Cold start rough idle with misfire codes
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Uber_NYC, Jan 23, 2020.
  1. Uber_NYC
    Uber_NYC Junior Member
    17
    Astoria NYC
    I wasn’t getting any coolant loss, oil looked good, ran the techstream compression test it was good.
    What I’ve done already to solve this
    - cleaned EGR valve and cooler
    - completely cleaned out intake manifold
    - replaced PCV
    - replaced spark plugs and ignition coils
    - replaced fuel injectors
    The ICE now has a rough start with 3 seconds of misfires then idles normally. While cleaning out everything I found very heavy carbon deposits inside the head itself and all over pretty much everything I cleaned out 59985823244__A3152542-D6D7-4F0E-844B-5466AC82C876.jpg
    Look at my old injectors
    What can I do next? I was thinking of running the Berrymans total combustion treatment through the evap vacuum line.
    iPhone ?
    52,883
    how many miles on her?
  3. Uber_NYC
    17
    Astoria NYC
    2013 with 100k miles
    iPhone ?
    52,883
  5. Uber_NYC
    17
    Astoria NYC
    I didn’t use the best gas and there was a pinhole in the engine air filter where you could see dust was getting through. The carbon in the head was literally flaking off in some spots.
    iPhone ?
  6. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Did you get authentic spark plugs
  7. Uber_NYC
    17
    Astoria NYC
    Yes, from the dealer. I saw the reports of fake plugs on Amazon.
    iPhone ?
    David Scott Dallas likes this.
  8. Peter123
    Peter123 Active Member
    132
    128
    Have you tried an engine cleaner, like Seafoam or Cataclean?
  9. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    After my EGR maintenance I left the head deposits alone and just used a few techron treatments. 2 years later the head had a light oil coating and no deposits.
    Good idea to remove and clean the injectors.
    Pixel XL ?
  10. David Scott Dallas
    David Scott Dallas Junior Member
    39
    Dallas
    Did you clean the throttle body? I had rough engine shifts on and off while driving when the motor would kick on. while stationary the car would really move like someone had jolted it when the engine would kick on. I removed and thoroughly cleaned nothing but the throttle body and maf sensor and it ran so much smoother
  11. Uber_NYC
    17
    Astoria NYC
    Yeah I cleaned the throttle body and the MAF and the MAP. Surprisingly the throttle body was the only piece that wasn’t covered in heavy residue.
    iPhone ?
  12. Uber_NYC
    17
    Astoria NYC
    I have Techron in there now. The first engine start is rough after 20 seconds every time. I turn off the car and it starts really smooth the next time. After an hour idling and a few really smooth engine cycles the misfires come back bad.
    iPhone ?
    #12 Uber_NYC, Jan 26, 2020
  13. tankyuong
    1,555
    662
    Central MO
    When it starts knocking apply the throttle until knocking disappears
