Cold air Intake? - Not a Joke or Noob question
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Daves09prius, Feb 11, 2012.
  1. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    For some reason the picture you posted just cleared up. Its the 2 blues.
  2. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Awesome... swinging by my local HD now 2 pick up the suggested parts... (1) brass 3/8 inch barrel and (2) small hose clamps.
  3. edthefox5
    10,096
    4,840
    Clearwater, Florida
    Its easy. Just don't cut your hands on the rad. It's a tight fit there. You can re-use the crimp clamps but I prefer a good old hose clamp.
  4. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Bought the parts from HD... cost just under $6 - will post pix up later.
  5. Daves09prius
    Daves09prius Active Member
    680
    161
    Gettysburg, PA
    Any plans on making more complete aluminum mandrel bent intakes (w/ correct MAF adapter) for those who are interested in buying?
  6. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Of course, I want to test both versions out and actually dyno them both. I just don't know if I'll get them welded up before I get my DC header on. I'd like to dyno each mod to see what the difference actually is for each and then together. Going to talk to a welder today and also trying to get in contact with a skilled welder in LA and see what I can come up with.
    Daves09prius likes this.
  7. Daves09prius
    680
    161
    Gettysburg, PA
    Awesome! I think you'll notice a lot with the header. I noticed a lot when I changed to the NISMO CAT-less header on my nissan SPEC-V, but then again that was an otto cycle engine... Please keep us updated on the intake and all the other mods you're doing! :)
  8. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    ...AAAAAAAnd it was CAT-Less :) After we heard back from ToyoTechWV and his experience with his exhaust..
    Once I add the header, I'm seriously considering cutting off the 2nd Cat as well and welding in (2) 7" round Magnaflow mufflers as resonators and calling it good. There is enough room for 2 round mufflers there in the middle of the car vs having to have one in the back like OEM. Haven't decided if I'll dump the exhaust or route it back to the rear of the car and do something like this..
    maybe more of this angle...just not chrome (blacked out).
    Just not sticking out so far - more streamline..
    or the norm..out the rear like the original..just blacked out tips.
    Slant (blacked out)
    Or Straight (blacked out)
  9. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
  10. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Got one piece welded!!
  11. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    when you get this stuff all done, you will have to drag race someone out there on the left coast to see how it goes. cool stuff you got goin', fo' sho'!
    Justdidit likes this.
  12. yangjiesheng
    yangjiesheng Junior Member
    Singapore
    hi guys,
    like to get a 90 degree reducer from ebay.
    can i know, the prius throttle size is 2.25"? that why your are using 2.25" to 2" to connect to the 2" customized maf housing?
  13. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    2004-2009 throttle body is 51mm or 2"
    My "test fit Yaris MAF housing" was 2.25 - so i had to use a reducer. My new MAF housing I had CNC'd is 2" - no need for adapter.
  14. yangjiesheng
    Singapore
  15. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Yes??
  16. yangjiesheng
    Singapore
    i custom order from kstech.biz for a 2" ID MAF housing after i read this thread. so excited so i was wondering why u chosen 2.25 reducer.
    so based on my setting, i wouldneed a 90 degree 2"-2". is it correct?
  17. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    $105 - Not bad! A bit more than I paid for mine.
    The 2.25 reducer was for the original design I had made from a Yaris intake which is 2.25" to have it fit the 2" Prius throttle I needed the reducer. Since we both now have 2" MAF housings u just need a 2" coupler in whatever angle you need. If you want to place the MAF in the similar position I did, then yes a 2" silicone 90° coupler would be perfect. Then slap on a filter and enjoy!!
  18. yangjiesheng
    Singapore
    Yes! Finally shippment arrived!
    Going to get either hks reload filter or apexi
    SFO and Daves09prius like this.
  19. yangjiesheng
    Singapore
    Done the by pass coolant!
    Excellent! Weather here 29-36c throughout the year, prolong journey sure can see the benefit!
    SFO and Justdidit like this.
  20. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Do I spy another JET performance MAF user?
