Combination meter how to get to turn on
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by robl45, Oct 15, 2019.
  1. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    I can't believe how much we're trying to point you in the right direction to solve the problem and it's completely ignored. You're asking for a type of solution that doesn't exist. We could just as easily tell you to punch the steering wheel as hard as you can until the dash turns on. There is NO magic combination of switches, etc that will miraculously make a failing circuit work every time. Anyone doing a magic combo is merely causing super small changes in the overall 12v circuit that, at some point, may or may not cause some type of flicker/transient that pushes the circuit over the edge (this time, but probably not next time). So, either invest a few bucks and fix the caps, or just keep flicking switches and knobs or 'whatever' until it turns on.
    jerrymildred likes this.
  2. ericbecky
    ericbecky Hybrid Battery Hero
    4,451
    3,359
    Madison, Wisconsin
    Clap you hands three times and spin around clockwise.
    Usually works most of the time.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    I think that only works in the northern hemisphere. Something to do with the coriolis effect. :D
  4. eljefino
    eljefino Junior Member
    43
    25
    Maine
    You're unemployed so you have plenty of time.
    Harbor freight has a perfect pencil tip soldering iron for $3.
    220 uf caps are 5/ $0.99 on ebay.
    Watch youtube, have fun. Maybe find some e-waste like an old motherboard if you want to practice soldering first.
    Money saved is money earned.
  5. Brian Hurst
    Brian Hurst Junior Member
    Fort Worth, TX
    I've got this problem, too, with my 2005 Prius - annoying. I saw Toyota issued a warranty extension to deal with the faulty combination meters in Priuses issued between 2004-2009 that lasted until 2013 or 2014, which doesn't do me much good having bought the car at a municipal auction in 2017 (why that city didn't get the problem fixed, I'm not sure).
    It is a p.i.t.a. sometimes.
  6. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
  7. Danny13pruisc3
    175
    28
    maryland
    So many negative people here..
    Turn on highbeams.. roll back windows up and down while repeatedly trying to start.. within 10 to 20 tries it has a good chance oof coming back on for me... if not i give up and drive.
  8. dolj
    dolj Senior Member
    8,637
    4,390
    Wellington, New Zealand
    Yep, it is a good idea to wreck your good $250 12 V battery just to save a one-time $150 repair to the CM, cheaper if you DIY.
  9. mr_guy_mann
    mr_guy_mann Senior Member
    4,113
    2,011
    NJ-USA
    10 or 20 tries to start the car? Call me crazy but I prefer it if something actually WORKS when I turn it on. If it doesn't work then it's broken and I better fix it.
    dolj likes this.
  10. Larry Newman
    Larry Newman Junior Member
    Orlando, Fl
    jerrymildred is correct. There's a capacitor on the board that tends to fail over time especially in cold weather for whatever reason. It's very cheap to replace and something that'll take a few hours to get out of the car if you haven't disassembled the dashboard before. The hardest part is probably just enduring the patience required to take off every panel on the dashboard without chipping or breaking them. If the combination display doesn't turn on, there's a number of things that won't work like taillights, backup camera, I believe A/C controls won't work on the MFD, etc. You can still drive the car but it'll be difficult to explain to an officer why your taillights won't come on in the middle of the night but your headlights will.
  11. ChapmanF
    19,006
    I think when I first saw Danny13's post, I took it as a tongue-in-cheek response to earlier posts in the thread.
