Colorado Catalytic Converter Theft - Advice?
Discussion in 'Gen 2 Prius Main Forum' started by Colorado2009, Mar 21, 2021.
  1. Colorado2009
    Colorado2009 New Member
    Colorado
    Hello, new user here. I've been scrolling through the many catalytic converter cat theft threads, but there's a lot being discussed and it's a little overwhelming.
    Mine was stolen yesterday off of my 2009 Prius (my only car). I'm being quoted a $3,000 repair bill (didn't insure the vehicle, since it's older) but more importantly the shop said they have no idea when the parts will become available from Toyota again. It doesn't make sense for me to leave the car sitting for 5 months, the battery might die right?
    What are other people doing in situations like this? I'm especially interested if you live in Colorado or state with similar regulations. Are you waiting 5 months to repair, or are you selling the car and buying a different one?
    One store I called told me to drive it across the border to Wyoming - that way I'll be able to get the repair done ASAP and cheaper (I'm assuming with a non-CARB compliant catalytic converter). Is that even legal? Is the law that only CARB-compliant cats can be used when the installation is PERFORMED in Colorado, or is it that since my car is a Colorado-registered car it must have a CARB-compliant cat?
    donbright likes this.
    49,383
    you need to ask a local inspection shop if a non toyota cat will pass. if so, the job is a couple hundred bucks.
    if not, you'll have to shop around for the best price you can find.
    Colorado2009 likes this.
  3. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
    The CARB cat requirement is a nightmare...
    I don’t see my smog check guy take a look under the car when I get a smog check.
    Even if he did, I wonder if one could get away with installing a universal CARB certified cat, meaning it has an EO# stamped on it....
    Walker sells a cat that has a CARB EO# for a 2009 Corolla. Technically the smog check person is supposed to verify that the number stamped is valid for the vehicle model it is installed on, but considering my guy doesn’t even look underneath the car:
    What are the chances he’s gonna look under next smog check? Very low.
    What are the chances he’s gonna verify the stamped CARB EO# matches for my car? Even lower since he doesn’t look underneath in the first place.
    You’d be in trouble if caught, but the Toyota replacement is horribly expensive.
  4. The Lizard King
    Buy an aftermarket catalytic converter and roll the dice on not having it visually inspected. Many aftermarket catalytic converters work as well or even better than the Toyota OEM ones.
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,193
    5,891
    Columbia, SC
    jzchen and Colorado2009 like this.
  6. PriusCamper
    PriusCamper Senior Member
    11,059
    4,501
    Pacific Northwest, USA
    It's a pretty easy repair for less than $200 if you or your friend has experience jacking a car up safely so you can work on it. $130 for cat and $20 for O2 sensor...
    #6 PriusCamper, Mar 22, 2021
  7. ColoradoCrow
    ColoradoCrow Active Member
    968
    392
    Leawood, KS
    I
    Where is Colorado was it stolen may I ask?
  8. The Lizard King
    Colorado Springs. :)
    PriusCamper likes this.
  9. Andy Ting
    Andy Ting Junior Member
    Boulder, CO
    Hi there,
    I live in CO and I am waiting for a new cat as well. So did you get a new cat converter from dealership? How long you have been waiting since Feb?
    Thanks!
  10. Colorado2009
    Colorado
    Hey Andy, sorry about your cat. I did not end up getting mine from a dealership. I didn't want to let my hybrid sit, so I ended up getting a CARB-compliant (but non-Toyota) cat installed by a local muffler shop.
  11. TMR-JWAP
    6,193
    5,891
    Columbia, SC
    jzchen likes this.
  12. qmanqman
    qmanqman Active Member
    309
    112
    CO
    I just replaced the cat in my daughter's Prius. The tail pipe on the new cat was a lot larger than the input pipe to the muffler so I had to do some work to get it right but it seems to be working fine. And since the one I took off is the OE cat it will sell for $950. Made $800 doing it.
    This is the one I put in.
  13. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,153
    2,204
    Taylors, SC
    This one fits perfectly.
    Here's a video of one used in an install.
    ColoradoCrow, Another and jzchen like this.
  14. SlambK
    SlambK Junior Member
    Fresno, CA
    Hey there,
    Fellow Coloradan (Denver) who just had their cat stolen here...I'm trying to go the route you did, but struggling to figure out who would do this work. Any chance you can share with me who did the work?
  15. royrose
    royrose Senior Member
    1,389
    949
    Foot of Pikes Peak
    In Colorado, emissions testing is required in only a few counties, generally around the Denver/Boulder area.
    From the DMV web site: El Paso County requires ONLY diesel inspections and those are limited to certain parts of the county.
    So the Wyoming option would appeal to me.
    Are you willing to say where in the Springs area the theft took place?
  16. SlambK
    Fresno, CA
    Hi there, I think you are mistaking me with a different person from earlier in this thread. I live in the Denver area, which is where mine was stolen.
    Unfortunately the person/s who stole it didn't do a great job and it looks like while they took the time to unbolt it at the one end, it took them three tries with the saw at the other ):
    I'm now concerned their first attempt is so far back the replacement cat won't even cover the partial cut into the pipe they made :(, so I'll almost definitely need to take it somewhere to get welded.
    Sorry for the bad photos, but you can see their first cut was basically on the original weld and looks like they did in fact cut through it a little. The second cut that they left hanging hopefully shouldn't be too hard to finish off at least.
  17. edthefox5
    edthefox5 Senior Member
    10,096
    4,804
    Clearwater, Florida
    Don’t worry about that the new cat replaces all that. The muffler shop just adds a connection pipe/ sleeve if you will over both ends if anything short and welds it all up.
    My muffler guy charged me $80 to remove my stock cat and install the model Georgina referenced which by the way car ran better with that cat and after months never ever saw a check engine light so it works well on a g2.
    I sold my stock cat on eBay for $1500 ebay took 10%. Sold it to a guy in Mass. My cat looked really good no rust on it Florida car.
    ColoradoCrow and Georgina Rudkus like this.
  18. royrose
    1,389
    949
    Foot of Pikes Peak
    Yes, I was responding to The Lizard King, sorry I didn't make that clear.
  19. SlambK
    Fresno, CA
    Can't find any muffler shops in the Denver/Aurora area who will touch it. If anyone knows of a shop or mechanic who can can at least put it on for me (welding would be great too, but one step at a time..) I would be extremely grateful.
    Definitely willing to make a drive- looking into Wyoming options now, but would appreciate hearing from someone who has actually done it (would having CO plates stop them from doing it?), but also sounds like we may have snow storms incoming so might not be the easiest option right now.
    Just cannot fathom putting $3,000+ into (via Toyota or authorized repair shop) a 2005 Prius at this point, absolute insanity.
  20. Another
    Another Senior Member
    1,802
    511
    Naples, Florida
    That’s what Google, email and the phone are for. Invest a couple of hours and you may find one.
    qmanqman likes this.
