Common 2G Problems, and What to Do About Them...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Patrick Wong, Mar 6, 2009.
  1. Hank Dietz
    Hank Dietz New Member
    Lexington, KY
    My daughter was driving my 2006 Prius when she heard a short sound and dash lights for problem came on, so she pulled over and stopped. After restarting, the car barely moved, so she turned it off again. When I arrived about 15 minutes later, I was able to start the car and drive it the few miles to home, and parked it outside. The rear seat fan was running full force -- even after sitting for a while, it turns on full force within 30s if I turn the car on. Here's what the displays show:
    One of the tire pressure sensors died and hasn't been replaced, so that means nothing. Anyway, it's hard to read, but the car does have just over 184,000 miles -- all on the original battery pack.
    So, I'm suspect the battery pack is dead. Two questions:
    1. Should I just have somebody (e.g., Green Bean) come out and replace the battery pack?
    2. Should I take it to the dealer to get things checked first and, if so, should I get it towed there?
    Basically, I'd really just like this car to last another six months or so and I don't do any maintenance on it myself -- it's been all dealership serviced. The only regular problem for it has been burning a bit of oil, but next scheduled maintenance is at 186,000.
  2. Stoner
    Stoner Junior Member
    45
    Naples, Florida
  3. Stoner
    45
    Naples, Florida
    Hello...I'm new with chat and don't know all the acronyms you and others, are using.
    Could you please direct me to an acronym library or spell them out at least once, in your fine post?
    Much appreciated by all of us newbies.
    Stoner
    RacerX likes this.
  4. padroo
    padroo Senior Member
    2,763
    2,252
    Don't feel bad, they still make me scratch my head of some of them.
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,153
    Tampa, FL
    Sorry, but this sounds a lot like like a failed traction battery. You'll need to have the codes read to be sure, though. There are other possibilities. The best case would be a bad inverter coolant pump. If the dealer is within a couple miles and the streets are low speed, you could try limping over there, but towing is safer since it could just quit on you in that condition.
    Raytheeagle likes this.
  6. Patrick Wong
    18,210
    6,511
    Hi Stoner,
    If you compile a list of the acronyms that require definition, I will endeavor to tell you what they mean.
  7. Stoner
    45
    Naples, Florida
    Thanks, will do!
    Stoner
  8. padroo
    2,763
    2,252
    Actually there needs to be two groups of acronyms.
    One list for internet slang acronyms.
    The second list pertaining the actual car acronyms.
    Here is the list on the Prius.
    [​IMG] "A"[/paste:font]
    A
    Amperes
    ABS
    Anti-Lock Brakes
    ABRS
    Air Bag Restraint System
    AC
    Alternating Current
    A/C
    Air Conditioning
    ACCS
    A/C Cycling Switch
    ACCUM
    Accumulator
    ACCY
    Accessory
    ACT
    Air Charge Temperature Sensor
    ADJ
    Adjust or Adjustable
    ADV
    Advance
    AFS
    Airflow Sensor
    AI
    Air Injection
    AIR or A.I.R.
    Air Injection Reactor
    AIS
    Air Injection System
    Alt.
    Alternator or Altitude
    Amp./amp/amps
    Ampere
    ASCS
    Air Suction Control Solenoid
    ASD
    Auto Shutdown
    ASDM
    Air Bag System Diagnostic Module
    ASV
    Air Suction Valve
    A/T
    Automatic Transmission/Transaxle
    ATC
    Automatic Temperature Control
    ATDC
    After Top Dead Center
    ATF
    Automatic Transmission Fluid
    ATS
    Air Temperature Sensor
    Aux.
    Auxiliary
    Avg.
    Average
    AXOD
    Automatic Transaxle Overdrive (Ford Models Only)
    [​IMG] "B"[/paste:font]
    BAC
    By-Pass Air Control
    BAP
    Barometric Absolute Pressure Sensor
    BARO
    Barometric
    Batt.
    Battery
    Bbl.
    Barrel (Example: 4-Bbl.)
    BCM
    Body Control Module
    BHP
    Brake Horsepower
    BMAP
    Barometric and Manifold Absolute Pressure Sensor
    BOO
    Brake On-Off Switch
    B/P
    Backpressure
    BPS
    Barometric Pressure Sensor
    BPT
    Backpressure Transducer
    BTDC
    Before Top Dead Center
    BTSI
    Brake Transmission Shift Interlock
    BTU
    British Thermal Unit
    BVSV
    Bimetallic Vacuum Switching Valve
    [​IMG] "C"[/paste:font]
    ° C
    Celsius (Degrees)
    Calif.
    CANP
    Canister Purge
    CARB
    California Air Resources Board
    CAT
    Catalytic Converter
    CB
    Circuit Breaker
    CBD
    Closed Bowl Distributor
    cc
    cubic centimeter
    CCC
    Close Coupled Catalyst
    CCC
    Computer Command Control
    CCD
    Computer Controlled Dwell
    CCOT
    Cycling Clutch Orifice Tube
    CCW
    Counterclockwise
    CDI
    Capacitor Discharge Ignition
    CEC
    Computerized Engine Control
    CID
    Cubic Inch Displacement
    cm
    Centimeter
    CMP
    Camshaft Position Sensor
    CO
    Carbon Monoxide
    CO2
    Carbon Dioxide
    Cont.
    Continued
    CONV
    Convertible
    CP
    Canister Purge
    CKP
    Crankshaft Position Sensor
    CTS
    Coolant Temperature Sensor
    Cu. In.
    Cubic Inch
    CVC
    Constant Vacuum Control
    CV
    Check Valve or Constant Velocity
    CW
    Clockwise
    CYL or Cyl.
    Cylinder
    C3 I
    Computer Controlled Coil Ignition
    C4
    Computer Controlled Catalytic Converter
    [​IMG] "D"[/paste:font]
    "D"
    Drive
    DC
    Direct Current Or Discharge
    DDD
    Dual Diaphragm Distributor
    Def.
    Defrost
    Defog.
    Defogger
    DERM
    Diagnostic Energy Reserve Module
    DFI
    Digital Fuel Injection
    Diag.
    Diagnostic
    DTC
    Diagnostic Trouble Code
    DIC
    Driver Information Center
    DIS
    Distributorless Ignition System
    DIST
    Distribution
    DLC
    Data Link Connector
    DOC
    Diesel Oxidation Catalyst
    DOHC
    Double Overhead Cam
    DOT
    Department of Transportation
    DPF
    Diesel Particulate Filter
    DRB-II
    Diagnostic Readout Box
    DVOM
    Digital Volt-Ohmmeter
    [​IMG] "E"[/paste:font]
    EACV
    Electric Air Control Valve
    EATX
    Electronic Automatic Transaxle
    EBCM
    Electronic Brake Control Module
    EBL
    Electronic Back Light
    ECM
    Engine Control Module
    ECT
    Engine Coolant Temperature Sensor
    EDIS
    Electronic Distributorless Ignition System
    EEC
    Electronic Engine Control
    EECS
    Evaporative Emission Control System
    EEPROM
    Electronically Erasable PROM
    EFE
    Early Fuel Evaporation
    EGO
    Exhaust Gas Oxygen Sensor
    EGR
    Exhaust Gas Recirculation
    EOT
    Engine Oil Temperature
    ESA
    Electronic Spark Advance
    ESC
    Electronic Spark Control
    EST
    Electronic Spark Timing
    EVAP
    Fuel Evaporative System
    EVIC
    Electronic Vehicle Information Center
    EVP
    EGR Valve Position Sensor
    EWMA
    Exponentially Weighted Moving Average (MODE 6)
    Exc.
    Except
    [​IMG] "F"[/paste:font]
    ° F
    Fahrenheit (Degrees)
    F/B
    Fuse Block
    Fed.
    Federal
    FI
    Fuel Injection
    FICU
    Fuel Injection Control Unit
    FIPL
    Fuel Injector Pump Lever
    FLI
    Fuel Level Indicator
    FPR-VSV
    Fuel Pressure Regulator Vacuum Switching Valve
    Ft. Lbs.
    Foot Pounds
    FWD
    Front Wheel Drive
    [​IMG] "G"[/paste:font]
    g
    grams
    Gals.
    gallons
    GND or GRND
    Ground
    [​IMG] "H"[/paste:font]
    HAC
    High Altitude Compensation
    HC
    Hydrocarbons
    H/D
    Heavy Duty
    HO2S
    Heated Exhaust Gas Oxygen Sensor
    Hg
    Mercury
    Hgt.
    Height
    HLDT
    Headlight
    HO
    High Output
    HO2S
    Heated Oxygen Sensor
    HP
    High Performance
    HSC
    High Swirl Combustion
    HSO
    High Specific Output
    HTR
    Heater
    Hz
    Hertz (Cycles Per Second)
    [​IMG] "I"[/paste:font]
    IAC
    Idle Air Control
    IACV
    Idle Air Control Valve
    IAT
    Intake Air Temperature
    IC
    Integrated Circuit
    ID
    Identification
    I.D.
    Inside Diameter
    IFS
    Independant Front Suspension
    IFS
    Inertia Fuel Shutoff (Ford)
    Ign.
    Ignition
    IMRC
    Intake Manifold Runner Control
    In.
    Inches
    INCH Lbs.
    Inch Pounds
    in. Hg
    Inches of Mercury
    Inj.
    Injector
    IP
    Instrument Panel
    IRS
    Independant Rear Suspension
    ISC
    Idle Speed Control
    IVD
    Interactive Vehicle Dynamics (Ford)
    IVSV
    Idle Vacuum Switching Valve
    [​IMG] "J"[/paste:font]
    J/B
    Junction Block
    [​IMG] "K"[/paste:font]
    KAPWR
    Keep Alive Power
    k/ohms
    kilo-ohms (1000 ohms)
    kg
    Kilograms (weight)
    kg/cm2
    Kilograms Per Square Centimeter
    KM/H
    Kilometers Per Hour
    KOEO
    Key On, Engine Off
    KOER
    Key On, Engine Running
    KS
    Knock Sensor
    kW
    Kilowatt
    kV
    Kilovolt
    [​IMG] "L"[/paste:font]
    L
    Liter
    lbs. (Lbs. when used in table)
    Pounds
    LCD
    Liquid Crystal Display
    L/D
    Light Duty
    LDP
    Leak Detection Pump (Part of EVAP system.)
    LED
    Light Emitting Diode
    LH
    Left Hand
    [​IMG] "M"[/paste:font]
    mA
    Milliamps
    MA or MAF
    Mass Airflow
    MAFS
    Mass Airflow Sensor
    MAP
    MAT
    Manifold Air Temperature
    Mem.
    Memory
    MEM-CAL
    Memory Calibration Chip
    mfd.
    Microfarads
    MFI
    Multiport Fuel Injection
    MICU
    Multiplex Integrated Control Unit (Acura/Honda)
    MIL
    Malfunction Indicator Light
    MPI
    Multi-Point (Fuel) Injection
    mm
    Millimeters
    MPH
    Miles Per Hour
    mV
    Millivolts
    [​IMG] "N"[/paste:font]
    NA
    Not Available
    NAC
    NOx Adsorber Catalyst
    NCA
    No Color Available (Wiring Diagrams)
    NGS
    New Generation Star
    N.m
    Newton Meter
    No.
    Number
    Nos.
    Numbers
    NOx
    Oxides of Nitrogen
    [​IMG] "O"[/paste:font]
    O2
    Oxygen
    OBD
    On-Board Diagnostics
    OC
    Oxidation Catalyst
    OD
    Overdrive
    O.D.
    Outside Diameter
    OHC
    Overhead Camshaft
    OSS
    Output Speed Sensor
    O/S
    Oversize
    oz.
    Ounce
    ozs.
    Ounces
    [​IMG] "P"[/paste:font]
    "P"
    Park
    P/C
    Printed Circuit
    PCM
    Powertrain Control Module
    PCS
    Purge Control Solenoid
    PC-SOL
    PCV
    Positive Crankcase Ventilation
    PFI
    Port Fuel Injection
    PGM-FI
    Programmed Fuel Injection
    PID
    Parameter Identification
    PIP
    Profile Ignition Pick-up
    PNP
    Park Neutral Position Switch
    P/N
    Park/Neutral
    PRNDL
    Park Reverse Neutral Drive Low
    PROM
    Programmable Read-Only Memory
    psi
    Pounds Per Square Inch
    P/S
    Power Steering
    PSPS
    Power Steering Pressure Switch
    PTC
    Positive Temperature Coefficient
    PTO
    Power Take-Off
    Pts.
    Pints
    Pwr.
    Power
    [​IMG] "Q"[/paste:font]
    Qts.
    Quarts
    [​IMG] "R"[/paste:font]
    RABS
    Rear Anti-Lock Brake System
    RECIRC
    Recirculation
    RH
    Right Hand
    RPM
    Revolutions Per Minute
    RWAL
    Rear Wheel Anti-Lock Brake
    RWD
    Rear Wheel Drive
    [​IMG] "S"[/paste:font]
    SAS
    Steering Angle Sensor
    SBC
    Single Bed Converter
    SBEC
    Single Board Engine Controller
    SDARS
    Satellite Digital Audio Radio Service
    SES
    Service Engine Soon
    SFI
    Sequential (Port) Fuel Injection
    SIL
    Shift Indicator Light
    SIR
    Supplemental Inflatable Restraint
    SOHC
    Single Overhead Cam
    SOL or Sol.
    Solenoid
    SPFI
    Sequential Port Fuel Injection
    SPK
    Spark Control
    SPOUT
    Spark Output
    SRI
    Service Reminder Indicator
    SRS
    Supplemental Restraint System (Air Bag)
    STAR
    Self-Test Automatic Readout
    STO
    Self-Test Output
    SUB-O2
    Sub Oxygen Sensor
    Sw.
    Switch
    Sys.
    System
    [​IMG] "T"[/paste:font]
    TAB
    Thermactor Air By-Pass
    TAC
    Throttle Actuator Module
    TAD
    Thermactor Air Diverter
    TBC
    Body Control Module (General Motors)
    TBI
    Throttle Body Injection
    TCC
    Torque Converter Clutch
    TDC
    Top Dead Center
    Temp.
    Temperature
    TFI
    Thick Film Ignition
    THERMAC
    Thermostatic Air Cleaner
    TPM
    Tire Pressure Monitor
    TPMS
    Tire Pressure Monitor System
    TPS
    Throttle Position Sensor/Switch
    TS
    Temperature Sensor
    TV
    Thermovalve
    TWC
    Three-Way Catalyst
    [​IMG] "V"[/paste:font]
    Valve
    Vac.
    Vacuum
    VAF
    Vane Airflow
    VAPS
    Variable Assist Power Steering
    VCC
    Viscous Converter Clutch
    VCRM
    Variable Control Relay Module
    VIN
    Vehicle Identification Number
    VM
    Vacuum Modulator
    Volt.
    Voltage
    VOM
    Volt-Ohmmeter (Analog)
    VRV
    Vacuum Regulator Valve
    VSS
    Vehicle Speed Sensor
    VSV
    [​IMG] "W"[/paste:font]
    W/
    With
    W/O
    Without
    WAC
    Wide Open Throttle A/C Switch
    WOT
    Wide
  9. Stoner
    45
    Naples, Florida
    ah, very nice...thank you!
    Stoner
  10. KatHeath
    KatHeath New Member
    29
    Missouri
    Yes the battery always reads between 11 to 14
  11. KatHeath
    KatHeath New Member
    29
    Missouri
    Did they figure out the problem?
  12. jerrymildred
    11,517
    14,153
    Tampa, FL
    The post you're asking about is over 9-1/2 years old and that person only posted six times total. I imagine they are long gone.
    padroo and Raytheeagle like this.
  13. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    Sorry I can reread the question but if he dropping to 11v and the car charging it at 14v then on it a bad 12v battey
    padroo likes this.
  14. hybridheidi
    hybridheidi New Member
    Hi...I have a 2007 prius, bought used in 2013 from one owner. It got a new battery in 2012 and it's doing well. I took it in due to the combo meter issue and also had a diagnostic test done. They recommended new spark plugs, water pump, drive belt, and the combo meter as items that need immediate attention. They also said I need to change the lower control arms within 6 months or so, and hybrid battery cooling system filter, inverter coolant pump, control arm bushings, and stabilizer bar end links in the near future.
    My car is probably worth 1200 at trade in, and some more for private party. I'm not sure if I should fix all this, and possibly have more things to fix in the future that is not coming up now. Any suggestions/recommendations on whether to fix and keep or get a different car? If these are the only issues (estimating $2,700) and I can drive it for 300k miles, I'll keep it, but I don't know what else could happen and not sure what's the best action to take.
    The mechanic said he has a 2006 prius with 330K on it and it's doing great with the engine and everything, but then again, he probably took excellent care of the car, fixing it with any signs of problems while me, not so much. :/ Any insight is appreciated!
  15. jerrymildred
    11,517
    14,153
    Tampa, FL
    Welcome. I don't think anyone can say what you should do. I don't get too attached to stuff, so I doubt I'd invest that much in fixing all those issues. But I'll offer some thoughts on them. First, though, you said it got a new battery in 2012. But which battery? If it was the hybrid battery, was it new or rebuilt? Since it lasted this long, I'll guess new or else it was the 12V. If it was the 12V, you're still on the original traction battery so don't be surprised if it needs to be replaced soon.
    Combo meter - it is not hard or expensive to replace. You can get a rebuilt one from Matt at Prius Speedometer Replacement. He's a well respected member here.
    New spark plugs - if you're at or over 115,000 miles (iirc) they are due. Not terribly hard to replace on a Gen 2 Prius.
    Water pump - I'd only replace it if it's leaking. Some people replace it after a certain number of miles just in case.
    Serpentine belt - If it has cracks or even if it's at the age specified in the maintenance schedule, replace it. You do NOT want that to break. You won't know it happened till you get a light on the dash and by then the head will probably be warped. The belt is a $15 part.
    Hybrid battery fan - It doesn't have a filter. The fan itself may need cleaning. Again, not hard to do.
    Inverter coolant pump - Did they say why? That's another thing some people replace just in case. I've never done it and have had two Gen 2s with over 150k miles on them. If you can afford to replace something not broken, it will give you some assurance that the pump won't surprise you some dark, rainy night.
    Steering parts - Well, if they're worn out, they have to go. Of all the stuff they mentioned, this is the only thing that takes anything like special equipment or skills.
    So, if I was strapped for cash, I'd do the belt, clean the battery fan, and get a rebuilt combo meter from Matt right now. Those are things a do-it-yourselfer with access to YouTube can handle at home. Then save for the others or sell it.
    I'm sure others will have other perspectives.
    Data Daedalus, Fern1461 and padroo like this.
  16. padroo
    2,763
    2,252
    Paying a dealer on an old high mileage car for non hybrid work is expensive. I would find a local shop that has done work on Prius especially if just changing parts.
    jerrymildred likes this.
  17. Karl Goh
    Karl Goh Junior Member
    31
    New Zealand
    i-Tech
    Just noticed a mild electric burning scent in cabin of my 2004 base model. Smells similar to what u get when using a battery drill. What should i be looking out for?
  18. Patrick Wong
    18,210
    6,511
    What warning lights if any are on?
    What you should be looking out for:
    1. The inverter coolant pump motor having a short and overheating.
    2. A high voltage traction battery module overheating.
    maleko likes this.
  19. Karl Goh
    31
    New Zealand
    i-Tech
    No lights. The car was parked at the supermarket in the sun during winter and driven within 1 min and i notice the smell that lasted for about 10 seconds.
    Other than my dad noticed it while he was using 1 day, and that time i was at the supermarket, haven't notice the smell since. i use the car 5 days a week mostly short distance and maximum 1hr highway trips
  20. Karl Goh
    31
    New Zealand
    i-Tech
    would it be A/C blower motor about to go?
