Code P0A80 + P3013 All Battery Cells reading good! Any thoughts?
Discussion in 'Gen 2 Prius Main Forum' started by vcvtrading, Jul 10, 2019.
  1. vcvtrading
    53
    22
    Arkansas
    Well... I'm flip flopping like a politician running for re-election!
    I spent about 2-hours reading up on Hobby Charges last night, types, brands, how to do it, etc. both here on prius chat and other sources. I came to the conclusion I am willing to spend the money for a 'good' charger/discharger. Then came to the conclusion pretty much any one that I buy will be adapted to my situation, as most of those chargers are designed for the RC industry. So pretty much everything I read and what I want to accomplish brings me back to the Prolong system. Find any bad cells and then re-balance the pack. It seems like the Prolong system does the best job at doing that.
    Question... Can I use the Prolong system with the pack out of the car and on my workbench? I would like to get the numbers I want to see before re-installing the pack. I'm aware the Prolong system forces the fan on, etc.. and if battery is out of the car the fan and duck system won't be running.
    Thanks for answering all my questions!
  2. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    As long as you have the harness, the Prolong equipment can be used outside of the car:).
    That's what I'd use if I had access to the equipment(y).
    Prodigyplace and jerrymildred like this.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    Same here. Just keep a fan blowing on the battery pack to cool it. Preferably blowing into the air ducting to get it into the right places.
    Raytheeagle likes this.
  4. vcvtrading
    53
    22
    Arkansas
    Cool. Do you think I would need to do something extra to trick Prolong into thinking the fan is running? Or does it care?
  5. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    It doesn't care;).
    The harness plugs the fan in to utilize it, but if it isn't there, you need to have an alternate source of air flow:whistle:.
    Find a large house fan and direct it on the pack :).
    Air flow is the key to thermal heat removal(y).
  6. vcvtrading
    53
    22
    Arkansas
    Thank you. I just got off the phone with Hybrid Automotive. Had a good convo with them. I think I might pull the trigger. They seem to have tremendous re-sell value if I decide to sell it one day.
    jerrymildred and Raytheeagle like this.
  7. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Depending on where you are at in Georgia, you might find other Prius Gen2 or gen3 owners who think the equipment is also a good idea;).
    I shared the equipment with 2 other members out here which also helped reduce the investment cost:).
    Each one of us had our own harness and this worked well for utilizing the equipment that sits on the shelf for large blocks of time(y).
  8. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,099
    Columbia, SC
    This is for a Camry, which has 34 modules instead of 28, so the Prolong uses different voltages.
    The problem with the Camry and the Altima is that they are relatively tough on batteries. Every Camry/Altima battery I've disassembled and tested has come up way short on capacity compared to a similar aged/mileage Prius battery, along with having much greater variances in individual capacities. Usually, there are about a dozen modules, minimum, that need to be replaced.
    Since the car has been off for quite a while, it should be very easy to determine "bad" modules with only a voltmeter. Those will be around 6.3 volts or less due to self-discharge. Unfortunately, depending on the overall battery condition, there may be a lot of them, with some "not really bad", as they may have taken a few months to self discharge, compared to some that took only weeks or days.
    The prolong system will not tell you which modules are low capacity. It charges/discharges all the modules in series until it reaches its voltage setpoints.
    One option would be to have the cover off, (and after it has been charged) and while it's discharging, take frequent voltage readings of the 34 individual modules. Each module has 6 internal 1.2 volt cells. Whichever module has the weakest "cell" should be the first one to drop into the 6.x volt range. As the 34 modules are discharging, I would track each one that drops into the "6"es. That will give you an indication of the weakest modules (or the modules that have failing/weak internal cells).
    Then, the important thing is going to be matching the replacement modules to an estimated capacity of the remaining "good" modules. If you go through this and determine how many weak modules you have, I have several dozen "good" Camry/Altima modules on the shelf that were tested/cycled in April and May.
    #108 TMR-JWAP, May 19, 2020
    1prius likes this.
  9. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Where'd ya get the Hycam from:whistle:?
    @vcvtrading shows a Gen2 in his profile and a 2008 Prius in his information;).
    But if a Hycam, your advice is true about the battery sizes being different(y).
  10. TMR-JWAP
    6,404
    6,099
    Columbia, SC
    The 4th word in post 95....and we've had earlier discussions on the forum.
    don't feel bad though, we've all been there and we'll all be there again
    Prodigyplace likes this.
  11. jerrymildred
    11,517
    14,171
    Tampa, FL
    Also from the first post. Unless he switched cars and I missed it. ;)
  12. vcvtrading
    53
    22
    Arkansas
    Yeah, I need to update my profile! I'll do that soon. The old Prius you see in my thumbnail pic is long gone. Sold it with over 200k trouble free miles (never an issue with the battery pack). But at the same time I also had and still have the Camry. It only has 150k miles on it. It's a perfect car, other than the failing traction battery. I think I simply let it sit too long over the years. Also I've moved to North West Arkansas, so not from Georgia anymore (born and raised in GA, live in AR now).
  13. vcvtrading
    53
    22
    Arkansas
    Naw, same ol' Camry. Just sitting, waiting to be fixed and driven
  14. vcvtrading
    53
    22
    Arkansas
    What if I do a 2 min load test with a light bulb with each cell? Wouldn't that quickly show bad cell as well after it been sitting for months?
  15. vcvtrading
    53
    22
    Arkansas
    I just updated my profile. Even changed my Thumbnail pic. Hopefully no one gets offended by my version of the Betsy Ross flag o_O
    #115 vcvtrading, May 19, 2020
  16. strawbrad
    953
    1,007
    After sitting for months simple voltage readings will quickly tell you what's up. Do not start the car or charge the modules. That would obscure the effects of months of self discharge. The junk will have self discharged to 6.XX volts. They cannot be recovered. Most of the modules should be in the 7.5 to 7.7 volt range. The actual voltages do not matter as much as how they compare to each other. Any module that is .2 volts or more under the rest is suspect. Any module that is sitting at 7.3 volts or less is suspect. Module voltage keeps dropping as they sit for longer. Once the as found voltages are recorded you could do the light bulb discharge. You will find the results correlate strongly with the initial voltage readings.
    A quick rebuild strategy could be to replace the junk modules based on just resting voltage and then condition the pack with a Prolong charger and discharger. That would produce a better pack than most DIY rebuilds. A downside to this method is you are not actually measuring the individual modules.
  17. vcvtrading
    53
    22
    Arkansas
    Thanks Strawbrad. I'll make sure I don't start the car or charge the batteries. I'm ordering the Prolong system tomorrow. I'm getting the conditioning kit with the discharger. They are having issues with manufacturing due to Covid-19, so could not promise a ship date just yet. We shall see.
  18. Prodigyplace
    12,720
    11,852
    Central Virginia
    I believe they also sell used modules trying to match mileage with you current ones.
  19. LukUsc
    LukUsc Member
    69
    26
    Poland
    @PriusCamper could You please send me more information on how to check the condition of individual cells? Thank You.
    I tried find the private message option but I can't see it anywhere: /
  20. jerrymildred
    11,517
    14,171
    Tampa, FL
    LukUsc and Prodigyplace like this.
