Codes P3000 and P3009 with Hybrid Warning Light
Discussion in 'Generation 1 Prius Discussion' started by SteamRollerCC, Nov 24, 2012.
  1. SteamRollerCC
    SteamRollerCC Junior Member
    29
    2002 Prius
    Some time ago I got a Hybrid Warning Light, which went away in abut 3 days:
    Thread 2002 Prius "Hybrid System Warning Light" just came on | PriusChat
    Recently, about 3 months later, I the same warning light again. This time, I took it to the Toyota Dealer and got codes "P3000" and "P3009". Here's what they wrote down on each one:
    P3000: Battery Control System
    P3009: Leak Detected
    My car runs fine still, but I feel the engine working more and the battery working less... also a decrease in MPG. What would you guys suggest I do? They recommended replacing the Hybrid battery for $3500, but what's the best options to take?
    Thanks in advance!
  2. bwilson4web
    16,523
    This is consistent with electrolyte leak that causes a ground fault. High humidity an cause the path to become more conductive. But I would also wonder about the module balance. But in the world of problems, this is one I would plan on by monitoring:
    • min/max module voltages - looking for a greater than 0.3 V difference
    • min/max module ID - looking to see if it has fixed on one weak module or still varies
    • four temperatures - looking for a hot area, 3C or greater
    Then start looking at different different pack options:
    1. Toyota - obvious choice, still older modules
    2. Rebuilder - ReInVolt and may be others, look for a warranty
    3. Rebuild it yourself - study technical aspects and if you have place to do the work and time
      1. minimal - remove battery, measure voltages, remove and clean bus bars, identify leaking terminals, clean electrolyte, reassemble, and reinstall . . . wait for next failure
      2. modest - attempt to replace failing modules, same as above but use old-style replacement modules
      3. full - get 38, NHW20 modules, measure capacity and match charge
    GOOD LUCK!
  3. Patrick Wong
    18,210
    6,517
    Also note that if DTC P3009 is the major issue, you can continue to drive the car indefinitely without implementing any repair.
    bwilson4web likes this.
  4. SteamRollerCC
    29
    2002 Prius
    Thanks guys!
    Ever since I got that first warning light... I felt my MPG going down and engine working more! I might check out re-involt for a remanufactured battery. I live in California near LA... Can re-involt ship and have place around here to do the labor?
  5. NinnJinn
    NinnJinn Member
    276
    Indiana
    Im sure they could, but if you are somewhat handy and have a friend, why not save the labor costs and do the swap yourself?
  6. SteamRollerCC
    29
    2002 Prius
    I've been doing some research and even called different hybrid mechanics that had articles on the P3009 error code on a classic prius.
    I seems that P3009 is a pretty complicated error code. The leak could be caused not just by the battery, but the ECU, power cables or the transaxle. When I drive my prius, it drives very normal... Though i feel the engine working more...
    I also forgot to mention that the Toyota mechanic wanted me to pay more to do some further diagnostic on the problem. Should I take it for the further diagnostic?
    I also found this
    Luscious Garage | Blog | Gen 1 Prius Transmission Repair, P3009, P3120, P3125
  7. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    735
    Boulder Hybids, Boulder, CO
    Don't take the dealers word that 3009 means Hybrid battery is bad. I've had customers spend $4000+ at dealer for new battery then have dealer tell them "sorry, your car also needs a new transaxle". Ideally you can find a good independent shop that knows Gen1's and they can properly diagnosis the car for you. Best thing to do is have tech unhook the "big orange wires" from MG2 and MG2 inside the invertor and "megg them out". If they don't know what "megg them out" means take the car somewhere else.
    Scott quinn and SFO like this.
  8. usnavystgc
    3,159
    990
    Tucson, AZ
  9. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    776
    363
    How is it you're in LA and didn't call me? The symptoms you are describing are more like this link. There is a good chance you can squeeze some more life out of your battery. I have fixed these before. Feel free to give me a call.
  10. guggenheim
    guggenheim New Member
    2002 Prius
    I'm curious how you resolved your issue because I've gotten the exact same error codes for my 2002 Prius. Let me know what worked. Thanks!
  11. SteamRollerCC
    29
    2002 Prius
    Its been a crazy ride... I gave a call to Avi from Avi's Advanced Automotive and he fixed my problem!! (y)
    Here's the story, I gave a call to Avi to talk about the P3000 and P3009. He gave me the same information about the actual battery residue possibly being the problem as the link he posted on here. Thought since the P3009 code could involve many parts of the car, he'd have to reset the codes and run a simple startup test to see where the leak is at. I drove where I live in Rialto, CA all the way to Tujunga (a little over an hour) to have my car checked out by Avi. I only had Saturday off to come... Avi agreed to come in anyway on his day off. Once he checked it, he confired it was the battery. When he phyiscally got to the battery inside my car, his predictions were right! The battery had residue all over the cells! Avi cleaned the residue off the cells and then we tested the car again. Surprisingly... the error code came back after 10 minues on "ready" mode. Then Avi took the extra step to clean each of the 38 modules individually! After that... the error code came back again. Avi then measured the volt of each module. Surprisingly, he found there was a volt mesurment on the out rim of the battery. There was a deep leak sending voltage on the outer rim... we even both saw a spark come out with the case. Then it was determined that the whole battery needed to be replaced sometime down the line. The whole visit took 9 hours to finally narrow down the conclusion. Avi worked overtime on his day off... Afterwards, the car drove fine and much better than it did!
    My car is a 2002 Prius and with about 90,000 miles. I wanted a new battery and I called Avi, he kept insisting to call Toytoa saying that I might be under warranty to replace the battery. I got very close to being covered... but I was 2 years short of the coverage. Avi then agreed to replace the battery and minus the labor I paid Avi for cleaning the battery. I ended up only playing $2100 for all the labor and replcement with the brand new battery! Afterward, no problems and my car is running ridiculously great! Almost brand new!!
    It's been one crazy past few months with this error code! Thanks to Avi, its finally fixed!
    usnavystgc and bwilson4web like this.
  12. Zoe
    Zoe New Member
    2002 Prius
  13. Zoe
    Zoe New Member
    2002 Prius
    Patrick - are you saying that with the P3009 code appearing that no repair is necessary? toyota is telling me I need a new HV battery. Car starts and drives fine except for the warning light. It is in the Toyota shop awaiting battery replacement. If I do not replace HV battery won't the "display of lights" comtinue? As far as I know the lights still come on when the car is started. But it starts and seems to drive fine. Thanks for any added comments or suggestions. The work to replace battery is scheduled to take place soon.
  14. Patrick Wong
    18,210
    6,517
    Zoe, your own observation is that the car can be driven without a problem. Therefore I suggest you should be slow to take action given the $3,000 repair bill and the low market value of a 2002 Prius... It doesn't make sense to put so much repair money into a car whose market value is so low.
    DTC P3009 points to a safety issue, where one side of the traction battery has a high voltage ground fault. This is typically because electrolyte from a battery module is leaking to the metal traction battery case, providing a path for the high voltage to leak to ground.
    If you are willing to ignore the ground fault, you can continue to drive the car without replacing the battery at this time. The leak may get worse over time and you may eventually have to replace the battery, but at least you can defer the repair for now.
    The trade off is accepting the ground fault safety issue vs. paying the four-digit repair bill. You'll need to decide what makes sense to you.
    Although Classic Prius with this problem can be driven, 2G Prius with the same problem have logic that prevents the car from being restarted after the DTC is logged. Hence some owners have decided to disconnect and reconnect the 12V battery before each start, to clear the logged DTC from the traction battery ECU. Obviously they also are bearing the risk of the high voltage ground fault.
    SFO likes this.
  15. bwilson4web
    16,523
    Hi Zoe,
    Perhaps you might let us know the City and State you live in. There are independent Prius shops who can give a second opinion and handle alternative solutions across the country from coast-to-coast and North to South. Knowing where you live makes it easy to identify known, credible, independent shops. For example, these folks offer hybrid vehicle training and can recommend some of the folks they have trained:
    Independent Hybrid/EV Repair & Service Shop Locator
    Now many of us can handle our own maintenance so we're not limited to the Toyota dealer. Our own labor and we find these cars fascinating, working on them is not a big deal. It is a hobby as well as transportation. But for someone non-technical, like my wife of 35 years, self-maintenance is not an option.
    BTW, a Prius-aware scanner is key to being an informed owner. It allows you to see the health of not only the traction battery but other subsystems in the car. It is a way to make an informed decision.
  16. ChapmanF
    18,997
    I was surprised to notice last night there's an actual impedance figure in the manual. Not sure why that surprised me, guess it just hadn't jumped off the page at me before, but there it is on p. DI-331 (2001 edition). Seems the threshold to trigger a P3009 is a path to ground of 100 kΩ or less. (Of course, that could also be the aggregate of two or more different paths.)
    Using a digital meter with typical impedance 100 times as high, I wonder how practical it could be to just measure the case voltage relative to both ends of the battery and get a pretty good guess which module to look at, if only one has the uncorrected 'deep' leak. More complicated if you assume n modules might be involved, but for lowish n there might still be a practical technique involving more than two measurements.
    -Chap
    usnavystgc likes this.
  17. bwilson4web
    16,523
    The relays might be open. It might be interesting to check the Orange safety plug contacts too. Just wondering if they might be hot or whether they may also be relay protected?
  18. ChapmanF
    18,997
    I was picturing the test with the cover off, so you'd have access inside at the system main relay. Yes, it would ordinarily be open and prevent you doing such a test from outside. The safety plug isn't on a relay; each contact will give you a connection to the middle module of one half of the battery. You could measure voltage from case to one of those contacts and narrow your search to half the battery. The system main relay again would prevent direct measurement at the other end of the half-stack, but still you could measure case-to-safety-plug voltage and divide by 7.2 to get a pretty good idea where the culprit is.
    In the case of plural culprits it wouldn't be so simple. I haven't sat down to think clearly about it yet, but it might be if you had the cover off and made multiple measurements you could get a system of equations to solve. I'm also thinking that the simple case of one culprit at a time must be common, because as soon as you have more than one you'll have a circuit, with charge loss and heating and probably more symptoms than just a P3009.
    -Chap
  19. Zoe
    Zoe New Member
    2002 Prius
    Thank you, Bob. The day the warning lights went on it was over 90 degrees and humid. No problems with weather before or after as it is generally mild, even cool, where I am, mostly in the mid 70s through summer. I have called Toyota with suggestions to try (from this board) prior to installing the new HV battery, but no calls back. Hopefully they are trying some of the simple things first to see if the problem resolves. I was told the Prius tech is "looking at it further" yesterday. Thanks again.
  20. ChapmanF
    18,997
    ... where I wrote "middle module of one half of the battery" ... of course I meant the module at one end of that half ... just the end that's in the middle of the case ... if that makes it all clearer. :rolleyes:
    -Chap
