Cold weather mileage hit
Discussion in 'Gen 4 Prius Fuel Economy' started by ultravorx, Nov 8, 2016.
  1. midwesterner
    midwesterner New Member
    Iowa
    I bought my 2016 Prius Two Eco in September, new with about 269 miles. The gauge was showing 69.0 mpg lifetime miles. By the time I got it home (roughly 100 additional miles), it was up to 72.0. The dealer had filled the tank for me, and I'm not sure what kind of fuel was used there. Since then, I've been using ethanol (mostly 10%, one tank at 15%) and it has gotten colder since Sept. I think the coldest when driving was somewhere around -10F to -20F. I've had a lot of days that were warmer, but I still had to run the defrost at higher fan speeds (i.e. gas hog) because the temp. I set to when using auto HVAC wasn't good enough to keep condensation off the windshield. Additionally, there have been some days with snow and rain, which I think cut mileage. Finally, wind seems (subjectively) to have been against me on a lot of longer trips.
    I'm now at almost 6K miles and down to about 52 mpg lifetime. Needless to say, I've not been happy with mpg lately. I'm not sure if the ethanol is lower mpg than if I were to use normal or premium. What I am sure of: Using the defrost as much as I have had to at the high fan speed is affecting mpg.
    RCO likes this.
  2. Prodigyplace
    12,717
    11,849
    Central Virginia
    Have you checked your tire pressures? My non-Eco was set at 32 by the dealer. Tire pressure can affect mpg. So can winter blend fuel. My son had noticed the fuel hit for years with his Prius.
  3. midwesterner
    Iowa
    No, but I'll make a note to do that sometime soon. The tires came filled with nitrogen, and I have not had any alerts for low tires. But I also realize that the low tire sensors won't pick up slight under-inflation.
    Should I switch away from ethanol? It is cheaper in my home state (subsidized with lower tax) where most of my gas is purchased. If there is a nominal difference, I would stay with the cheaper gas and be better off anyway.
  4. Prodigyplace
    12,717
    11,849
    Central Virginia
    Good question. Here non-ethanol fuel is about $.50 per gallon more expensive. People generally use it for garden equipment, especially 2-stroke cycle engines. In fact, some manufacturers recommend against ethanol fuel in their 2-stroke engines.
  5. Flash287
    Flash287 Junior Member
    Hamburg, NJ
    My gen 4 during spring, summer and fall has been averaging 62mpg in new Jersey. Cold temps in winter below freezing mpg dropped like a rock. Last tank was down to 50 mpg. Wondering if there is something wrong?
  6. Mendel Leisk
    42,355
    50 mpg in the dead of winter is still very good.
    greenmonster01, RCO and krmcg like this.
  7. first_superior_prius
    76
    115
    Michigan
    Nothing went wrong, there is more rolling resistance for the car, the air is denser, you have to have the heater running - all of that drains MPGs
    It will rebound back to the 60s once spring rolls around
    krmcg likes this.
  8. Mendel Leisk
    42,355
    Besides all the physics pulling mpg down (in winter), I think the car's programming shifts, purposely delays engine shut off, etcetera.
    RCO likes this.
  9. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    How and where you are driving makes a big difference to mileage. Low speed city type driving gets higher mpg. At higher speeds, such as open highway, it takes longer distances for the mpg to increase to 'good' but not as good as city! YMMV.
    krmcg likes this.
  10. Prodigyplace
    12,717
    11,849
    Central Virginia
    Stop-and-go city driving can lower your mpg, though. People here are in too much of a hurry. They accelerate fast so they can brake fast.
