Cold air Intake? - Not a Joke or Noob question
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Daves09prius, Feb 11, 2012.
  1. Sezy
    Sezy Active Member
    443
    233
    37
    Saint Charles, Missouri
    2020 Prius Prime
    I'm going to use the stock MAF housing. I think I have a prototype made. Just need to order the tubing that will connect to it.
  2. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    got pix? the oe maf housing is the bottleneck on the intake side. throttle blade is about 2", maf housing in the airbox is closer to 1.5".
    SFO and Daves09prius like this.
  3. Sezy
    Sezy Active Member
    443
    233
    37
    2020 Prius Prime
  4. 69shovlhed
    2,170
    752
    Delaware
    I like it!!! almost looks like a carburetor should go under that filter. you are very persistent to remold the maf housing like that. so you gonna eventually shove the filter down below the rh headlight? that seems like the best spot for cooler air to me.
    Daves09prius likes this.
  5. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Checked out your blog. Nicely done on the MAF housing. Def cheaper than my route and shouldn't cause ANY problems. As long as you use the 2" diameter at the MAF..which you are, you can use any size before OR after the MAF. Just need to match up the piping to the 2" throttle opening.
    Pretty cool. Keep us posted.
  6. Sezy
    Sezy Active Member
    443
    233
    37
    2020 Prius Prime
    sounds good from inside the car. Makes a faint hiss sound and suction noise when engine turns off.
    toyotechwv likes this.
  7. toyotechwv
    toyotechwv Toyota Technician
    474
    254
    Princeton, WV
    Another Prius owner that does autox, I love it. Sounds like you need some r-comps though. Great run!!!!
    Makes me miss my old 2nd gen, it was.....umm....unique :)
    SM-G900V ?
    Sezy and Justdidit like this.
  8. Currawong
    Currawong Junior Member
    23
    Fukuoka, Japan
    Bringing this back from the dead, as I saw the PriusChat shop has a Injen Short Ram Cold Air Intake. I guess it is not worth bothering with for a Gen 3?
  9. 69shovlhed
    2,170
    752
    Delaware
    only worth bothering with if you enjoy that sort of thing
    Currawong likes this.
  10. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    If you like noise, and don't mind that it stops at odd times you can make more noise. If you want good filtration, stay stock.
  11. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    SFO and Sezy like this.
  12. dml996
    dml996 Junior Member
    Spartanburg, South Carolina
    anyone got a stock intake, resonator assembly for 2012 for sale?
  13. dolj
    dolj Senior Member
    8,652
    4,404
    Wellington, New Zealand
    As your car is a Gen 3, try asking your question in the equivalent Gen 3 forum. It is more likely the people there will have Gen 3 parts.
  14. Tuf
    Tuf New Member
    Brooklyn
    Hi Dave 09. I have an 09 and the air intake resonator got mashed. It looks like the only issue with not replacing it is having it moderate water being splashed into the engine. I have been driving without it for about 500 miles and getting better milage. Especially in the city. Did you have any issues with water puddles? I havent driven in heavy rain yet. Tuf in brooklyn ny
