combination meter repair - DIY
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ultanium, Jan 20, 2016.
  1. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    http://Www.digikey.com
  2. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
  3. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
  4. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
  5. WebVixen13
    WebVixen13 Junior Member
    I live hours away from LA, but we're kind of desperate for an affordable fix! So far it's still working? Was the 160 including labor? We just bought this car used, for my mom who's retired. 2009 Prius with only 99k. A month later, it started having the black screen issue, today. We've basically spent all our funds, new tires, hoping to have a reliable trouble free car. Now this. Past the warranty, purchased 9/2008.
    Anyone know of any bay area shops that offer similar affordable repair? We're a little freaked out by this, and definitely aren't capable of repairing it ourselves.
    PriusPaddler likes this.
  6. WebVixen13
    Curious about going this route! How did you get them to give you money off the repair??
    We bought this 2009 Prius with 99k a month ago, from a local person. Paid $150 for our Toyota dealership to do a pre purchase inspection. They said it was in good condition aside from tires. Today, dashboard didn't turn on.... twice. Out of the blue. Key fob trick worked. But i'm worried it'll get worse. It's only 48 degrees out, not that cold! We spent most of our saved up funds, and I was hoping for a stress free car for my retired mom. So stressful.
    We're not at all DIY people either, i'm impressed by you guys! But that's not an option for us.
  7. Paul Schenck
    Paul Schenck Active Member
    524
    307
    Fresno, California
    Gosh that $160 price is nearly worth a drive from the Bay Area. Check for a mobile mechanic in the Bay I’m sure there is one specializing in this repair. four hours of your time plus materials might make it worth hiring a local guy.
    My last check the capacitors that fix the problem are $24.00 the skill to put them in, $200.
    iPhone ?
  8. JC91006
    16,936
    8,647
    You can fix this yourself, just need some very basic tools. The cost to get a refurbished unit is $150 from texashybridbatteries.com.
    You can watch some YouTube videos that will show you how it's done
    Maybe @Raytheeagle will want to tackle a combination meter on his next meetup in the bay area
    #188 JC91006, Jan 12, 2019
    SFO and Raytheeagle like this.
  9. Ernest Erickson
    Ernest Erickson New Member
    16
    Arizona
    Technology
    An ESR meter will help determine faulty caps.
    Capacitors are mainly used as filters, low, high frequency signals, mainly on the B+ lines, with the values changing with location to the components, such as regulators, ASICS and the like.
    SFO likes this.
  10. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Maybe between @SFO and i we could work something out;).
    He’s probably on borrowed time with his 2007 and the combo meter:cool:.
    Might be good practice (y).
    #190 Raytheeagle, Jan 12, 2019
    PriusPaddler, SFO and JC91006 like this.
  11. JC91006
    16,936
    8,647
    That would be great, just be extra careful and don't break the air vents when you remove them. And put a towel on the steering wheel, so you don't scrap it up when you pull the dash in and out
    Raytheeagle and SFO like this.
  12. Barry Hines
    Barry Hines New Member
    Port Orchard, WA
    This can be completed by using the videos on YouTube. There are several very helpful ones. Its a really cheap fix if you just replace the capacitor.
    This video shows you how to remove everything carefully.
    This video shows you how to replace the capacitor.
  13. dolj
    dolj Senior Member
    8,645
    4,395
    Wellington, New Zealand
    In the original post where this video was published, comment was made by an electronics technician that it was a bad idea to piggy back (connect in parallel) a second cap as shown in this video. The better method is to remove the bad cap and replace it with a new one. It is also better to replace it with a cap of higher capacitance, the details of which maybe contained elsewhere in this thread, but definitely in this thread. Also of note, is that at least two other caps should be replaced for a more robust repair. Again details are in the other thread.
  14. cooscoos
    cooscoos New Member
    Knoxville, TN
    Do I need to unplug the 12v battery to remove the cluster? It seems like yes but I saw two youtube vids and neither mentions to disconnect the 12v battery.
  15. dolj
    dolj Senior Member
    8,645
    4,395
    As long as the car is IG-OFF, you should need to, but you can if it makes you uncomfortable to leave it connected.
  16. Patrick Wong
    18,210
    6,517
    Yes. You should always remove 12V power before you mess around with disconnecting electrical circuits. In this particular case you also have to disconnect and remove the passenger-side airbag, which is more reason to make sure no 12V power is present before you start.
    donbright and SFO like this.
  17. obiejon12
    obiejon12 Junior Member
    Virginia
    I'd just like to weigh in and say I successfully did this repair... like other posters said it takes most of a day. There are a lot of very annoying steps, like taking the side curtain panels off. You'll need a very long extension arm for a socket wrench to unscrew underneath the airbag. Just so you all know my experience level... close to zero. So it is possible for beginners! I used the same video as post #193. I removed the capacitor and tried to apply the new capacitor straight onto the pcb but I was concerned I didn't have a good connection. So I soldered some wire to the PCB and then the other ends of the wire to the capacitor, not directly to the board. I haven't had a single problem with the meter since.
  18. Phil Stasik
    Phil Stasik Junior Member
    Merritt Island, Florida
    I would like to add another testimonial to Matt at Texas Hybrid Batteries, and the DIY replacement of my (217 K miles) 2004 Prius' Combination Meter. I really appreciated Patrick Wong's posts, which made this project easier, and cleaner. I found, as he did, that the original circuit board seemed to suffer from sloppy workmanship -- but I'm not an expert in this field. I'll try to upload photos of this. The whole project took most of a day, but I always like to clean areas that have not been exposed since manufacture, especially the cabin air filter and fan assembly and its ducting. Nothing broke -- thanks to the good advice of all of you on this thread. I'm really glad that I bought a "plastic crow bar" trim removal set to gently pop the car's interior panels apart gently and easily. The video on this thread is wonderful, and my sincere thanks to the gentleman who produced it. I took plenty of time to thoroughly clean the glass and mirror that reflects the display information to the driver's view. The failure of my CM was slow and became very frustrating, and the new unit has been working flawlessly. I also took the time to fix the long-broken glovebox opener spring with JB Weld, and removed the paint from the glovebox push buttons that looks so disreputable on older Prius' It's like having a new car. We have loved our Prius since we bought it new 15 years ago. This project looks daunting, but is merely a low-tech, step by step process -- as long as nothing breaks! Original Prius CM Back.jpg Original Prius CM Close-up.jpg Original Prius CM Front.jpg
  19. FLA$H
    FLA$H New Member
    HERE
    Would anyone happen to still have the original CAPACITOR
    because I lost mine after replacing it and I would like to use
    the original to see how long it will last.
    I just need the HEIGHT & WIDTH.
    Thanks
  20. Phil Stasik
    I'm sorry FLA$H, I returned the original board to Texas Hybrid Batteries. You should reach out to them.
    By the way, it's been about a month and a half (500 miles), since I installed the Texas Hybrid Batteries replacement CM, and everything has been operating perfectly. They were also very prompt at providing credit for the core return. They even payed for the return postage.
    #200 Phil Stasik, Mar 10, 2019
