Code p1121
Discussion in 'Gen 2 Prius Main Forum' started by zeron1982, Jan 22, 2019.
  1. zeron1982
    zeron1982 Junior Member
    2008 prius has code p1121 so after some research I replaced the water pump/control valve I bought a new one from O'Reilly but after a week the same code came back water level is good, I checked wires they have power and ground good resistance , not sure what the problem is should I be looking or replace any specific fuse or relay ?
  2. JC91006
    16,936
    8,647
    California has a 15 year/150k miles emissions warranty for this failure p1121
    You are checking the coolant level at the radiator right? Not the overflow tank
  3. zeron1982
    Unfortunately this car has 180, miles and yes at the radiator inverter and overflow tank as well coolent levels are fine in all 3 places , any more ideas ?
  4. JC91006
    16,936
    8,647
    Do you have heat? Bleed the system of air?
    I didn't know O'Reilly makes this part, most just use the OEM part from the dealer
  5. zeron1982
    Yes I have heat works fine ,
    I replaced the coolant with a vacuum system ,
    And yes O'Reilly got these parts
  6. JC91006
    16,936
    8,647
    Only advice left is to cycle the chrs pump but it seems there shouldn't be air in there. Maybe bad part.
    Hoses are correct, not mixed up?
  7. zeron1982
    Hose connections good I marked them twice ,
    What I also noticed is the check engine light comes back days or a week after I reset it ,
    So I was wondering is there a specific fuse or relay related to this part ?
  8. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    What are you reading the stored DTC(s) with?
    Those tank outlet temperature sensors can go bad, try doing a search if needed.
  9. JC91006
    16,936
    8,647
    All the information is in post #2, additional areas to check
