combination meter repair - DIY
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ultanium, Jan 20, 2016.
  1. Emily K
    Emily K New Member
    Greensboro, NC
    Hi Talonts,
    Sorry I'm late to the party but my CM problem has just gone from intermittent to constant. I'm really not in a place where I can spend $800 at a dealership to get the problem fixed so I was hoping you might still have the 06-09 meter you grabbed at the salvage?
  2. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    2018 is a new year, and could be time to share your secret.
    Raytheeagle likes this.
  3. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    contact texas hybrids, matt has a very good rep here, i used one of his rebuilt meter on my 08 and its been perfect .. an hour to put it in myself and only cost 175 free shipping both way.
    PriusPaddler, m.wynn and Raytheeagle like this.
  4. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
  5. Beachbummm
    1,160
    392
    if he is repairing the cars speedo he doesn't have to reprogram the miles .. its only when you replace it with another one the miles have to be programed, IDK what parts he replaces, if its just the 2 caps shown on youtube I doubt the repair will last.. I went with Matts service because it has a life time warrantee
  6. BigVanMan
    BigVanMan Junior Member
    27
    28
    Manchester, NH
    Update on the previous repair to my 2007 combination meter. Everything still working after 5 months and about 7k miles. My wife's 2004 just started to have the same symptoms so removed and repaired her combination meter as well. This time, I have an ESR meter and confirmed that the 10uF cap was the culprit. Readings were well below 1uF and resistance was 13 ohms. Even though only one capacitor identified as bad, I replaced all 3 capacitors as well as changed out the regulator. IMHO, that is the right way to repair things since all capacitors were the same age. Even the 330uF appeared to bulge some.
    Started to see ads on Craigslist as well advertising repair for the combination meters around Boston for $200. Just hope they replace all the capacitors and regulator as well.
    PriusPaddler likes this.
  7. Fabrizio Pinzan
    Fabrizio Pinzan New Member
    Italy
    for all the interested and not intended to DIY, overall for Europeans, I repair the combo boards - 100eur - repair of your boards (not a swap)
  8. Fabrizio Pinzan
    Italy
    now there is!
  9. Hypno72
    Hypno72 Junior Member
    SC
    Four Touring
  10. dolj
    dolj Senior Member
    8,633
    4,386
    Wellington, New Zealand
    You realise this is not a fix, but a work around, don't you? Eventually this work around will work less and less. At that point you will need to get the combination meter (CM) fixed.
    valde3 likes this.
  11. NeuroJosh
    NeuroJosh Junior Member
    Indiana
    Kudos to TexasNative, especially post #71! I replaced the 3 caps in my '09 Prius with the recommended ones from Mouser, and it's running fine now! I didn't bother replacing the 5V regulator. I did use the 220 uF cap instead of the original 100 uF.
    giorgioYe and pilotgrrl like this.
  12. giorgioYe
    giorgioYe New Member
    Milano
    I welded an 470uF 35V capacitor from my washing machine and hope everything goes well.
  13. giorgioYe
    Milano
    this is the original instruction
    PriusPaddler and VFerdman like this.
  14. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    good welding
    giorgioYe likes this.
  15. LEVE
    LEVE Member
    191
    97
    On the Willapa
    Good on you for getting the meter working, however, that said, the OEM capacitor may be a problem in the future. It's not good electronics practice to:
    • Check capacitance while the capacitor is in the circuit.
    • Parallel a good capacitor with a known bad, or failing, capacitor.
    IMHO, it would be a good idea to remove the failing capacitor from the PCB and solder in a known good capacitor. Otherwise, I think it will be a possible point of failure in the future.
    #135 LEVE, May 31, 2018
    edthefox5, giorgioYe and VFerdman like this.
  16. giorgioYe
    Milano
    I found a difference betwen European CM and USA CM.
    The European ones don't have that small socket.
    Patrick Wong likes this.
  17. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Good one LEVE. Paralleling a capacitor that's already esr'ing is a guaranteed fail.
  18. beezerhale
    beezerhale Junior Member
    US
    Quick question ... I hope I didn't overlook the answer here. I am planning on sending my combination meter in for repair. Will the Prius function (run errands with me) while the meter is out being repaired or am I car-less in the meantime?
  19. drew935
    drew935 Member
    168
    23
    Nor Cal
    Yes, you can drive it. You just won't have any indication of gear and speed.
    PriusPaddler and beezerhale like this.
  20. beezerhale
    US
    Thank you! I plan to drive it to the auto paint place to have some work done. They'll need it a few days. I figure I can double up - send the meter out for repair while the paint guys have my car.
