Combination Meters that stop at 299,999 miles, Who's affected and what you can do about it.
Discussion in 'Gen 2 Prius Main Forum' started by Texas Hybrid Batteries, Jan 10, 2017.
  1. OBJUAN
    OBJUAN Member
    165
    78
    canada
    ITBland has as chart to move the 6 wires on M13 into the newer MFD configuration.
    thread: Will 86110-47230 work instead of 86110-47081 in 2005 Base Model?
    If you are putting in a backup OEM camera, you'll need the REV+ line on pin 21. The best place I found was to use IJ3 pin 22 behind the glove box. I just cut it off, there was no pin on the male jack anyway (base 2005), then solder and heat shrink a jumper for M13-21. My new MFD is a 86110-47210, old was 86110-47081. I cut the hole in the hatch for the camera yesterday, waiting on some shielded wire for the camera. Still needs some cabling between MFD M14 and stereo to make the bluetooth work. Map light Console with Mic for the bluetooth and a garage door opener mirror was shipped today. Still a ways to go.......but its do-able... good luck
    ITBland likes this.
  2. OBJUAN
    OBJUAN Member
    165
    78
    canada
    If you haven't found the answer to this question, Will 86110-47230 work instead of 86110-47081 in 2005 Base Model? | PriusChat
    With ITBlands info I put a 47210 MFD and camera into my 05. Working on the combo meter now......
  3. Sunger
    Sunger New Member
    Arizona
    @Texas Hybrid Batteries I know this is an old thread and hoping you're still on the forums. Where did you purchase the right side cluster? I've been trying to find it and I cannot find anywhere that carries them.
  4. dolj
    dolj Senior Member
    8,439
    4,288
    Wellington, New Zealand
    Click the user link in your post above and then click on "Start a Conversation" on the pop-up that appears.
    Matt sells refurbished combination meters and light clusters, so you will be able to get everything you need to sort out your issues.
    #44 dolj, Nov 24, 2019
    m.wynn and jerrymildred like this.
  5. Prodigyplace
    12,548
    11,772
    Central Virginia
    Try here?
    Prius Speedometer Replacement
    Raytheeagle and jerrymildred like this.
  6. OBJUAN
    OBJUAN Member
    165
    78
    canada
    got mine from a 2009 donor car at a wrecker...
  7. Haskins
    Haskins New Member
    Are these still available for purchase?
  8. dolj
    dolj Senior Member
    8,439
    4,288
    Haskins likes this.
  9. Michciu94
    Michciu94 Junior Member
    44
    Poland
    Hello. My odometer stuck. Ive got full assembler from 2009 Prius - it is plug and play (after delete tpms light) or the harness is different?
  10. dolj
    dolj Senior Member
    8,439
    4,288
    You need to replace the light cluster and the combination meter when you use a 2006-2009 light cluster/combination meter combo into a 2004-2005 Gen 2. If you do both (removing the TPMS LED as you note) then yes, it is plug and play.
  11. Michciu94
    44
    Poland
    I posted photo. I just need to remove entire and just put those cluster or I have to change odometer and lights ?
  12. dolj
    dolj Senior Member
    8,439
    4,288
    I'm not sure what you're asking maybe some detail has been lost in translation.
    But you need to remove the 2005 light cluster and the combination meter then install the 2009 light cluster and combination meter. The 2009 light cluster will need the TPMS LED removed before installation.
  13. Michciu94
    44
    Poland
    At post 49 I show photo - it is 2009 assembly with harness. Can I disassembly old and just put in this whole part or I need to just replace odo and claster light to old part?
  14. dolj
    dolj Senior Member
    8,439
    4,288
    I don't know sorry and I don't recognize the parts in the photo. Maybe someone like @jerrymildred might have hands-on experience with the process and could help.
    Having said that, I can't imagine that with having the parts from the 2009 in hand, it would be that difficult to work out how it goes together once you start removing the 2004 parts.
    #54 dolj, Sep 28, 2022
  15. jerrymildred
    jerrymildred Senior Member
    11,517
    14,150
    Tampa, FL
    I don't think I can give the kind of help that's needed. I've replaced several combo meters but never opened up the dash next to it to remove any indicator lights. I don't know if the housing for the light panel is glued together or not. Here's a good video on replacing the combo meter.
    Once you get it out of the car, you can investigate the possibility of opening it up and performing surgery on it. I could check our spare parts, but we're shut down for a hurricane right now. Then we're leaving on a two week vacation. But I do remember seeing some screws, so it might open up.
  16. Texas Hybrid Batteries
    Texas Hybrid Batteries Senior Member
    271
    563
    Dallas -Fort Worth
    @Michciu94 You can put that whole unit (the picture in post #49) directly into your 04 or 05. Remove the wire harness, you don't need that. Just use the one in the car. It's all pug and play and will work fine with the exception of the TPMS light being on.
    To deal with the TPMS light there are pictures posted earlier in this thread that show how to remove that light if you want to do it.
    Remember that the odometer will still have the miles or km from the 2009 Prius which it came from.
    jerrymildred likes this.
  17. ChapmanF
    18,149
  18. Texas Hybrid Batteries
    271
    563
    Dallas -Fort Worth
  19. Michciu94
    44
    Poland
    Hello. I have 2005 Prius Europe and my odometer stuck. I bought odometer from 2007 - after lifting, it has ,,ready” icon etc but don’t have TPMS icon. Will il work without problem with 2005?
  20. dolj
    dolj Senior Member
    8,439
    4,288
    Are you sure, I would have thought it would be the other way around? The 2004-2005 did not have TPMS, so no TPMS light. TPMS was introduced in the 2006-2009 facelift, so it should have the TPMS light.
    I don't think that would be different in Europe.
