Codes p0a7a, p0a94 (yep, when it rains it pours)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by MrPete, Aug 22, 2022.
  1. MrPete
    MrPete Active Member
    507
    194
    Colorado, USA
    Our adventures continue
    Gen3 Prius, over 2k miles into a 3.2k trip, out in the middle of rural Idaho.
    * Repaired HV battery is working great
    * Patched up HG leak, working vreat
    * Oil consumption, not too bad.
    Then, 20 miles from our overnight (Burley ID), the warning lights lit up. The car is clearly not happy.
    Codes p0a7a and p0a94 seem to indicate a serious Inverter problem.
    Good news: I drove at 45mph to our place. No HV motor.
    Bad news: clearing codes doesn't do anything.
    Research leads to questions:
    * Apparently there was a recall/tsb on this. Any chance Toyota would honor it on a 206k mile 2011?
    * Any chance this is minor or easily repaired?
    * Anyone know which dealers ins ID or N UT are good (or any other Toyota specialist)?
    * Could it be safe to drive 750 miles at 45mph w/o the Inverter? (avoiding freeways)
    * What is the gas mileage of a prius running on gasoline only?
    Any questions I *should* be asking? (yes, seriously considering how to just replace this ride )
  2. ToyXW
    ToyXW Active Member
    153
    149
    Sacramento
    Remy McCarthy, et al., v. Toyota Motor Corp., et al.
    Good news: The inverter warranty is extended to 20 years, unlimited miles.
    Bad news: the settlement isn't expected to go into effect unti January 2023.
    If Toyota doesn't replace it right now, you can get an inverter for a couple hundred dollars from a junkyard and replace it in an hour or two. Lots of videos online... I would not drive a fried inverter 750 miles across the continental divide, but I also wouldn't have embarked on a 2000 mile road trip with a blown head gasket and sticky rings so your tolerance for high probably catastrophic breakdowns exceeds my own.
    #2 ToyXW, Aug 23, 2022
    MrPete likes this.
  3. MrPete
    507
    194
    Colorado, USA
    That is awesome news. Time to make some calls...
  4. MrPete
    507
    194
    Colorado, USA
    Wowwww. Never heard of non-recall agreements this good!
    • Toyota already has extended the inverter warranty to 15 years/unlimited miles. In Jan it should shift to 20 years.
    • It includes some towing and rental if needed. The dealer thinks only $35 a day, nice but 1/3 of cheap rental cost...
    • The hard part: no dealer is allowed to stock spare ($4500?!) inverters. Each one approved and released. Overnight delivery but 2-3 days overall.
    So, we rented a cheap car to finish the drive home (I have a crucial non-moveable appt), and then my sweetie will drive back to pick up our car.
    Too funny: got a great rental discount, then the agent said "I'm so sorry, that rental is not driveable. Would it be OK if I substitute a 2022 Prius at no charge?"
    Hmmm... 1500 miles of driving, 50 mpg or 30 mpg...."yes Ma'am that would be fine."
    Too bad Avis won't let us keep it. LOL
    ToyXW likes this.
  5. rjparker
    rjparker Tu Humilde Sirviente
    11,054
    6,926
    Texas Hill Country
    Had my inverter changed many years ago. There was a software fix Toyota pushed back then but apparently it was not good enough. At least you were lucky enough to keep limp home mode which means it did not completely go out like mine did.
    You are pushing your luck. Still have the hg issue. That sealer won't last forever. Your sweetie may file for divorce if it goes out on the way back.
  6. MrPete
    507
    194
    Colorado, USA
    They claim even with a complete inverter failure, it can go 60mph.
    I suspect the reality is more like:
    * mostly depends on HV SOC (state of charge) at time of failure.
    * from experience, it appears the regen braking can charge the HV a bit, even with dead inverter.
    When inverter died we were at 54% SOC. 60 miles later, 26%.
    Is the inverter part of keeping the 12v charged?
  7. rjparker
    11,054
    6,926
    Texas Hill Country
    Not true. Most of the time you can't even Ready the car.
  8. MrPete
    507
    194
    Colorado, USA
    Interesting!
    This is from the new settlement agreement:
    "Toyota confirmed that the Recall Software ensures that Subject Vehicles will enter fail-safe mode in the event of an IPM or Inverter malfunction or failure, and that Toyota is aware of no incident in which a Subject Vehicle equipped with the Recall Software was unable to travel ~60 miles per hour after entering fail-safe mode."
  9. rjparker
    11,054
    6,926
    Texas Hill Country
    Failed on me. That is written by the other side's lawyers.
    MrPete likes this.
  10. MrPete
    507
    194
    Colorado, USA
    I assume you had the software fix... If so, the class action people would probably like your story
  11. rjparker
    11,054
    6,926
    Texas Hill Country
    I had the software fix and then it failed later. Mine was an early event, many occurred later.
  12. MrPete
    507
    194
    Colorado, USA
    They have done several SW fix recalls (none of them solved the real problem of course.)
    We are now headed back to pick up our fully repaired Prius.
    * Toyota decided to have the dealer repair specific parts rather than replace the whole inverter. Of course this added delay, increasing my rental time/cost... Now over $900.
    * I asked the dealer if there is a national number could call to discuss my growing costs, and see about reimbursement. He gave me a number...
    * I ended up speaking with a Sr manager. He could not *guarantee* they would cover me, it expressed his understanding of my predicament, and said "Pete (you aren't trying to rip us off); just do what you need to do, and submit your expenses. I am sure we will take good care of you."
    At this point I can't really expect more than that. Will report on the final outcome.
  13. MrPete
    507
    194
    Colorado, USA
    BTW, my "fail safe mode" experience: yep, the Prius could go 65mph...
    ...downhill.
    From a stop, uphill? Maybe 5-10mph while flooring it. It took several minutes to get anywhere close to a reasonable speed. I would NOT want to drive in failsafe mode in the Western Rockies.
  14. MrPete
    507
    194
    Colorado, USA
    Let me wrap up this story (potentially to be augmented if the class action produces any reimbursement for us.)
    Ultimately, even being very careful on costs, and paying $0 for the actual inverter repair...
    • Toyota's delays to minimize their parts cost ended costing several days of time, during which we were paying for the rental car
    • We ended up paying for nine days of rental, a few days of motel, and some meals, beyond what we would have paid anyway for our in-progress trip. Over $1k total.
    • Toyota's final response: we're sorry, we have no program that can reimburse your costs.
    • The upcoming class action resolution apparently doesn't allow for more than a few hundred dollars in other costs. They never considered the case of people having an inverter fail while in the middle of a trip.
    So we do have a repaired inverter. We're also out over $1k for now, and hoping to recover a fraction of that. Not happy.
  15. ASRDogman
    ASRDogman Senior Member
    8,055
    4,083
    Well, think of what the inverter repair would cost... PLUS the cost of a rental car, hotel, food, etc.
    So, if you look at it like it was ONLY $1000 to have the inverter repaired, it's pretty inexpensive.
    You could take them to small claims court to try to get your money back from that.
    Or hire a lawyer, unless you find one that will take your case for nothing, and try to get your money
    back from that, and emotional stress.....
    2010moneypit? likes this.
  16. rjparker
    11,054
    6,926
    Texas Hill Country
    Exactly.
    That is essentially what happened to my wife and I when the inverter suddenly died a 100 miles away from home. On a late Sunday evening with no shops or nearby rental cars. A failure with absolutely no warning and no limp home mode.
    Had to wait an hour for a tow truck. Another 30 minutes for a taxi then 45 minutes at the airport picking up a rental car. Finally driving a hundred miles home. Plus dealing with a shop far from home. Four days later it was ready but the out of pocket expenses were substantial.
    Inverter firmware had been updated two days after it was available. All of which is why I always warn people about gen3 issues. Even though Toyota covers the inverter cost, it is still one of the biggest reliability risks and one of their biggest flaws.
    #16 rjparker, Jan 13, 2023
  17. MrPete
    507
    194
    Colorado, USA
    In that sense, I'm grateful that we basically DID have a "limp" mode. Drove to our intended motel. Next morning drove 40 miles back to the dealership in a bigger town. And a friendly customer in the waiting area gave us a ride to the car rental area at the airport!
    AFAIK, we now have an improved, more reliable inverter. (If not, I had better not bother replacing the engine next month!)
