Code c1345 & c1368
Discussion in 'Prius v Technical Discussion' started by Eddie cortez, Nov 6, 2023.
  1. Eddie cortez
    Eddie cortez New Member
    Arizona
    Workn on a 2012 prius v with the named codes above i have attemped to clear memory test and recalibrate does not complete nor can i erase codes to do so any advice to correct problem also on named vehicle were is the skid control unit located thx in advance
    52,347
  3. rjparker
    rjparker Tu Humilde Sirviente
    10,454
    6,556
    Texas Hill Country
  4. Eddie cortez
    Arizona
  5. Eddie cortez
    Arizona
  6. Eddie cortez
    Arizona
    I have read and tried most of it useing a xtool scanner any idea how long to wait for completion ring light blink after 120 minutes or?
  7. rjparker
    10,454
    6,556
    Texas Hill Country
    Built into the brake booster / master cylinder assembly.
    #7 rjparker, Nov 7, 2023
  8. Eddie cortez
    Arizona
    so basically The unit is bad ?
  9. rjparker
    10,454
    6,556
    Texas Hill Country
    XTool D8? People have trouble running the bleed procedure even with Techstream.
    What is the history of this problem?
    What happens when you drive it?
    The brake boosters are a common failure on these cars.
  10. Eddie cortez
    Arizona
  11. Eddie cortez
    Arizona
    Well ill strt with i purchased vehicle for son in law ‍♂️ no issues after some time light turn on after cld never relearn after. Now battery dead and need a new 1 also i myslf inspected the brakes ect it in need of pads all arnd as well as a fresh bleed of new fliud once battery pads changed ill try agn and bleed it out hope thts all it is aslo ? On this issue how can one know if it the acuator or the contorller codes basicly read out of spec correct?
  12. Eddie cortez
    Arizona
  13. Eddie cortez
    Arizona
  14. Eddie cortez
    Arizona
