Coil Pack Failure?
Discussion in 'Gen 3 Prius Technical Discussion' started by deis, Jan 21, 2024.
Tags:
  1. deis
    deis Junior Member
    63
    UK
    Excel
    Hi all
    How do coil packs fail? I've done a resistance and diode check (both ways) across all combinations of the pinouts of all 4 coil packs and I'd say there is no real discrepancies in the values I read.
    If my understanding is right on how the coil packs work, the only other way they can fail is due to the secondary coil, which I believe is impossible to check?
    I remember that article which was posted in the spark plug thread I opened a few days ago, and this might well resort to testing with an oscilloscope. Where is the Crankshaft sensor anyway?
    So before that and other than physically checking for a spark against the engine body, at which point one could suspect even if there is a visible spark, it doesn't mean it'll ignite properly (weak spark?).
    What other checks can I do before I resort to buying a new coil pack? How likely is it to be more than one coil pack? What about used coil packs?
    As always, I look forward to any advice.
    Thanks, Deian
  2. Mendel Leisk
    42,352
    Why do you suspect defective coils; any symptoms or codes?
    What’s the miles?
  3. deis
    deis Junior Member
    63
    UK
    Excel
    Hi Mendel, thanks for replying...
    107k miles.
    As you've probably followed so far, I have my transaxle damper plate vibrating and making noise.
    It runs fine. Other than a juddery start off the line, and what seems like 'under load' rattle while charging at standstill. So rather than replacing the transaxle damper plate, I should really find the root cause, which i suspect is a misfire, I think it's quite obvious, as it can be rough on acceleration as the engine fires up wanting to help the motors.
    I am sure the gearbox itself is fine.
    I'm sure the root cause is a misfire. And I've already changed the plugs. But there are no fault codes, ever.
    So next thing to check is the coil packs, so far they check out, so I'm looking for more experienced input.
    Unless there's a more physical/mechanical issue. I did remove the intake manifold last summer, and soon after (weeks/month) this started happening, it came, then went, and came again and stayed until now.
    Could it be an intake/vacuum issue? Just looking to remove the coil packs from the equation first.
    I changed the engine oil and filters this weekend, if I can resolve this, I'll change the transaxle fluid.
    Thanks
  4. Leadfoot J. McCoalroller
    8,290
    7,804
    Pennsylvania
    2018 Prius c
    Swap coil packs with another cylinder and see if your misfire follows.
    I've never had more than one fail at once, but sometimes within a few months of each other. Used ones are a minor gamble, all depends on the price really.
    I've learned through trial and error that there are many low grade counterfeit ones on the market, sold in convincing packaging with all the right brand names and marks. Amazon and eBay are full of counterfeits.
    Also learned that the counterfeits work fine, at first. But they tend to fail after a year or two instead of 10-20 like with the real deal ones.
    CR94 and Danno5060 like this.
  5. Mendel Leisk
    42,352
    When you removed the intake manifold did you clean it, in particular the small diameter (4~5 mm) EGR passages, one at each intake port?
    Also, did you follow through on cleaning the EGR components? (you had a previous thread, prepping to do that)
    your miles reported in previous but recent thread, are around 108,000? That’s somewhat early for head gasket to fail. If you haven’t done a full EGR clean I would, soon.
    Also keep an eye on engine coolant level in the reservoir, and consider doing (or getting done) boroscope inspection and/or leak down test.
    Regarding the coils, there’s no codes, and your main reason for suspecting them is you’re experiencing occasional rough running. May be a red herring.
  6. deis
    deis Junior Member
    63
    UK
    Excel
    I'll elaborate a bit more on the conditions.
    I wouldn't say it's occasional rough running. It's rough when taking off hard or when it's charging.
    I can feel the misfire/roughness. But I also wonder why no codes come up.
    There are certain conditions where the misfiring happens more.
    It's VERY rattly (the transaxle damper because of engine load vs misfire) when moving slowly through traffic when it's charging (with two bars).
    It's NOT rough when it starts up from cold. And it'll be less 'misfiery' when the engine needs to kick in, but it will eventually get more likely to be rougher on the off and rattle on deceleration.
    Basically. If there is the need to be gentle with the engine, such as a smooth transition of power from motor only to motor+engine or I'm off the accelerator pedal but not completely (unloaded), it'll rattle. I basically need to accelerate or decelerate to avoid it in public. So to avoid this I have it in Power mode all the time.
    Regarding the EGR clean I did last year, I did everything but the EGR cooler, the little holes in the intake were clear before, and clearer after. That's not to say I couldn't have done a better job. But I will tackle an EGR check again, and definitely free up any gunk inside the EGR cooler. But I 'felt' and concluded it the EGR cooler was 'ok'.
    Thinking back, I wonder if there is something I didn't put on properly, or torque up properly (as much as can be torqued when tacking the tight spaces around the EGR assembly and pipework. The car worked fine after putting everything back together. But this phenomena happened a few weeks after, and it came, and then went.
    One thing I did do was spot this little motorised flap on the exhaust pipe after the first catalytic converter, I'm not sure what it does exactly, but I believe it's something to do with keeping the exhaust back pressure even to make sure the temperatures/noise/energy is conserved? I believe it's a thing on the UK/European cars? I sprayed WD40 on that mechanism and it 'seemed' to help a bit, so maybe it's that?
    Again, no fault codes.
    I appreciate all the help guys, what an awesome place to be.
  7. Tombukt2
    Tombukt2 Senior Member
    13,864
    2,519
    Durham NC
    This is kind of exactly what's going on with the 13 persona right now with the description you posted of how your car is running The torque plate business and all that I'm about to get the transmission out and have a look and I have my old original transmission on standby as well as two torque plates and the flywheel that the torque plate bounce on I'm banking that either The plastic pieces in the springs have been knocked out of one or two of these springs The flywheel portion the six or five bolts or whatever something's loose possibly I have no idea but I will say on the video that I have posted on wherever it is I can send the link it's on my YouTube I think under my same name here You see my engine running absolutely stupidly smooth while the racket between the engine and the transmission where your eyes immediately focus to is just wild n out.. I wish I could find a mess I have aftermarket junkie coil packs as most people here might call them and they seem to be spot on the plugs and all the ignition seem to be firing absolutely perfectly You can see it in the video If it was an older style car and I was lifting the plug wires off of the plugs you would hear the drop and all the funny business like you did back in the day of course doing that to this vehicle You might damage the coils If I thought for a minute I had bad coils there are aftermarket very nice coil over plug units made by some Asian company they work out to be I don't know what about $44 a pop they're like billet aluminum and so on and so forth have pretty good warranty on them they're called out for our cars and many others Hondas Toyotas some GM maybe even two they've sent me advertisements to my business address several times I think they're red I can't think of the name they look like they do a good job and maybe doing a good business and then there are others I wouldn't think coilover plug technology is anything we need to really super worry about needing any kind of super high quality of course you don't want junk so far the aftermarket coil set that I bought for my Gen 3 which look very much like the factories seem to be working fine have no problems and the wells that they sit in are clean but I have the same clunking business you do right now and it's been this way for a few months we've not been driving the car I'm worried about that clunking and clanking rattling everything to death We have plenty of cars so that's not a problem. But my next move is to get the transmission out and have a look behind it maybe put the transmission that was originally in the car which was working flawless when the engine blew up We will see. And good luck. We will phase out our Gen 3's as they fall by the wayside and we're back to four generation twos and may have one or two more any minute
  8. Leadfoot J. McCoalroller
    8,290
    7,804
    Pennsylvania
    2018 Prius c
    Every engine control unit has its own thresholds for misfires, but they can all have misfires for a while without actually logging a P030X code. At some point it gets worse and then codes are trapped.
    Until that happens, you kind of have to go by older methods.
    One such: selectively unplug one coil at a time, and do a test run. The engine should feel like it is running on three cylinders with the bad coil disconnected. It will run worse than on three cylinders (or perhaps not at all) when one of the good coils is disconnected.
    Look for carbon tracking. In many cases the failure mode is high voltage leaking. The spark is occurring, but it's happening between the coil and the inner wall of the tube it lives in rather than at the plug gap. Sometimes this leaves observable burns and carbon dust. I haven't had much luck with this method, but others do okay.
    That's a heat harvester. Keeps the engine coolant warm by flowing exhaust over it. Faster warm-ups, so the engine burns less fuel getting into its most fuel-efficient temperatures. Good to keep it happy.
  9. deis
    deis Junior Member
    63
    UK
    Excel
    What does the ECU check for in order to find the misfire? Is it a feedback value from the coilpacks or some kind of calculation? Is this a value I can find on my OBD2 reader and Torque Pro app?
    You said in an earlier reply to move the coilpack to another cylinder, and see if the problem follows, the only problem I see with that is that I don't even know what cylinder it's happening to, and even if I move a random coil pack to another cylinder wouldn't the issue be the same? The other alternative is to buy one genuine second hand one and swap each with that one, assuming it works better than my possibly dodgy one?
  10. Leadfoot J. McCoalroller
    8,290
    7,804
    Pennsylvania
    2018 Prius c
    I understand it to be a running measurement of crankshaft position. A Prius is well-instrumented to know exactly where the crankshaft is within its circle, and if it suddenly seems to be behind schedule (due to misfire) the ECU can mark the event as a misfire if it is severe enough. But I couldn't tell you what the tolerance is or how to read it from your diagnostic tool.
    You're correct, swapping two coils is useful if you already have a suspect meaning a misfire severe enough to leave a code, and considerably less so if you don't. Swapping in a 5th of any origin will eventually help you puzzle it out.
  11. ASRDogman
    ASRDogman Senior Member
    8,066
    4,089
    You need a code reader to tell you where the missfire is first.
    If it's #1, and switch #1 and 4, and clear the codes and the missfire moves to #4, then you know it's that coil.
  12. deis
    deis Junior Member
    63
    UK
    Excel
    Well thats the problem. There is no fault code.
    However, some fuel cleaner feels like its having an effect. Went out just now, little lumpy on the off (cold), but it felt smoother at times, all in all, slightly better? I don't know. Could the injectors be partially blocked or something?
  13. ASRDogman
    8,066
    4,089
    Have you pulled the plugs?
    Have you check your fuel quality? Maybe you got some bad fuel.
    Take a sample and put it in a clean clear jar. Wait 5-10 minutes and see what
    it looks like.
    It is possible you have a bad connection at the packs. If they injectors are clogged,
    they likely won't be producing a mist pattern. And if the droplets are too large they
    don't burn fully or quickly. Which could cause a hessitation. And might not show
    as a missfire because the coil and plug are firing correctly.
  14. deis
    deis Junior Member
    63
    UK
    Excel
    I'll let the fuel cleaner do its work more. And maybe pop another bottle in.
    I doubt it's dirty fuel, as this has been going on for a few months now and I've had fuel from many different places. If there's a difference after the second bottle of Fuel Cleaner I might get my injectors cleaned.
    I wonder if it's the E10 fuel we have to use here in the UK. I don't think so, but some car have some effects due to the level of Ethanol in the petrol. So now standard 95 RON fuel has 10% ethanol (government choice) comapred to the the 5% it used to be. If you want 5% ethanol you're paying more than £0.10p a litre more for that and they only come at RON 97 or 99. I doubt it's that though.
    ASRDogman likes this.
  15. PriusCamper
    PriusCamper Senior Member
    13,467
    5,434
    Pacific Northwest, USA
    I thought it was crazy to blame ignition coils for engine problems for decades... But have fixed Prius by replacing ignition coils, so it really is a thing. But kind of embarrassing that Toyota can't build such a simple electrical circuit without such a high failure rate.
  16. Mr. F
    Mr. F Active Member
    390
    264
    Washington
    To see if there actually are any misfires, hook up Techstream, put the vehicle in maintenance mode, and switch to Engine and ECT > Live Data List. Monitor the misfire counts for each of the cylinders. Anything more than 0 is an anomaly, and then you can swap components between cylinders to see if anything changes.
    #16 Mr. F, Jan 21, 2024
  17. Tombukt2
    13,864
    2,519
    Durham NC
    I look at it like I'm coming up at 300K on three of these cars win some misfires start to develop some of mine I have NGK coils in place of the denso units on same engine so they've been worked on and dealt with before now while I have the car. When the misses start to show up I'll just get new coil sets put in new plugs and start there nowadays there's some really nice coilover plug manufacturers that seemingly do good work so it's probably just worth it to do that they're not that expensive The ones I bought for the Gen 3 were like $88 for the set and I was extremely skeptical but when they came the packaging was decent The material and workmanship looks good I can't see the circuit inside. And they've worked flawlessly for about 2 years so I'm okay with it.
  18. ChapmanF
    19,027
    The primary is also pretty much impossible to check, by any simple 'resistance' or 'diode' check. No connector pins expose the coil directly; you're trying to make those measurements across what turns out to be a more complicated electronic circuit really.
  19. PriusCamper
    13,467
    5,434
    Do you know why they went from a single coil to 4 coils? The single coil systems of all my old cars seemed bulletproof? Why do these weaker coil over plugs fail so often?
    Tombukt2 likes this.
  20. Tombukt2
    13,864
    2,519
    Durham NC
    Yes but then you have to have a mechanical distributor well generally speaking or you have a four coil pack mounted to the side of the motor and four wires running up to the extensions and to the plugs I guess is another way to do it general motors. But generally these coilover plugs were talking about these it well over $170,000 mi usually and usually really over 200 for the most part or right in that range I buy cars a lot and see coils have been replaced NGK is a popular brand so I have the gray NGKs on one or two cylinders and the black denzo on the other two now whether the change was really needed or not I have no way of knowing a lot of these cars people just pull the parts cannon and start firing which can be problematic I guess but it seems the coilover has taken over and is the way to go The failure rates don't seem to be really that high they just seem to be pretty steady and it pretty high mileage when most people have long gotten out of the car because of whatever reason.
