Code P2601 Confusing Situation - Coolant Storage Tank
Discussion in 'Gen 2 Prius Main Forum' started by SaLKar, May 19, 2026.
  1. SaLKar
    SaLKar Junior Member
    Houston
    Hello guys. Here's one for all the electrical savvy ones.
    Got the code p2601.
    Here's what I've done so far.
    Tested the pump directly with a 12-volt battery. The pump works but when plugged in it does not.
    Jumped the pump relay in the engine bay directly to see if the pump would work. I've done it before and I jumped the correct pins but nothing happened.
    Seems like the power is not coming to the relay.
    What could be my next steps to troubleshoot this?
    The wiring seems okay under the wheel well near the pump. How do I test from here on?
    Thanks in advance
  2. Tombukt2
    Tombukt2 Senior Member
    13,836
    2,512
    Durham NC
    Do you know when the pump is supposed to work and when it's not ? It do not just be on all time after certain temps or any of that . you could wire in a test led to the pump and sit it in between the hood n fender close hood and drive . Once heated up come back to driveway shut off car . During all the shut down noises do the led lite up . For a few seconds to fill the silver tank .? Pay attention . That's it . Now won't run again until car cools enough to need a boost to quickly heat car up . Like tomorrow. unless you in the low 50 or better !
  3. SaLKar
    Houston
    Thanks for your reply. I understand the pump only works on startup or shut down to pump the hot coolant in and out of the storage tank.
    So the one way (in my understanding) to check the pump is to use a pin or a jumper to activate the pump which most people do when bleeding air out of the coolant lines.
    Once the relay pins are jumped, the pump is supposed to work and I have done so successfully on other cars.
    The problem is the relay in the relay box directly above, the engine is not getting any power. That's what I'm trying to troubleshoot.
    It'd be great if someone can point me in the right direction. I think at this point a schematic diagram of the pump circuit would also help as I can use that to try to troubleshoot the issue although I'm not very skilled at troubleshooting electrical problem So any help would be greatly appreciated.
  4. Tombukt2
    13,836
    2,512
    Durham NC
    I can't generally post pictures here but I have the whole electrical manual for gen2 2nd edition 06 09. It's a separate couple hundred pages . And you have no fuses or those fusible links and what have you ,? I've never jumped the pump in my life to bleed air out of the lines personally I've had like 7 to 10 of these things . But I've read of people doing so
  5. SaLKar
    Houston
    Thanks again for updating.
    The problem is solved. There's a 10A fuse In the engine bay fuse box marked *1 whose picture I'm going to attach. That fuse is somehow related to the pump I'm talking about. That fuse was blown. Once I replaced the fuse I was able to operate the pump by jumping the terminals I was was talking about earlier. Thanks for all your help. Hopefully this helps someone else resolve this issue.
  6. Tombukt2
    13,836
    2,512
    Durham NC
    Usually most electrical problems or something very simple like a fuse blown we always look their first . Then it's rodent chewing and that sort of carrying on on wires
  7. ChapmanF
    18,985
    Finding a fuse blown only tells you that you have an electrical problem, not what the electrical problem is....
  8. SaLKar
    Houston
    Fuse is where I always look first, but in this case the name of the fuse and its location was a mystery. Anyway, that's why I attached the picture. So anyone facing the same problem may have an easier time
  9. SaLKar
    Houston
    I agree Years ago I remember you telling the same to another member and I appreciate that. Been lurking around these forums for like 10-15 years and it's great to have two of the senior members respond to my question. Shout out to Patrick Wong as well.
