Coastal EV Mod Problem
Discussion in 'Gen 2 Prius Accessories & Modifications' started by veryblueprius, Apr 26, 2012.
  1. veryblueprius
    veryblueprius New Member
    Ok, so the problem is that the plug will not come out no matter what. I made sure I was pressing down on the clip, and tried working it out of the slot. Is there any special technique that can help? It's almost as if the plug is glued in.
    :confused:
    52,785
    did it 7 years ago, i forget what it looks like. can you put some pliers on either block?
  3. veryblueprius
    I tried using pliers, but the tangle of wires makes it impossible. Is there a way to pry out the block using a screwdriver? There seems to be two slots on the side where this might work.
    52,785
    probably, but it's been so long, i can't remember. hopefully someone has done it recently. can you post a pic?
  5. veryblueprius
    Nobody has any solutions? I'm probably the only one with this problem. :p
  6. veryblueprius
    Ok I installed the ev mod. Problem solved.
