to marry to the trans. It is totally worth it. here is an example where I got it called LQK
    LKQonline | eBay Stores
    #29 johnnychimpo, Mar 30, 2022
  10. Lemon Drizzle
    Lemon Drizzle Junior Member
    Hall Green, West Midlands
    Can this be done whilst the car is on jack stands I.e from underneath the car and without taking out the engine?
  11. PriuSocal
    PriuSocal Member
    377
    62
    SoCal
    Sorry to revive this thread but i just posted a similar issue on her eon my 2008. I am getting a sound like grinding or coins in a dryer when I start the car. You can definitely hear something turning but the ICE doesnt seem to be on. I initially also got a lone code of P0A90 for Drive A motor but the scanner I had did NOT give the 3 digit sub code so when the car came in yesterday I hooked up my ICON T10 scanner but 12V battery was too low to keep the car on and scanner to fully diagnose BUT I did get 2 new codes and the P0A90 is not there anymore at least couldnt stay on long enough to perhaps come on. But, just like the OP up here said, I am now getting P0A80 Hybrid Battery Needs Replacement and P0335 Crankshaft Pos Sensor which I mention was not coming in before.
    I read from another post that having a low or dying 12v battery could cause these “false-positive” codes to come on so I am not=w charging the battery to try and do a proper diag tomorrow with a fully charged 12v. I went to the junkyard and was lucky to find a good cond damper in a lower mileage prius and picked it up just in case its the damper that is damaged (saw a video of a guys damper springs falling off and that was making the rattle).
    Finally, If the damper itself is whats damaged (once trans is removed and confirmed), could I simply put this used damper assembly in and put the trans back in or would the whole trans need replacing either way? I am really hoping my ICON T10 can give me a the 3 digit subcode to know what exactly the p0A90 was. One good thing that my scanner has is the TOPOLOGY so hope this points me int he right direction.
