Coasting and tranny ???
Discussion in 'Knowledge Base Articles Discussion' started by MR.K, Apr 7, 2008.
  1. qbee42
    qbee42 My other car is a boat
    18,058
    3,077
    Northern Michigan
    No, that's correct. There is a fixed clutch between the ICE and the PSD. This clutch allows a bit of slip when the ICE fires up, to help avoid shock load and jerkiness. It is never disengaged or "thrown out", but instead just slips a bit when necessary.
    Tom
  2. zeeman
    zeeman Member
    211
    that is interesting
    i suppose that is controlled slip, akin to slip of clutch pack in a top fuel car, except this slip in prius is probably just in a duration of a second or 2 to avoid harsh engagement/disengagement
    is this about right?
  3. patsparks
    10,664
    567
    Adelaide South Australia
    There is no clutch and no slipping.
    There is a tortional damper which looks like the centre of a clutch plate in a manual car but this just smooths the power delivery of the ICE through springs. There is no friction material and no slipping just springs.
  4. qbee42
    18,058
    3,077
    Northern Michigan
    That's good to know. I assume the torsional damper allows a small amount of rotational displacement before the springs pull it back into alignment. Is this correct? That would work exactly as described above, but without the wear and maintenance issues of a clutch and frictional surfaces.
    Tom
  5. MR.K
    MR.K Junior Member
    86
    Idaho
    So do you have to lightly step on the brake to go from D to N when moving to coast?
  6. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    Nope, just hold the shifter at the N for about 1 second.
  7. narf
    narf Active Member
    611
    45
    Colorado
    Four Touring
    OK, there seems to be a lot of conjecture about what happens when you shift into N over 42 mph.
    The N mode just changes modes in the computer. It prevents any power from being used for forward propulsion, and prevents any regenerative braking from slowing the car. It's like a forced glide. There is NO WAY that the engineers at Toyota would design the software to allow you to overspeed any components of the drivetrain just by moving a lever. just imagine the warrenty costs they would have to deal with!
    According to my scangauge, when running at highway speeds in neutral the engine will run at a low RPM. As you coast to a stop the engine eventually will stop.
    I use the N position all the time when coasting down hills, or any time I want to maximize my coasting. No problems.
  8. efusco
    19,891
    1,194
    Nixa, MO
    You may be right, but you're dealing in conjecture yourself...and I think you're wrong.
    If I shift into neutral while in an ICE-off glide below 41mph then coast/glide down a hill while still in neutral the ICE can not start. Your characterization of what's happening is over-simplified...indeed the ICE is not capable of starting while in neutral. If the ICE is not running (as in my ICE-off neutral glide down a hill) and I exceed 62mph MG1 will exceed 10,000rpm. I have personally observed, via CAN-View, 9960rpm at 61-62mph. I saw no sign that the car was going to electronically kick me out of neutral (which one would think would happen at around 60mph to give a margin of safety) and therefore did it myself as I wasn't willing to sacrifice my Prius to see just exactly what would happen. If your confidence in the Prius engineers is greater than mine feel free to try this on your own and let me know what happens!!
    I think what you're missing in your assessment is that you talk about going into neutral when the speed is in excess of 41mph...in that case the ICE is, indeed, running and can run faster, if necessary, to avoid MG1 overspinning. But in my case I'm entering under 41mph with the ICE off...there is no way the ICE can start back up once I enter neutral.
  9. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Tom
    Similar torsional dampers are used on centrifugal blowers and other large equipment at industrial plants. With a +200 HP electric motor, the bearings wouldn't last long if there wasn't a way to minimise the startup and shutdown harmonics
    Cheaper couplings just use an elastomer material inbetween splined metal fingers. They work but don't last, and the failure mode is usually a catastrophic one
    The question I have is this: why on earth would anybody want to or need to shift into N at highway speeds while driving a Prius? At the very least, you prevent charging the traction battery
    jay
  10. narf
    narf Active Member
    611
    45
    Colorado
    Four Touring
    I will be glad to try it when the opportunity arises. What I think you are missing is that the ICE doesn't have to start. MG2 (it is MG2 isn't it?) will spin up to prevent an MG1 overspeed condition. That will spin up the ICE without actually using fuel.
    Anyway, if the situation presents itself I'll to the test and report the scangauge data.
  11. qbee42
    18,058
    3,077
    Northern Michigan
    MG2 is tied directly to the drive train. Its speed is not controlled by the ECU. Only MG1's speed is controllable. The speed of the ICE is a product of the relative speeds of MG2 and MG1. That's why MG1 goes so fast when you coast without the ICE spinning. If the ECU slows down MG1, then the ICE will start to turn. That works without question. The question is whether the ECU will limit the speed of MG1, or rigidly stick with the no-starting-in-neutral rule that is otherwise enforced. Evan's experience suggests that the ECU will not limit the speed of MG1. This makes sense since MG1 is not powered in this mode, but is merely freewheeling.
    Tom
  12. qbee42
    18,058
    3,077
    Northern Michigan
    Jayman,
    Many marine engines use this sort of damper to connect the engine to the propeller shaft. In this case they are usually the cheap ones with the elastomer.
    Our marine diesel has the prop shaft bolted directly to the drive flange of the engine. Our engine is also directly bolted to wooden engine logs. Must be that we enjoy vibration. :dance:
    Tom
  13. Danny Hamilton
    Danny Hamilton Active Member
    926
    94
    Greater Chicagoland Area
    Actually, so long as the wheels are turning MG2 is always spinning. Furthermore, MG2 rpm is in direct proportion to the rpm of the front wheels (assuming that both front wheels are spinning at the same speed).
    At any given constant speed MG1 and the ICE balance against each other. As the ICE changes speed, MG1 must change speed to compensate. If the shaft of the ICE is not spinning at all, then all changes in vehicle speed much be compensated for with a change in MG1 speed.
    At 62 MPH, if the ICE is not spinning (because the driver chose the Neutral drive setting below 42 MPH when the ICE wasn't spinning), then one of three things will have to happen.
    1) Neutral will no longer keep the ICE shaft from spinning and the ICE will suddenly be allowed to spin. (through testing with various tachometer solutions it has been confirmed that prior to 62 MPH this does not occur)
    2) The vehicle will apply some form of braking mechanism to prevent exceeding 61 MPH. (regen? automatic application of friction brakes without driver input?)
    3) MG1 will exceed the 10,000 rpm it is rated for and risk of failure will increase substantially.
    Now, I'm not sure what the original source of the information is, but it seems to be generally excepted here at PriusChat that if the ICE shaft is not spinning and the Neutral gear selector is chosen, then the ICE shaft will not spin again until a non-neutral selector is chosen (Park or Drive). It is also generally accepted that the vehicle will not under any circumstances engage in HV battery charging while the Neutral gear selection is chosen. If both these are true, that only leaves option number 3 above.
    I assume that you are indicating a belief that option number 1 above is what the engineers are likely to have designed into the vehicle?
    It appears that there is some mechanism in place prior to 62 MPH that holds the ICE shaft in place and keeps it from spinning. Your belief seems to indicate that this mechanism will suddenly release, allowing the ICE shaft to spin freely as needed at 62 mph. Additionally there must be some sort of mechanism to maintain MG1 at or below 10,000 rpm to provide the resistance necessary to transfer force to the ICE shaft to accelerate it and acquire the appropriate rpm from the ICE?
  14. efusco
    19,891
    1,194
    Nixa, MO
    MG1 and MG2 are not directly coupled in a way that will allow that to happen.
    Unfortunately the only data that will help will be whether you required a multi-thousand dollar repair of MG1 or not.
    As I said, you may be correct that at the 10k rpm threshold the computers may be programmed to override neutral back to drive which will allow the ICE to spin up (ie. Danny's #1 in the preceding post) ...but I doubt it for reasons stated above...no evidence at 9960 rpm that that was going to happen. You'll be risking your Prius on the unfounded belief that Toyota programmed it that way. Remember that when the car is in N it can't charge the HV battery...it's the one and only way (pretty much) to kill it beyond repair and there are no overrides programmed to prevent that. I think N is the one state that most of the normal overrides and protections are disabled. I'm not gutsy or wealthy enough to test it.
    And it's MG1 that spins up the ICE.
  15. dogfriend
    7,512
    1,189
    Carmichael, CA
    Come on, how about taking one for the team. :D
    I don't know if this is OT or not, but interesting to consider is that N in the Prius is not a mechanical state of the transmission, but a disconnection of the electrical field current in both MGs. That is why the car cannot start the engine in N; there is no field current to power MG1.
    Also, I doubt that an even 10k rpm is the magic number that the MG will catastrophically explode; someone at Toyota has probably tested this on a few transaxles and then derated the actual speed limit to give a margin of safety. That isn't to claim that you aren't doing some damage at that speed though; you might get away with it a few times, then get your catastrophic failure at lower speed because you initiated a crack a few months before.
    I think I will just leave mine in D. :D
  16. Ichabod
    Ichabod Artist In Residence
    1,794
    Newton, MA
    Speaking of torsional damping and MG1 cranking ICE:
    I wonder, since Evan got MG1 to 9960 RPM with ICE at 0 RPM, would damping between MG1 and ICE be enough if ICE started from 0 RPM while MG1 is @ 10k RPM? Or would there be further risk damaging the drivetrain or motors by allowing a shock like that? I know ICE routinely starts and stops with MG1 around 6500 RPM, so maybe another 4k is not enough to stress about.
    But I have to wonder if that's part of the design decision to limit to ICE-on at higher speeds, not just avoid high RPMs in MG1.
  17. pdefalla
    pdefalla New Member
    Santa Barbara
    So I just bought a 2008 that has a transmission position labled "B". I haven't even finished reading the manual, so I havent' gotten to that part yet, but when reading this thread it made me wonder why nobody is referring to this. Is this setting new?
  18. dogfriend
    7,512
    1,189
    Carmichael, CA
    B mode is not new; it is on all Prius. It is analogous to "2" (or possibly 1) in a 'normal' automatic transmission.
    For more info read this
  19. jayman
    13,439
    641
    Winnipeg Manitoba
    Tom
    A low speed application, that should be ok. A surprising number of high speed (3600 rpm) +200 hp electric motors are hooked up to centrifugal multi-stage blowers that way, which is *not* a good idea
    Kind of historic and romantic to have this 1-2 cylinder iron horse diesel knocking away. As a kid, I remember one of my uncles having an ancient Lister diesel on his farm to run a water pump
    The Lister had pushrods external to the block, and you could watch them go up and down. For a kid, it provided hours of entertainment. It was built like a brick s***house, for under 20 hp it weighed around 800 lbs. Easy to take apart, clean/rebuild, and reassemble
    jay
  20. DrFranken
    DrFranken Junior Member
    Middleville, Michigan
    And according to my Scangauge even when no power flow arrows appear on the display the battery is being pulled at about 6 amps. When N is selected that drops to just below 1 amp with nothing but the radio on. (More with lights, fans etc.) When doing lots of pulse and glide it seems that N helps keep the traction battery from draining.
