Code P261B pump failure but the pump still turns on
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by zoeboi954, Jul 29, 2017.
  1. zoeboi954
    zoeboi954 Junior Member
    83
    22
    Couple of nights ago my engine stop on me. I started up a minute later it turn off on me. This happened 3 times the 4th time it started up and I was able to drive home without it shutting off. The next day i drove around the block to see what will happen, and it did shut off again. I hooked it up to the techstream it read P261B. So I order a new waterpump. when I was removing the old one I decided to test it out before I unplugged. The water pump turn on fine which made me wonder if I was changing the wrong thing.... my thought is since I was able to drive home maybe it only work sometimes... what yall input
    Link to video
    Ben Schneider likes this.
  2. zoeboi954
    83
    22
    I figured out the problem. Does anybody know where I can get a water pump wire harness from... I'm going to call toyota tomorrow to see
    SFO, Prius6058 and Ben Schneider like this.
  3. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Do you have a junk yard nearby? I'd call around if Toyota can't get you just the connector with wires and terminals attached. Also check eBay, car-part.com, and craigslist.
    When soldering into your harness use heatshrink tubing so that the copper doesn't corrode.
    Pixel XL ?
  4. zoeboi954
    83
    22
    i pray for the day a prius show up at a junkyard near me... but im checking craiglist now to see if i can find one. i'm thinking about seeing if can get the whole wiring harness so i dont have to solder, but if i do i got plenty of heat shrink and solder just got a crappy soldering iron
  5. afradette
    afradette Junior Member
    Ashford, Connecticut
    Godaca LLC has all kinds of connectors. I just ordered my NSS connector from them with pins and WP inserts
    SFO and PriFi like this.
  6. Prius_Mat
    Prius_Mat New Member
    SC
  7. Sonic_TH
    Sonic_TH Active Member
    575
    96
    Puerto Rico
    2016 Prius c
    So how did you ended up fixing this?
    SFO likes this.
