Combination cluster not working. Turn on '05 prius correctly?
Discussion in 'Gen 2 Prius Main Forum' started by franken1313, May 29, 2017.
  1. franken1313
    franken1313 Member
    216
    26
    US
    My combination meter (dashboard) sometimes does not power on. My cruise control sometimes does not work. Especially if the dashboard is not working. I have error code P0a93 which indicates to a bad inverter pump. I have changed the several pumps multiple times. Nothing has helped my car except 1 thing. When I go to start the car I press the on button twice and then I hold down the brake and turn on the car. After doing this everyone I noticed my dashboard would work almost everyday. I had no error codes and my cruise control was working fine. So is going straight to holding the brake and turning on the car not the "correct" way to turn on a prius? Can someone who is having the same dashboard problems try this?
    49,600
    how is the 12v health?
  3. franken1313
    franken1313 Member
    216
    26
    US
    Good. I have changed the battery at least 3 times. I have changed several several things in the car hopping that was the problem
  4. JC91006
    16,488
    8,402
    You should just change out the combination meter and be done with it
  5. franken1313
    franken1313 Member
    216
    26
    US
  6. JC91006
    16,488
    8,402
    Yes
    You should reset your 12v battery, get rid of the inverter pump code. See if it'll come back. You might simply have to bleed out the air in the coolant
