code U0293
Discussion in 'Newbie Forum' started by stevejenks, Sep 22, 2017.
  1. stevejenks
    stevejenks New Member
    kekaha hi
    can anybody tell me what code U0293 is it is the only code coming up on my 2004 Toyota prius still will not run
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    everything I see in my manual says a U0293 is a network/loss of communication problem
    52,785
    what are you reading it with?
  4. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    Steve,
    Have you performed or has anyone else performed any work on the car recently? Any chance a wire was left disconnected or not fully plugged in somewhere? I tried searching for any other posts you may have made, but all I get is errors.
  5. stevejenks
    kekaha hi
    i have a very basic code reader i need a more expensive one ,
  6. stevejenks
    kekaha hi
    Is their a way to reboot the system i guess the ECM ,,
  7. bisco
    52,785
    disconnect the 12v negative for a minute. get a mini vci off amazon for thirty bucks, you need a compatible laptop though.
  8. stevejenks
    kekaha hi
    i have checked every wire every fuse every sensor on the car 10 times already the car should be running like a champ , i do believe
    the Computer stopped connecting to the Ignition i am looking for a Flah2 reprogramer now ,
  9. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
