Combination Meter, Best Option, Sacramento Area
Discussion in 'Gen 2 Prius Technical Discussion' started by Friendlyx, Oct 24, 2018.
  1. Friendlyx
    Friendlyx Member
    187
    47
    Stockton, CA
    I have a Toyota Prius 2006, which i believe the combination meter is going bad or already gone. It started about 6 months ago, and at first the car wouldn't turn off randomly, or it would randomly not show the odometer. Then about 2 months ago it got worse, where it was happening more often, i learned that i could disconnect the battery to fix it, and it did for a while. Now it's happening every week or so and i think it's time to replace it.
    The car has 160k miles on it, and still on the original hybrid battery, so i think i'll need one of those soon too. What's the cheapest way to replace/repair it? I'm near Lathrop, CA if that matters.
    52,596
    diy, otherwise, luscious or avi.
  3. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    There is a guy that rebuilts them. He is on here You will have to take your dash apart though. There are videos showing how to do this. I suggest you look at them and see if you can do it
  4. Friendlyx
    Friendlyx Member
    187
    47
    Stockton, CA
    I've looked at them and they seem fairly okay to do. How do i find the guy?
  5. Skibob
    2,912
    1,505
    Northern California
    Hopefully someone here will give you his name. Or search combo meter repair. He in in Texas I think.
  6. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,525
    Bay Area, California
    2019 Prius Prime
    @Texas Hybrid Batteries is the user and Matt is his name;).
    You can always look up at the Rancho Cordova recyclers for replacement meters (HP Motors has many Prii).
    Then do the swap (y).
    Skibob likes this.
  7. Skibob
    2,912
    1,505
    Northern California
    Won’t the mileage be different if he swaps one out from the junkyard?
    Raytheeagle likes this.
  8. Raytheeagle
    11,267
    15,525
    2019 Prius Prime
    It will be, but there are videos on how to do the swap to fix that ;).
