Cold weather dashlights don't work!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Dow, Nov 21, 2014.
  1. Dow
    Dow New Member
    Clatskanie, OR
    My wife's 2007 Prius Dash lights stop working in extreme cold weather. We have asked the dealer 3 times about it but to no avail! No one seems to have any ideas about this. Does any body have any suggestions. I don't even know where to start with this one?
  2. Patrick Wong
    18,200
    6,471
    If the combination meter is the only system which is intermittent, the problem is with that device. It had been covered under an extended warranty.
    T-SB-0172-09 Combination Meter - Intermittent Display | PriusChat
    Otherwise, if the combination meter is not the issue, then I know where to start:
    1. Obtain the electrical wiring diagram for your model year at techinfo.toyota.com
    2. Get a decent digital multimeter for use in troubleshooting
    3. Find a system that is intermittent.
    4. Refer to the EWD to determine the relays and fuses that feed that system
    5. Park the car outside in cold weather so that the system will not function
    6. Use the multimeter set to voltage and trace the wiring (per the EWD) to see where you no longer measure 12V. That is where your problem is.
    Most likely, the problem is a relay that gets stuck so it will not engage in cold weather.
  3. Dow
    Dow New Member
    Clatskanie, OR
    I thank you Mr. Wong! It is sure nice to have a place to ask questions and get good advice.
  4. Mrs.Diamond
    Mrs.Diamond Junior Member
    66
    Minneapolis, MN
    Did you find the fix? I’ve been having the same issue.
  5. dolj
    dolj Senior Member
    7,628
    3,849
    Wellington, New Zealand
    Search for Combination Meter in the Gen 2 forums.
    Essentially, if it is faulty, send yours to Matt @Texas Hybrid Batteries with some $$$, your ODO reading and he will send you a refurbished unit with the correct milage programmed. Contact him direct for details.
    Mrs.Diamond and Raytheeagle like this.
