Combination meter and trying to work with Toyota
Discussion in 'Gen 2 Prius Technical Discussion' started by ahartnet, Jul 16, 2018.
  1. ahartnet
    ahartnet Junior Member
    Hello,
    My combination meter has been getting flakier and flakier. I'm in a warm climate, and I thought from previous posts it mostly seemed to happen on cold days, but I can confirm that even on 90F+ days that my combination meter doesnt always start. unplugging and replugging the battery does seem to temporarily fix it, but is obviously annoying.
    I contacted Toyota and let them know I have a TSB document number of what I know they need to do trying to figure out how much it would cost me to fix, and they were saying upwards of $1000, but that they wont give me an actual price until they do their own diagnostics to confirm the price. I don't want to go pay $100 to find out they're going to try to charge me $3k (or even $1k...) to fix it.
    It's an '06 Prius on it with 224k miles on it. New 12V battery installed by me last year, and a rebuilt/reconditioned hybrid battery installed by hometown hybrids (in Texas) in 2015. This toyota dealership replaced my evaporator core a year ago and didn't reconnect my FM tuner, and then also replaced brake actuator under an extended warranty about 7 months ago.
    I have not ever taken the dash out of a vehicle before, and it's my daily driver, so repairing it myself seems intimidating. I was hoping to get a couple more years out of my Prius, but at some point I got to decide if the repair cost is worth it. So I come to y'all asking for any advice or guidance on is it worth it to investigate putting in a new combination meter myself, trying to get Toyota to give me a better idea on cost (and/or cheaper), or bite the bullet and keep it around for short trips but recognize it may not be my daily driver anymore. Reselling isn't really an option to me since I don't think I could get much out of it (12 yrs old, 224k+ miles, hood was chipped away at driving behind some kind of rock truck on a highway, and the trunk handle is JB welded on to it).
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    52,720
    75 bucks for install is incredible.
  4. VFerdman
    VFerdman Senior Member
    1,200
    1,218
    Western Massachusetts
    I have watched videos on replacing the combo meter and it really does not look that bad. If you are at all good with simple hand tools and following instructions I think this could be a very satisfying and fruitful weekend project for you. $75 for a re-manufactured part is really a bargain and the time spent by you learning and performing the job will still be under the dealer cost. I suggest you go that route.
    As an aside, I have also seen enough information on the subject to learn that most of the failures on these displays are due to a bad and undersized capacitor, a dime-a-dozen part that can be purchased in many of the online electronic parts suppliers. So if you have any experience in working on electronics yourself, you can have the part fixed yourself for only a few bucks.
    Best of luck and let us know what happens.
  5. ahartnet
    That is a great link. Other posts on this forum I've only seen suggesting ebay or junkyards to get combination meters, but kind of wanted to keep all my hard-earned miles on the odometer.
    I watched a couple of videos on taking out the combo meter, and I have a weekend in a couple of weeks that I should hopefully have at least one full day available. I will go that route and follow up in here with the video links I used and what tools I needed handy for anyone in the future.
    Thanks!
    VFerdman likes this.
  6. VFerdman
    1,200
    1,218
    From what I understand it's a couple hours job. Best of luck!
  7. greasemonkey007
    greasemonkey007 Active Member
    287
    106
    South Central Arkansas
    Call Matt at Texas Hybrid Batteries! You get a lifetime warranty on the replacement part, and the miles are matched to your car!
    Where are you located?
  8. ahartnet
    I'm in Houston
    I actually just paid to have the combination meter sent to me today. I'll be attempting to install it this weekend
    Raytheeagle likes this.
  9. greasemonkey007
    287
    106
  10. ahartnet
    Got my part in from Matt, and used this video
    Took me about 90 minutes, and was really straight forward. Didn't feel great about changing out the board in the humidity of Houston (did it in my garage), but no major issues. Only thing that was really an issue was because I was an idiot and tried to remove the bottom panel on the driver's side and was confused as to how to take the hood latch off the panel. I eventually realized there was no reason to remove that panel from the vehicle and could just leave it hang there.
    My vent covers (the silver trim around the vents) were previously cracked, so they're in a little worse for wear now after prying them off and putting them back on. But the vents themselves are all fine still.
    Had a great experience with Texas Hybrid batteries.
  11. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    YAY!! Glad you had a good experience with Matt. And that's the same video I used when I had to clean two different combo meters. One was an '05 and the other an '07. I was going to suggest it, but I see I came to the party too late.
  12. RD James
    RD James New Member
    Hawaii
    Same problem here but it usually fails after it's rained. The lower edge of the windshield is directly above the combo meter. Before I take the dash apart I am sealing the lower edge of the windshield and see if that changes anything.
