1. mhdriver
    mhdriver Member
    162
    61
    florida
    Check engine light is on. Just got my Prius back together yesterday after water pump/thermostat/pcv/egr/cooler/manifold service.
    Was very careful to torque it all, went over each connection several times. I didn't put the cowling back on yet, will do so in the morning. I did connect the wiper motor to avoid an error code. Ran for a bit in mainentance mode, refilled with about a gallon and a half of antifreeze fluid.
    Tomorrow will get the car completely ready to drive. It sat for a few weeks but started up easily and battery is mostly charged.
    ODB scanner says "MANFOLD ABSOLUTE PRESSURE / BAROMETRIC PRESSURE CIRCUIT HIGH.
    Dr. Prius cannot seem to connect to this scanner.
    Any ideas, I'd be happy to listen. My plan is to get it out for a drive and see if the symptoms resolve.
  2. mhdriver
    mhdriver Member
    162
    61
    florida
    A bit more background here. I did buy a new exhaust manifold off ebay. It was reviewed well by others but it is a cheap version. Forgot what I paid. I will clean the old manifold tomorrow and see if that fixes it. Also got a new EGR valve online from a Toyota dealer on a close out. A bit over $100 dollars. I can clean the old one as well. Wasn't getting this code before. Will also check MAP sensor to see if anything obvious is wrong. I suppose the first thing to do is just clean the MAP sensor and hope the code goes away :).
    Edit: I did order a new MAP sensor. It was cheap enough. My suspicion is the manifold. Second time around should be a lot quicker. Of course, the map sensor bolt did break off in the manifold, so there's that :). My biggest concern of "too much pressure" is blowing a head gasket.
    #2 mhdriver, Feb 13, 2026
  3. mhdriver
    mhdriver Member
    162
    61
    florida
    Got down to the map sensor and went to remove it, but noticed it slid out easily. Apparently, I didn't connect it properly. Clicked it, disconnected the battery/waited 10 minutes, and no code on the start. Now to put the cowling back on and take this sucker for a test drive :). No error codes, no triangle of death. Thanks to Merv and NutsAboutBolts and all the guys on PriusChat!
    Now I do know it is sacrilege, but I did put in a 1/2 dose of the low dose Kseal, which was 2 oz total. Hoping to seal any very tiny issues that could be staring with my head gasket. 205k, hoping to get to 300k before I replace the head gasket or the motor.
    Had I not run into so many broken bolts, this would have been a 2 or 3 day job for me. I'm not a pro, I haven't got the greatest tools. All in all, a great learning experience. Just hoping that's the end of it and I can drive for a few months without issues. My advice to others is if you don't have an extra car and can afford to be down for a while, pay a shop to do this.
    #3 mhdriver, Feb 14, 2026
  4. ChapmanF
    18,922
    Looks like the OP might have things sorted, but just for other readers who happen by, $0738 is not a trouble code. Trouble codes all start with a letter P, C, B, or U.
    The $0738 would be the CAN address of an ECU that has a trouble code. Not completely uninteresting, but tells you much less than an actual trouble code.
  5. mhdriver
    mhdriver Member
    162
    61
    florida
    Yes, the readout on the OBD scanner is what led me to the solution.
  6. mhdriver
    mhdriver Member
    162
    61
    florida
    The bane of this job was the 6 mm bolts. I had about 6 of them snap on me, only able to get two out and the rest I had to drill. The ones I got out broke right at the rusted nut but were easily turned by pliers. The ones that broke at the base, impossible for me to extract. Very important for first timers to realize that these bolts can be very problematic. Wish I had knows this when I started. Had no issues at all with 8mm.
  7. Mendel Leisk
    42,223
    If you will entertain a grumble: by my count this is the seventh thread you've started, on essentially the same topic.
  8. ChapmanF
    18,922
    It's important, in any case, for readers to recognize what part of the readout on an OBD scanner is a trouble code, and what part of the readout is not a trouble code.
  9. mhdriver
    mhdriver Member
    162
    61
    florida
    Sorry. It's over now! This had me majorly upside down in the real world.
    Mendel Leisk and bisco like this.
  10. Mendel Leisk
    42,223
    We're all of us that close (holds finger-and-thumb tightly pressed together) to an existential crisis, in this thin veneer we call reality.
    That's my navel-gazing quota for today. :)
    CR94 likes this.
  11. mhdriver
    mhdriver Member
    162
    61
    florida
    Maybe it's not over just yet. Popped the same code, but a little diferent verbage, pointing at vapor cannister purge valve. Common thing here seems to be that manifold. Drilling out the broken bolt in the original manifold and cleaning it, got it soaking in Purple Power..
    Overall, mileage after EGR cleaning has improved by 7mpg. I'm impressed with it. Other than the code, the car is running great. Using no coolant. I think I can change that manifold in no more than a couple of hours at this point. Doing it next week. Also putting in a new MAP sensor. It's going to be a bit of swapping around until I find the issue.
  12. ChapmanF
    18,922
    Please let us know the actual code being reported: the 5-character thing that starts with a P, C, B, or U, not the "$0738" address of the computer reporting the code.
    "diferent verbage" is the giveaway that you don't have the same actual code this time; the "verbage" that goes with each code is constant.
    Brian1954 likes this.
  13. mhdriver
    mhdriver Member
    162
    61
    florida
    You're correct. I did see the number and it was a P0441 code for purge valve. Took the air intake off and got to it. Again, found I'd not gotten the click when putting it back together. Did that, cleared the code and did a 20 mile test drive, no return code. I'm firing my mechanic. Now for shocks and struts, something easy with no electronics.
