Collision - Things to make sure
Discussion in 'Prime Main Forum (2017-2022)' started by AmazingPriusPrime, Mar 16, 2022.
Tags:
  1. AmazingPriusPrime
    AmazingPriusPrime Junior Member
    23
    Northwest
    Got into a collision today with the other driver's fault (He was taking a left on my right of way). Anyways, looking at the damage below, are they anything to be aware or make sure when I take the car to the body shop to fix? I think none of the EV areas are impacted but would like to take your opinion so I can select a body shop accordingly. FWIW, I'm in Seattle Eastside area. Anything else to double check or make sure will be really appreciated. No injury to either drivers. Also, this is 2017 advanced but for some reason couldn't detect and stop the collision probably due to the direction in which the other car came and hit.
    s
  2. xliderider
    xliderider Senior Member
    7,909
    3,138
    Honolulu, HI
    That sucks, make sure they replace that driver's side wheel. Have them verify that there is no suspension damage from the impact to the wheel, and check the alignment.
    Trollbait likes this.
  3. PT Guy
    PT Guy Senior Member
    1,085
    711
    Washington, the state
    Take a very good look for less obvious spots of damage. Photograph all the damaged parts so you'll have that to go back to when the shop says it's ready for you. Take an extensive test drive before you accept it back. It'll need an alignment check, and on your test drive try for a straight level road where you can take your hands off the steering wheel briefly. It the car doesn't continue straight, the alignment isn't correct, perhaps due to bent parts they should have changed. Look at the earlier posting about front wheel bearing noise--listen for that both driving straight and turning both directions. Your car should look like new and drive like new.
    49,842
    when it gets to the body shop, tell them you want to see it after they pull the damaged panels off and discuss what hidden damage they find. usually the insco takes a look at that point
  5. jerrymildred
    jerrymildred Senior Member
    11,518
    14,127
    Tampa, FL
    We took ours to a Toyota collision center. No squawks from insurance. Looks like a new car now.
  6. Gokhan
    Gokhan Senior Member
    4,845
    1,907
    Paramount CA
    Since this the Advanced/Limited trim, you need to take it to a Toyota dealer because other shops will be clueless on how to recalibrate your parking sensors and radars.
    Incidentally, it could cost more than $1,000 to recalibrate the parking sensors alone. However, insurance companies negotiate it to half the price. Simply have this done through an insurance company at a Toyota dealer and don't worry about the rest. If it is a hit-and-run, you will need to pay your deductible. Moreover, these repairs take a very long time, and you will need a rental car for perhaps about a couple of months.
    #6 Gokhan, Mar 19, 2022
  7. BiomedO1
    BiomedO1 Senior Member
    1,678
    866
    SacTown, Ca
    Check to see if the body shop replaces the front wheel bearing and strut assembly. I can't tell from the picture, if the rear wheel took a hit. Wheel bearings take a while, before you notice there's a problem. Minor damage turns into grinding noises a few thousand miles down the road.
