Cold weather Engine noise
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by MichaelJai, Nov 30, 2018.
  1. MichaelJai
    MichaelJai Junior Member
    toronto
    2017 Prius c
    I noticed a weird ticking noise from the ICE when it is cold outside. Around 1200RPM when idling. Anyone has the same problem/experience too?
    Btw...The new Camry hybrid XLE is so niceeee. Definitely feels like a Lexus now.
    Thanks
    52,695
    are you using synthetic oil? sounds like a lifter
  3. MichaelJai
    toronto
    2017 Prius c
    Currently running 0w20 Mobil 1 extended performance with Toyota OEM oil filter. I am going to switch to Amsoil signature series after the winter and see if it is gonna help.
    bisco and James1964 like this.
  4. frenzee
    frenzee Member
    95
    73
    16
    Costa Mesa, CA
    Mine lasts about 1-2 minutes, then it goes away, regardless of outside temps. I can't tell if it's a lifter or an exhaust manifold shield rattle.
  5. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    The last 3 Toyota's I've owned (Matrixx, Yaris, Prius C) all had the lifters tick when cold. Seems to last only a few minutes though.
    I'm not sure how much difference synthetic makes on this when it comes to the lifter tick. I'm using Castrol 0/20 w/Mobil 1 filter and it ticks just like it did when it was brand new. That being said, the last 2 Toyota's I owned also did this (Matrixx & Yaris) I doubt it's anything other than normal when cold.
    ztanos, bisco and roadrunner like this.
  6. bisco
    52,695
    is it worth running it by the dealer while still under warranty? they replaced a lot of engine parts on my fathers new chrysler a few years back. unfortunately, that didn't fix the problem though.
  7. mohsin
    mohsin Member
    91
    61
    Dubai, UAE.
    2014 Aqua
    If its just ticking (sharp) noise then its the lifters. If its growling/scraping or anything strange then its definitely the heat shield. They can make very strange and scary noise.
