combination meter/speedometer replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mcbooster, May 17, 2016.
  1. mcbooster
    mcbooster Junior Member
    Just did my 2007 combination meter using this video
    and sending it to Speedometer Repair guy in MN for $115
  2. Brandonholohibrido
    Brandonholohibrido Junior Member
    65
    Houston, TX
    SO the speedometer cost $115? or the labor?
  3. mcbooster
    That is repairing your old combination meter. $115 plus shipping. He had it back in 2 days and it works great so far. Lifetime warranty also
  4. Planet Awesum
    Planet Awesum Junior Member
    26
    32
    Portland, Oregon
    I did this and it worked, after having the red triangle on dash and touch screen . I had just replaced the combination meter. Having it repaired by someone in Arkansas for $90 off eBay. You can drive without the combination meter. I did for about a month total and didn't miss it. Just have to keep it filled w gas cause you won't know how low you are. Everything works fine without the combination meter. Make sure to plug everything back in securely. I had to put it in and take it out about 6 times till I got it right.
    "04-09 Prius procedure. Disable SMART KEY (button that says KEY under steering column), and insert key fob transponder into slot in dash. With foot on brake, push power button and hold the power button in for 30 seconds. Release power button and try to restart."
  5. Planet Awesum
    26
    32
    Portland, Oregon
    All the lights , triangles , beeps and vsc and everything will come on when your done and freak you out. Just do the reset thing above and they'll go off. Also drive it some to get gas meters back into play because it'll probably flash empty.
  6. Markavelee
    Markavelee Junior Member
    25
    Caribbean
    Can anyone assist I have a Gen 3 with the same issue, Gas guage, Speedometer and Gear indicator cluster went out, which part number should I replace, please see attached pics
  7. mr_guy_mann
    mr_guy_mann Senior Member
    4,113
    2,011
    NJ-USA
    No idea. Perhaps someone in the Gen3 forums knows, might want to post your question there.
  8. ChapmanF
    19,016
    Like Gen 2, Gen 3 projects those indicators from below. Guessing from that diagram, my guess would be 83247 (or maybe 83134B?), whichever one is described as a meter circuit board or circuit plate or some such description in the list of parts.
