Colder weather has zapped my mileage to 44mpg
Discussion in 'Gen 3 Prius Fuel Economy' started by cmalberto, Dec 5, 2009.
Thread Status:
Not open for further replies.
  1. snead_c
    snead_c Jam Ma's Car
    667
    58
    Hendersonville
    All together now ...AMEN ! :cheer2:
  2. Love My Prius
    Love My Prius New Member
    Sinking Spring, PA
    I purchased my 2010 prius IV in July 2009 and was averaging 48 to 51 mpg. Weather has been in the 30's / 40's and I just had my first oil change the last week in 2009. Now my gas mileage is down to 42 - 43 mpg. Could be the cold weather but it make me wonder if it might have something to do with the oil change.
  3. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    Make sure not over-filled, and attempt to verify they used 0W20...
  4. cmalberto
    cmalberto New Member
    95
    Sour Lake, Texas
    Maybe - but I hit 50 last week when the temps stayed in the 60-70s. Now back in the 40s this week and I am back down to the low 40s. It makes a difference. I also switched back to reg gas. Will try plus again next week just to see. Probably will warm up as soon as it does just to cloud my test.
    --Mickey
  5. Cdrake999
    Cdrake999 New Member
    Indiana
    Driving back and forth to work 45mph speed limit on most roads, with temps in the teens, I can get nearly 50mpg. It's all according to snow/ice on the front wind shield. That engine startup/defrost kills my mpg. If temps were in the 60's or 70's here I'd be getting 55+ mpg.
  6. Airbalancer
    Airbalancer Active Member
    892
    73
    Cobourg, On, Canada
    My wife drives the Prius 90% of the time
    Look out the window this morning, car is running as she clears the snow off the car:eek:
    Who wants to tell her that is bad for the mileage :D
  7. Tom183
    Tom183 New Member
    652
    65
    Maine
    Unlike most other cars, the Prius will shut off as soon as it's warm enough - but if she has the cabin temp set to 80, that may take a while... :rofl:
  8. Love My Prius
    Sinking Spring, PA
    Thank you. I did check oil level and dealership didn't over fill. Hope they are honest because I checked my print out and it stated they used the synthetic oil.
  9. Welshdog
    Welshdog Member
    181
    38
    Austin, TX
    We were getting 38 mpg this weekend. Can't wait for hot weather again. Didn't think I would ever say that after 69 days of +100° temps last year.
  10. cmalberto
    95
    Sour Lake, Texas
    Is that the truth...when would you ever ask for hot weather. I am at 43mpg this week, but you guys have alot of hills which doesn't help.
    --Mickey
  11. Tom183
    Tom183 New Member
    652
    65
    Maine
    I have mentioned this in other threads recently, but it's worth repeating here:
    Increase your tire pressure. I'm seeing an additional 2 1/2 mpg across the board, even at high speeds.
    It won't fix really short trips (under 5 miles), but for everything else you should see a difference.
  12. viprius
    viprius Junior Member
    46
    Southern California
    I am from LA and I too bought my car in mid-July last year.
    Initially I used to get very good mileage but after that I am getting around 43!
    I can understand that my work commute is 5 miles one way. Also, initially when the car was new I used to drive it a lot.
    Let's see how it goes now summer is almost back!
    Attached you see my MPG history.
    Also, that sharp drop you see is because once I went to a very steep hilly area.
      File size:
      46.1 KB
      643
  13. priusmiselus
    priusmiselus New Member
    42
    Planet Earth?
    38 sounds really low...
  14. TonyWilkey
    TonyWilkey Member
    99
    25
    Kansas
    What do you think of 35 then! Heh. Only four tanks so far.
  15. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    It is low, however it is pretty normal on short trips and in cold weather.
    We can not expect 50 mpg in such condition.
    MPG is miles per gallons.
    The warming-up and heater usage fuel do not increase miles part, but they do increase gallons part.
    The result is low mpg.
    Ken@Japan
  16. priusmiselus
    42
    Planet Earth?
    Interesting, thanks.
  17. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    For those worried about low MPG, I suggest taking a trip somewhere other than your daily commute. Preferably highway miles and over 50 miles and see how your MPG changes.
    I say this because my normal commute keeps me in the 44mpg area but when I take trips in the other direct (away from the mountains and in flat terrain) my MPG pops back up to 50mpg without even really trying.
    My point is, your car is likely fine. It is your commute that kills your mpg.
  18. snead_c
    667
    58
    Hendersonville
    Excellent points. I would add that how fast and how aggressively you drive also make a big difference. The standard issues of tire inflation, car load, oil viscosity and level, as well as energy drain for AC use and cold air chilling down the ICE must be considered.
    I frequently do 20% better than my wife on the same roads just by trying to drive economically. :rolleyes:
  19. john1701a
    john1701a Prius Guru
    12,817
    5,303
    58
    (note the cross-post link)
    So, after all that MPG complaining you ended up trading in for a car that only delivers 22/32 ?
  20. cmalberto
    95
    Sour Lake, Texas
    I am crushed...
    --Mickey
Thread Status:
