Combination meter capacitor
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Mebeksis, Aug 4, 2018.
  1. Mebeksis
    Mebeksis Junior Member
    53
    17
    Covington, GA
    Getting ready to replace the capacitor on my combination meter and was wondering (from those who have done this successfully) what solder you used? Thanks ahead of time.
    DLC82SV likes this.
    52,819
    i reported your post, and asked that it be moved to gen 2 forum where more experts might view it, all the best!(y)
  3. Mebeksis
    53
    17
    Covington, GA
    Oops, thought I had posted it there.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Why ??
    Most any rosin core solder should be fine.
    Brian in Tucson likes this.
  5. Mebeksis
    53
    17
    Covington, GA
    Why am I replacing the capacitor?
    Combination meter failure. It's a gen 2 known fault. Remedy is replacing a 100uf capacitor with a 220uf.
    DLC82SV likes this.
  6. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    I think I would agree with that. Solder is solder.
  7. bisco
    52,819
    i use electronic solder from radio shack, cause i have no idea what i'm doing. otherwise, i'd be using plumbing solder.
    the electronic solder is very fine, which is nice around small areas and wires.
  8. sam spade 2
    7,035
    2,804
    2017 Prius c
    Yep. That's the critical point.
    Plumbing solder is ACID core and tends to EAT electronic components.
    :eek:
    OBJUAN and ITBland like this.
  9. VFerdman
    VFerdman Senior Member
    1,200
    1,218
    Western Massachusetts
    You still have access to Radio Shack? The last one has closed around here a while ago... Or maybe you use solder so infrequently that you still have some Radio Shack stuff from previous century? :)
    I think the OP is worried about PCB corrosion from the flux and/or lead content of the solder. I used Radio Shack stuff until I ran out a while ago and bought some online. You can still buy leaded solder which has a lower melting temperature and is preferred by many old school techs. I personally do not care. My iron handles either kind well.
    It would be nice for the OP to elaborate on his question. Otherwise I would go with "(electronic) solder is (electronic) solder" answer.
    bisco and edthefox5 like this.
  10. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    I think you want something like this: Just regular tin-lead solder that melts as low as possible.
    Here is my iron
  11. padroo
    padroo Senior Member
    2,763
    2,253
    Ask for 60/40 rosin core solder. You want a small diameter solder to do your work.
    The 60 represents the tin in the solder and the 40 the lead.
    Never use acid core solder on electrical or electronic circuits, it is for plumbing.
    DLC82SV likes this.
  12. bisco
    52,819
    the few radio shacks shown on their store locator are 'authorized dealers' under another name.
    i just soldered a wire on my grandsons choo choo train yesterday but yeah, my stuff is all from the 80's.:p
    m.wynn and VFerdman like this.
  13. Mebeksis
    53
    17
    Covington, GA
    Ended up buying this as it was recommended for electrical and was the smallest diameter (.032").
    New question. Getting ready to solder, new capacitor has different length arms. I understand the longer one is positive, but should I clip it so the capacitor isn't leaning sideways? Or just go with it?
  14. Mebeksis
    53
    17
    Covington, GA
  15. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    Plumbers might agree, but electronics engineers might have different opinions!
  16. padroo
    2,763
    2,253
    Except for looks the length isn't important but like you already know the polarity is important. I would clip it and make it look good if I was doing it.
    With a visual inspection did you see anything wrong with the old capacitor? Usually that kind of capacitor gets a slightly bulge in the top when they fail, the new one should be perfectly flat.
  17. padroo
    2,763
    2,253
    I am into model RC aircraft and people don't like that lead free solder.
    Start watching at 4:20 for a demonstration.
  18. sam spade 2
    7,035
    2,804
    2017 Prius c
    IF......the "lead free" solder is tin and silver, it certainly would not "suck".....except for the price, that is.
    And the polarity of the capacitor leads are marked on that plastic cover around it, down near the bottom where the leads are.
  19. Mebeksis
    53
    17
    Covington, GA
    Price of 96% tin and 4% silver was less than $5.
    Also, got new capacitor on, car started, left it running for a few minutes with no explosion, so I think I'm good. We will see. 20180805_145409.jpeg
    wjtracy, DLC82SV and bisco like this.
  20. bisco
    52,819
    that's where my flux and solder are from, building electric planes in the 80's. my, how times have changed.
