combination meter repair - DIY
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ultanium, Jan 20, 2016.
  1. 2006_HK
    2006_HK First Hybrid
    74
    Santa Clara, CA
    I would imagine that the handshake would still be an issue if I extract the PCB and just replace it? How are people able to order replacement PCBs and get it to work if that is the case?
  2. pasadena_commut
    pasadena_commut Senior Member
    3,076
    956
    Southern California
    I don't know the details, but since we know they must program in the odometer reading my best guess is that they also program in the VIN, or some cryptographic hash of it. There is also the possibility that there is no such VIN checking and something is wrong with the (re)installation, like a loose or omitted cable connection, or the replacement combination meter might be defective.
  3. Mr._Mulligan
    Mr._Mulligan New Member
    Riverside, CA
    I had this problem with my 2008 Prius in February, this year. So, I replaced all three capacitors. The problem went away. Now, it has returned. Could it be the same three capacitors again, or something else? How would I diagnose the issue?
  4. pasadena_commut
    3,076
    956
    Southern California
    It could be the replacement capacitors, especially if you used old capacitors (long past manufacturing date, or recycled from another device ) or piggy backed them on the originals and left those in. To show definitively that the capacitors are bad you would need test equipment to measure the capacitance and the ESR. Bet you don't have either - I don't. You would probably have to take at least one pin out of the board to test them, and at that point, you might as well just put new ones in, as even top of the line ones are not expensive at that size. There is a remote chance that the capacitors might have bulged or burst, but having that happen in under a year would be really, really, really unusual, even for a really poorly made capacitor.
    I would also suggest carefully inspecting the board near where the work was done to make sure there isn't a stray blob of solder, a pad lifting up, a scorched component from an errant soldering iron touch, or that sort of thing.
    Mr._Mulligan likes this.
  5. Mr._Mulligan
    Riverside, CA
    OK, thanks. I have the replacement capacitors in hand. I also got the voltage regulator. Just need to set aside a day to do this.
    I was wondering if a low 12V battery could also cause this issue? When I tested it, it was a bit low. 11.8V. It dropped to 11.1V when the headlights were turned on. Then, with the engine running, 13.8V. Since it is due for replacement, maybe I just do it, and see if the speedometer display issue improves.
  6. pasadena_commut
    3,076
    956
    Southern California
    This was measured at the battery or the jump post with a voltmeter? 11.8 V is pretty low for this battery type. They seem to lose capacity easily when discharged that far. Oddly though, 13.8V when the motor is on indicates a not so bad battery. The 12V in my car has maybe 7Ah capacity, and when the car is running it reads 14.10 V once it settles down. (It starts at 14.5 or 14.4 then drops to 14.3 then 14.2 then finally to 14.1 over 10 seconds or so. The higher that voltage the worse the 12V, so by that metric, your battery is in better shape than mine. I recently had a chance to measure battery voltage on my car when it was sitting unlocked and unused (other than the back doors opening a couple of times each day, left the hood unlatched the whole time) and it was losing about .05V per day. It would probably lose more if it was locked, as the built in alarm system would then also be active.
    I'm trying to think of why the battery would matter for the display once the car is going. The combination meter will be seeing that 13.8V, which should be plenty. The only thing I can think of would be the combination meter electronics going into a funny state when the 12V is low when the car first turns on and never coming out of it. Possible, but seems unlikely.
    If you have access to a battery charger it would be a good idea to charge this one up. If you want the car to do it it might take hours to get to a full charge. Easier to let it charge overnight, assuming you have the equipment and a place to do this.
    gdanner likes this.
  7. Mr._Mulligan
    Riverside, CA
    I measured the voltage using the built-in check, via the combination display. Is it not accurate?
    I do have a battery charger. How do I charge the battery? Via the jump start terminal under the hood?
  8. dolj
    dolj Senior Member
    8,657
    4,407
    Wellington, New Zealand
    No, if anything it helps to hide the issue.
    I don't know why exactly, but observations by many people over several years demonstrate the higher voltage of a new battery exacerbates the CM start-up failure.
    #388 dolj, Dec 3, 2024
  9. Mr._Mulligan
    Riverside, CA
    OK, thanks. Interesting thing this morning. So, the combo meter was blank this morning, as it has been consistently whenever it gets cold. I immediately turned off the car and connected a battery charger to the jump start connector. The combo meter was illuminated when I started the car again. Perhaps it would have been the same if I hadn't connected the charger. No way to know. I'll keep running this experiment every morning. If it repeats, then it may just be a low 12V battery.
  10. pasadena_commut
    3,076
    956
    Southern California
    In theory either at the jump start or on the terminals at the battery. In practice the Battery Tender Jr. and Harbor Freight 4A battery charger (63350) I own both give up far too early at the jump point on my 2007. I have no idea why. So I use them directly on the battery terminals, usually with the wires that plug in at the gizmo on the positive post disconnected. Then they both work like they should.
    Note, with these chargers and probably many others it is essential that the surface charge be removed before starting to charge or they misinterpret the high voltage as the battery being more charged than it actually is. In some cases they will go straight to "maintenance mode" without doing any real battery charging. If charging is interrupted for any reason the surface charge has to be removed again.
  11. Mr._Mulligan
    Riverside, CA
    This morning, I connected the battery charger and started the car. Dark combo meter. So, battery level doesn't appears to be the root cause. It does seem to contribute somewhat in that the combo meter came on after a couple of tries. Without the battery charger, it would have stayed dark until it's fully warmed up, like in 10 minutes of driving.
  12. Mr._Mulligan
    Riverside, CA
    I've been putting off doing the capacitor replacement while I worked on a head gasket replacement on my 09 Corolla. The behavior of the combo meter is very consistent. If the morning temperature is 48F or below, it will be dark until it heats up, about 10 minutes into the drive. The display will light up during the drive as soon as it reached the right temperature.
    I'm hoping the higher quality capacitors I got from Mouser will solve this permanently. I got some no-name brand off Amazon for the fix I did last February. I also got the voltage regulator, but I'm nervous about swapping it out. I do have a hot air solderer, but I don't have a lot of experience removing and installing ICs.
  13. pasadena_commut
    3,076
    956
    Southern California
    I will solder through hole components, but I don't have the equipment for surface mount. Do you have a dissecting scope or some other good visual aid so that you can see the tiny pins clearly? A magnifying glass isn't going to cut it. If so, find some electronics board you can practice on where you can check that the result works. Perhaps something like an old MP3 player. Otherwise, call around to the Cell phone and laptop repair shops and see how much they would charge for the work. They do have the equipment and the experience to swap an IC, although I bet they don't do it very often, instead replacing parts at the board level.
    You could always swap the capacitors and see if that works. If it does, hold off on the IC swap.
  14. Mr._Mulligan
    Riverside, CA
    Yes, I think I will hold off on the IC swap and see if the capacitor swaps alone will fix the problem. If I have to open it up again, I'll do it again. I was just trying to avoid taking things all apart yet a third time.
    #394 Mr._Mulligan, Jan 2, 2025
  15. KitsuneVoss
    KitsuneVoss Member
    376
    55
    Virginia
    I seem to be having the worst luck with my 2006 with the cluster going out
    What is the best video that people know for disassembling the dash to get to the cluster?
    One I watched super speeds the disassembly.
    Also, it pretty cold, making me worried about breaking the vents. Thinking about putting a space heater on low in the car to hopefully warm up the interior before taking it apart. Has anyone tried that? I do have a brand new left center vent mounting if that is the one most likely to break.
  16. pasadena_commut
    3,076
    956
    Southern California
    Turn the speed down in the playback.
    A space heater would likely be overkill in that small a space. Why not just drive the car until it is warmed up then run the heat on high for a while? Warming them up might help a little, but given the age of the plastic, odds are some tabs are going to snap regardless. If some break there are aftermarket replacement vents available. For instance, go to Amazon and enter "Prius vents" in the search field. Of course they come from China and can be had from a large number of "who are they?" vendors on AliExpress, usually for less but with a longer delivery time.
  17. KitsuneVoss
    KitsuneVoss Member
    376
    55
    Virginia
    Having a small heater in the car actually made a more pleasant work environment.
    I did find a good video although he did not try to repair the cluster.
    I was able to get the cluster out but badly broke the center two vents although the furthest left one only got a single minor crack and no damage to the one furthest to the right. Did not even take it out to be honest and did not seem to need to. Had a spare one where the shifter is mounted from when I cracked the one on my 2009 but never took the dash apart to replace it. Only actually need the center right one. Have not found any for sale for less than either getting both center or getting even all four.
    My roommate, used to be a professional in repairing electronics when they involved soldering, was able to solder a new capacitor on the board, a 220 uF instead of 100 uF as many recommend. Was actually trying to solder it one perfectly with cutting almost the entire lead off but we both don't have the proper tools and she is getting a little older. Finally just decided to solder with extended leads.
    The repaired board works although need to take apart the dash because I think I missed a wire because the gas gauge is flashing. Saw there was already a thread on it. At least I have a speedometer, can use cruise control, and have the range on the touch screen which lets me estimate when I need to refuel.
    #397 KitsuneVoss, Jan 11, 2025
  18. jonsey1886
    jonsey1886 Junior Member
    Roanoke
    It’s been a few years since this list was posted and the original regulator chip isn’t made as it was superseded, but everything else is still the same. All links are to Mouser now but can probably be found on DigiKey, RS in TX,USA, etc.
    New Shopping List as of 1.12.25
    From Post #3 the regulator chip is an Infineon TLE4278GXUMA3 5V Low Drop Fixed Voltage Regulator. Link.
    From Post #46 the upgraded 16V 220uF Cap that Toyota is using is a Nichicon UUD series. (Nichicon UUD1C221MCL1GS) Link
    From Post #34 the other 2 Caps are 35V 10uF and 330uF, you can choose which ever brand you like but we use Panasonics.
    10uF (Panasonic EEE-HA1V100R) Link. 330uF (Panasonic EEE-HA1V331P) Link.
    Still ~$13 US with default shipping
    #398 jonsey1886, Jan 12, 2025
    deekaljin and Mr._Mulligan like this.
  19. Mr._Mulligan
    Riverside, CA
    What would be the occasion to change the voltage regulator chip? Is there a particular symptom?
  20. Mr._Mulligan
    Riverside, CA
    I went ahead and did this fix today. I did it a year ago, but it didn't last. Anytime the temperature drops below 48F, I don't have a display until it warms up about 10 minutes into the drive.
    One thing I noticed is that the new Panasonic caps I got are bigger than the ones I put in a year ago. Here is a comparison of the three caps.
    Also, the LCD had dark burn marks in the corner that I don't recall from last time.
