Coil? Plug? Injector? Or bad gas?
Discussion in 'Gen 2 Prius Technical Discussion' started by FazilHussein, Mar 21, 2022.
  1. FazilHussein
    FazilHussein Member
    71
    37
    Perth, Ontario, Canada
    Folks,
    My 2005 beast (352,000 km) has finally given me some trouble.
    Heavy snow outside; started to misfire really badly. Limped it home, put some fuel stabilizer in the tank, fired it up the next day, same thing. Read the MIL; P0304, misfire cyl 4.
    Thanks to this wonderful site, I found a TSB (EG 063-05) that detailed a coil/spark plug replacement and applying sealant to the cowl to prevent water ingress. Replaced the coil, cleaned the plug, cleared the code, topped off with premium gas and off we went for another 500km.
    I'm down to two bars of gas and she starts to misfire again; I limp to the gas station, tank with regular...good to go. On the way home, more misfiring.
    So we're down to spark plug or injector. I order both, top with premium and add fuel injector clearer (STP).
    Gave her for an Italian tune up....rough, a little less rough, then smooth. Has been that way for the last week.
    So.....was it bad gas all along? Injector is going to bite me when I least expect it? Plug intermittent?
    Am confused :unsure:
    Does anyone have a similar experience?
    Much thanks,
    Faz
  2. PriusCamper
    PriusCamper Senior Member
    13,459
    5,430
    Pacific Northwest, USA
    Your oil level isn't low is it? If oil level is good try switching coils around to see if location of misfire moves with the coil or stays in same place.
  3. FazilHussein
    FazilHussein Member
    71
    37
    Hi PriusCamper,
    Checked oil; on the top dot.
    No longer misfiring; going to have to figure out how to break it again ;)
    Wondering if this is related to temp change? Has gone from -20C (I was working on it in the garage @ -10C) to +10C in two weeks; good ol' Canada.
    ~ or ~
    Cyl 4 is weak and premium gas is helping it along.
    Thanks,
    FH
    PriusCamper likes this.
    52,848
    i woner if you got some bad gas, and it got stirred up when you refueled
  5. FazilHussein
    FazilHussein Member
    71
    37
    Hi Bisco,
    Seems that way; I'm thinking due to the temp swings and ethanol I ended up with water in the gas.
    1) Misfire restarted when tank was low
    2) Cleared when I tanked
    3) Of course, being a cheap b@stard I tanked with 87 octane (that, and premium was $2.08/L)
    4) Which then sweated out some more water and exacerbated the issue.
    5) Issue cleared using 91 octane (no ethanol) and STP fuel injector cleaner.
    What I can't figure is why only cyl 4? I'd expect random misfire.
    Thanks,
    Faz
  6. bisco
    52,848
    good question. maybe it is the most worn due to mileage, and most susceptible? idk
  7. JahT
    JahT Member
    145
    77
    If your sounds like this it could just be a bad injector. I replaced coils and plugs but it didn't help my misfire on 1 and 3, but a set of refurbished injectors for $40 fixed the intermittent problem.
  8. FazilHussein
    FazilHussein Member
    71
    37
    Hi JahT,
    Yes, that was the exact noise my poor, poor 17 year old car was making :(.
    Thought it was a goner; almost broke down and bought a new Corolla (red, 6MT, sunroof....like the car...like my $30k better). :)
    I have the injector and spark plug; will take a crack at it this weekend and report back.
    Much thanks!
    Faz
    JahT likes this.
  9. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    2 things:
    One is I hope you bought an OEM Denso coil as the parts store coils are no good. That's why there half the price.
    The other thing is using your iphone take all the coils off and take a good picture of the spark plug in the well and see if you have any oil leaking into the spark plug well. That's very common too.helps to have the iphone magnifier photo app. I'm using a borescope here since i was scoping out the pistons too.
    Here's a shot of my car's spark plugs wells at 110,000 miles. You can see the oil just starting to fill the well in one photo. New factory gasket was $30 when i bought mine 3 years ago.
    It's easy to take the valve cover off and a great time to replace the pcv valve out too. Many people have busted a hole in the valve cover using the wrong wrench/technique trying to remove the pcv. Much easier if cover off.
    And you get to check the chain for wear. And also see how your engine oil is taking care of the top end.
    #9 edthefox5, Apr 7, 2022
  10. FazilHussein
    FazilHussein Member
    71
    37
    Hi Ed,
    You caught me :D I did cheap out and buy the amazon specials.
    BUT!!!
    It turned out to be the injector; once I replaced it, running normal again....zero misfires.
    Have put 3k on it since, regular gas; running like a top.
    I did replace the PVC at the same time as the plugs; thankfully did not break anything.
    Good point on the valve cover gasket; it will be part of my once over this summer.
    Thanks,
    Faz
    JahT and bisco like this.
