Codes P0031 P0136 P0456 P3190
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by GreenBeanMike, Mar 9, 2022.
  1. GreenBeanMike
    GreenBeanMike New Member
    South Carolina
    Hello Everyone,
    I have a 2010 Prius with 166K miles on it. I recently got the triangle and replaced both the HV and 12V batteries.
    I am now getting the following errors: P0031, P0136, P0456, P3190, P0A80, U029AP0A0F
    I have replaced the upstream O2 sensor and the cleaned the MAF, cleared the codes with Dr. Prius and still am getting the check engine codes.
    Any ideas or assistance would be appreciated. Thank you
  2. ChapmanF
    15,825
    What codes did you have the first time the triangle came up? Were they the reason you replaced both batteries?
  3. GreenBeanMike
    South Carolina
    Hi There, the original code was a 3190. I replaced both batteries d/t a post I found indicating that a weak 12v can cause all sorts of havoc
  4. ChapmanF
    15,825
    Yes, there are a lot of posts that say that. At least you have new batteries now.
    P3190 is set if the ECM is only able to get less than 20% of the requested torque from the engine.
