Commercial aircraft mishaps
Discussion in 'Fred's House of Pancakes' started by tochatihu, Feb 17, 2025.
  1. PriusCamper
    PriusCamper Senior Member
    13,375
    5,407
    Pacific Northwest, USA
    Yeah... Saw that one dude's video on Tik-tok where he's filming his escape from the upside down plane and then walking around the wreck saying something like: "Wow, I was just on an airplane and now I'm not." It's amazing how everyone has such a high quality camera these days.
  2. Prodigyplace
    12,709
    11,847
    Central Virginia
    I think the rear landing gear is visible in this video.
  3. PriusCamper
    13,375
    5,407
    If you look at your video you can clearly see that the landing gear under the wings took the full force of the impact and failed, which changed the aerodynamic forces on the wings causing the plane to flip over.
    MAX2 and Prodigyplace like this.
  4. PriusCamper
    13,375
    5,407
    The plane clearly lost lift or was pushed downward or both by the wind forcing it to touch its wheels down with a massive amount of forcing causing the landing gear to fail and the plane to lose control.
    I agree that there no side to side motion with the wind, maybe a sudden downdraft though, or maybe sensors gave a bad reading on how far from the ground the plane was.
  5. ColoradoBoo
    ColoradoBoo Senior Member
    1,327
    947
    Monument, Colorado USA
    Yes, very scary to watch....almost looked like the pilot was trying to land it hard, like on an aircraft carrier, but probably due to the high winds.
    It, really, is a miracle nobody died, thank-you Jesus!!
    Prodigyplace likes this.
  6. ETC(SS)
    7,475
    I'm getting a lot of differing reports.
    Some saying that cross winds were no factor, and others suggesting that there were fairly brisk winds 30-ish degrees off the nose..
    One drive-by mentioned that the RJ came in like the Space Shuttle and the right gear folded up.
    We'll know 'all the things' soon enough.
    There's probably not going to be much daylight between the initial and final accident reports - nor very many unanswered questions.
  7. Prodigyplace
    12,709
    11,847
    Central Virginia
    In the video I posted, both gear look down. Perhaps one was not locked in place though.
  8. frodoz737
    frodoz737 Top Wrench
    4,790
    2,554
    33
    Perhaps...we should wait for the official report to be made.
  9. bisco
    52,747
    yes, let's not speculate here on priuschat, we only deal in facts :whistle:
  10. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    The right landing gear is missing. It either immediately collapsed upon touching the ground, or was torn off along with the right wing.
  11. tochatihu
    tochatihu Senior Member
    9,931
    3,842
    Kunming Yunnan China
    2001 Prius
    We have a particular poster asking for pause until experts figure it all out. This is reasonable but at the same time, a different skin for this poster to wear.
    This mishapped airplane landed under difficult conditions and possibly without all their hardware working well. Recognizing own personal limitations, I can't imagine setting aside options of going around or going to a different airport for landing. I spoke up about crosswind landings on snow.
    NTSB will finish this discussion as they do all. I hope they find that crosswind landings on snow should have lower limits, and I do not at all apologize for saying so.
  12. tochatihu
    9,931
    3,842
    2001 Prius
    Mishap airplane based on what we seem to know now had an unusually high rate of vertical descent until ground contact. That is not normal.
    MAX2 likes this.
  13. rjparker
    rjparker Tu Humilde Sirviente
    10,953
    6,872
    Texas Hill Country
    Our NTSB won't investigate in Canada. Canada will unless we go to war with them.
    The telemetry indicates the the plane stayed under the 1000 ft/min descent rate.
    I hate those small commuter jets in any weather. Most of the time there are no options on certain routes.
  14. tochatihu
    9,931
    3,842
    2001 Prius
    “The NTSB is leading a team of U.S. investigators to assist the Transportation Safety Board of Canada with their investigation of today’s accident of a Delta Air Lines Bombardier CRJ-900 at Toronto Pearson International Airport,” said an NTSB Spokesperson.
    US airline and departure point. Standard procedure to co investigate. When NTSB has something in written it will be filed under
    DCA25WA127
    #34 tochatihu, Feb 19, 2025
  15. bwilson4web
    16,507
    My understanding is 40° from right cross wind with gusts variations of 10 knots. Also landing at very end of the runway instead of past the numbers.
    It is entirely possible the wind gusted down at the final moments and there was insufficient time and altitude to correct. Slightly crabbed for the crosswind, the plane right wheel missed touchdown on the pavement to the right. The wheel sank in the dirt and ripped the gear and wing off. The other wing, not damaged, flew the plane over, upside down. Ripping off the right wing meant the subsequent fuel fire was well away from the fuselage.
    Source:
  16. ETC(SS)
    7,475
    Same.
    I fix phones for a living and I'm not even an expert in THAT field - but I didn't see the plane flair out before they got to the runway............... AND 'my lying' eyes.....
    DARNED good job by Bombardier for building a tube (didn't want to look up how to spell fuselage) that kept all of the squishy cargo inside during the crash!!!
    Second recent hull-loss accident for this...type? Series?
    AND for the operator???
    IF SO.....that's gonna cost them!
    (and US)
    I may not be a very good dial tone technician, OR ANY kind of aviator but I AM a fairly decent convoy commander.
    We always do a series of 'briefs' before each convoy.
    Every convoy brief begins with a Safety Brief.
    Every Convoy Safety Brief begins with the SAME opening statement:
    GOOD drivers do NOT get into accidents!
    Period.
    Full Stop.
    Chalk the tires.
    If this seems less than 'fair' then before board a plane ask yourself if you would rather have a GOOD pilot or a LUCKY one?
    YOU get to pick!
    In the submarine community, we did that coin flip in the 1940's.
    YMMV
    #36 ETC(SS), Feb 19, 2025
  17. Prodigyplace
    12,709
    11,847
    Central Virginia
    Remember too, unlike many crashes, the cockpit crew survived so they can me interviewed as part of the investigation too. Many times the crew does not survive an incident like this.
    ETC(SS) likes this.
  18. Prodigyplace
    12,709
    11,847
    Central Virginia
    A Canadian company. The doors did not fall off like US based Boeing... ;)
    ETC(SS) likes this.
  19. bwilson4web
    16,507
    If the wind gusts faded, the jet would have lost airspeed faster than it could recover.
    I had something like that landing at night. A strong head wind disappeared as I descended to the leveled, lighted runway. I recognized it fast enough to lower the nose and using my landing light, flair on the unlighted part of the runway at Hyde Field. Not lighted because it has a small upslope and I nailed it. But then that was my home field.
  20. Leadfoot J. McCoalroller
    8,260
    7,763
    Pennsylvania
    2018 Prius c
    NTSB is frequently called in to assist with crashes in rest-of-world and it would seem to be because they're the very best people available for the task.
    Note that the CRJ is a Canadian product; they were all built in Montreal and have maple-scented air freshener trees hanging from the compass.
    So it should tell you something when you hear about Canadian accident investigators asking the US NTSB to come help out with a Canadian airplane broken at a Canadian airport.
    I don't love traveling in CRJs but I'm in them all the dang time. (Of note to other potential passengers: you want the -550 version, it's the least uncomfortable one)
    A CRJ is Mrs. McCoalroller's office, she's been aboard those for most of two decades now.
