Combination meter diy
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jack08, Dec 8, 2015.
  1. jack08
    jack08 New Member
    45north
    After scouring the web unsuccessfully for the fix to my 08 prius with 280k? miles on it I decided to just tear into it. The attached picture is what i found to be the problem. I soldered c70 back on and my car worked great for one day(same part failed again).
    If the fix is simply to swap out c70 then this is an easy diy or 5 min of shop time(cheap). The problem is- what is the value of this component?
      File size:
      162 KB
  2. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    The problem is that something is causing C70 to fail, the solution might be to find out what is causing the failure. Replacing the component is akin to replacing a blown fuse without determining the cause!
  3. Patrick Wong
    18,210
    6,515
    It is not obvious what is the problem:
    1. Did C70 actually fail or was a solder joint the problem?
    2. If the problem is with the solder joints then do you have the correct tools/skill to replace surface mount components?
    3. If C70 actually failed, how did you know what component value to replace it with?
    4. The cost of a new capacitor is typically very small, in the pennies, shipping will cost much more than the part itself, mouser.com is one source (assuming you know the specs of the capacitor including capacitance and voltage rating.)
    5. Referring to your photo, there are two solder joints below C70 associated with a multi-pin connector which look pretty bad.
  4. jack08
    jack08 New Member
    45north
    I took off the resistor 6r8 (the green one in the pic). Tested it and it had failed to the open position (no resistance at all).
    I just now replaced the resistor 6.8 ohm, and since i did not know the capacitor value i chose one of similar size from another pcb. Not ideal but without the schematic how could i get the value of a toasted capacitor? Besides I read that size can give some indication to the value so why not...
    Dash is lit up again, been a couple hours now.
  5. WilDavis
    2,493
    2,155
    49
    …as I mentioned in my earlier post, I think your problem is unlikely to be fixed by simply replacing the blown component. You might be better advised advised to seek the source of the problem! Good luck! (…and if you still don't understand what I'm trying to tell you, the very best of luck! (…because you're gonna need it!))
  6. Patrick Wong
    18,210
    6,515
    When you say the "dash is lit up", I assume you mean that the combination meter is working right now?
    I agree that 6R8 = 6.8 ohms, so that is a good value regarding resistor R111. Did the replacement resistor remain at 6.8 ohms or did it also blow?
    How did you determine that capacitor C70 had failed? Did the original C70 have any markings on it?
    It looks like the replacement capacitor is not soldered very well to the pads. You are right that there is no way to determine its value since there are no visible markings - unless you use a capacitance meter to measure it.
  7. WilDavis
    2,493
    2,155
    49
    …the only other advice I have might be that when you eventually determine the value of the blown capacitor, it might be more economical to try to get a bulk deal and buy several hundred, since until you find the cause of the problem you'll likely use a lot of them! :rolleyes:
  8. scottymac62
    scottymac62 Junior Member
    I just had my Combo meter repaired by a guy on Ebay. When I received it back, I could see which component was replaced because he did not clean off the solder flux. It was the power transistor, Part # "NEC C4552" . I have circled it on the picture. So far, it has worked flawlessly.
    I just thought all of you would like to know.
    dizzyharper and Patrick Wong like this.
  9. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    I always wondered if these repairs last... any update on this post would be helpful
