Code P0A80 + P3013 All Battery Cells reading good! Any thoughts?
Discussion in 'Gen 2 Prius Main Forum' started by vcvtrading, Jul 10, 2019.
  1. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    P3013 = Block 3 becomes weak...which means one of the 2 modules that makes block 3 is failing....block 3 is modules #5 and 6 from the negative cable end. So, it makes sense, if your #6 is the 6th module from the negative cable.
  2. vcvtrading
    53
    22
    Arkansas
    Yes #6 makes sense based on that code... IF I have numbered the cells correctly. I think the Camry battery is built differently, and I do not see where the negative cable is attached. See pic of my Camry battery... I numbered the cells starting with #1, right to left of the pics (far right of the pics start #1, far left ends with #34).
    see Strawbrad... There IS a need to know and understand the cell order and what banks are what! (Sorry, just poking fun! And a call out to PriusCamper for defending that one!) IMG_7167.JPG IMG_7170.JPG
    PriusCamper likes this.
  3. strawbrad
    953
    1,007
    Yes it is normal for the voltage to bounce back after a discharge. Likewise voltage will drop after charging is finished. Is the module you have have labeled #6 the one that started out at 7.69 volts?
  4. PriusCamper
    PriusCamper Senior Member
    13,456
    5,430
    Pacific Northwest, USA
    Congrats, you found it... Now you're in preventative stage... Wanna try to find the module that will go bad next before the dash lights up? Also interested in doing battery re-condtioning to find next bad module? Let us know? Sometimes it's easier to wait till later, sometimes it's easier to find 'em now.
  5. vcvtrading
    53
    22
    Arkansas
    Strawbrad.. .I think I was a bit dyslexic or going from bad memory when typed 7.69. After I actually documented on the spreadsheet, I did not have one reading that low.
    Priuscamper... Yes, I would like to know more about locating the next potential bad cell and reconditioning. Hopefully it does not require too much fancy equipment.
    For a regular old car battery, I would discharge it and then put a 1-amp charge on it for a few days. But I suspect it's not that easy with the cells.
  6. Prodigyplace
    12,712
    11,848
    Central Virginia
    If I were considering just replacing bad modules & extending the battery life, I would consider getting a Prolong Reconditioning System & a user module from Hybrid Automotive. @jeff652, the owner, is a very trusted user here and many users such as @Raytheeagle have successfully used his Prolong systems to extend battery life.
    Some users here have shared the cost of the system across multiple cars (separate wiring harnesses) but I see that your Camry & Prius do not use the same system. :(
    Skibob and Raytheeagle like this.
  7. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    The Prolong equipment worked well for me and there are 2 other members here in my geographic area that share the equipment and makes the equipment make even more sense:).
    I’d a module does fail, you’ll then have the equipment to rebuild it too;).
    We’ve rebuilt 3 packs using the equipment, so I’d say it pays for itself (y).
  8. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Plus if you move on to another vehicle that doesn't use the system, you can easily resell it to another owner needing one.
  9. vcvtrading
    53
    22
    Arkansas
    You guys mention "rebuild" with the Prolong? So there is more to the Prolong system than just balancing and maintaining?
    I will go and read up on it. I do not mind spending the money, if it will help me down the road. Also, I have a 2013 Prius (daughter) with 90k miles. Plus the fact I will always have some sort of Toyota hybrid.
  10. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    What I’m saying is if you have a failed pack (a bad module) you can use the Prolong equipment to rebuild the pack ;).
    Just another option when considering a tool is it’s versatility and ability to either make it save you money :).
    We’ve done well with the equipment out here(y).
  11. Prodigyplace
    12,712
    11,848
    Central Virginia
    Unfortunately the charger & intelligent discharger are different for those 2 cars.
    I am sure @Raytheeagle can explain the benefits of the intelligent discharger instead of the cheaper "light bulb" one.
    Raytheeagle likes this.
  12. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Less babysitting ;).
    With the light bulbs you have be monitoring and interacting with the system as it works. With the intelligent Discharger, all you have to do is select the discharge level and then check on it after about 4-5 hours:).
    I went the intelligent route(y).
    Prodigyplace likes this.
  13. vcvtrading
    53
    22
    Arkansas
    As I get older and wiser.. I tend to choose the intelligent route any chance I get ;)
    Prodigyplace and Raytheeagle like this.
  14. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    vcv,
    There are two heavy gauge orange cables that connect to the 'end' modules of the battery. One cable will connect to the (-) terminal on an end module and the other cable will connect to the (+) terminal on the other end module. Blocks are numbered starting from where the heavy orange cable connects to the (-) terminal.
    1prius and Skibob like this.
  15. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    It happens. That’s why you load test. It tests the capacity of the battery.
  16. vcvtrading
    53
    22
    Arkansas
    Ahhh... Thank you! I get it now. I traced the positive and negative cables to each end. I am correct on the way I numbered them! So it is in-fact bank 3 where the bad cell is located...
  17. Skibob
    2,912
    1,505
    Northern California
    Not exactly. You are asking for help in a Prius forum about a Camry. There is technically no reason for a Prius member to know how Camry modules are numbered. Its not a Prius.
  18. Prodigyplace
    12,712
    11,848
    Central Virginia
    Some members such as @strawbrad work on other Hybrids too, so tey may be more familiar, though.
  19. Skibob
    2,912
    1,505
    Northern California
    He did say if your checking all the modules there is no reason to know. :whistle:
    That being said it does confirm that 1 of modules was bank 3. You do need to know the order for that.
    I saw 2 modules that could use replacing, only 1 was in bank 3.
    1prius likes this.
  20. DWJM2513
    DWJM2513 Junior Member
    64
    24
    US
    I've just had P0A80 and P3013 pop up on my 2005 prius with 236k on it and I've read your comments. My question is can I drive it while these codes are on? And I don't have the money right now to be putting into this car but once I have it, I have no problem putting it into the car.
