Common 2G Problems, and What to Do About Them...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Patrick Wong, Mar 6, 2009.
  1. Patrick Wong
    18,210
    6,517
    No surprise. Perhaps two decades ago, an automobile engine might require replacement at 100K miles or less.
    You really need to check the engine oil level periodically to keep the oil level above the lower dimple on the dipstick. If you allow the oil level to get down to the point where a warning light appears, the engine is being damaged. The difference between the top and bottom dimples is ~1.6 US quarts. If a warning light appears then the dipstick is probably dry which means the oil is at least 2 quarts low.
    There is no problem using synthetic oil but that probably won't reduce your oil consumption if you stay at the same viscosity.
    Please keep the engine oil level above the lower dimple, or else don't be surprised when the engine does fail one day. You can expect oil consumption to accelerate as the odometer reading increases.
  2. ToyotaPrius2005
    ToyotaPrius2005 Junior Member
    36
    San Jose, CA
    Thank you Patrick! I will go check my oil level regularly from now on.
    Would you recommend synthetic oil over regular oil(high mileage oil)?
    thanks
  3. Patrick Wong
    18,210
    6,517
    If you are going to change the oil at 5K mile intervals, then mineral (or regular) oil is fine. It wouldn't hurt to use synthetic oil but it may not help, either.
    I use full synthetic oil and change at 7.5K mile intervals. My 2004's engine with 158K miles is consuming oil at the rate of 1 quart per 5K miles.
    There have been other recent threads regarding engine oil consumption and what other owners have done about it. Some report success in reducing consumption, so you may want to search for those discussions to see if any approach seems applicable to your car's situation.
  4. jadziasman
    jadziasman Prius owner emeritus
    1,355
    488
    District 6
    More like four decades ago, Patrick.
    Early 90s Honda and Toyota engines routinely made it to 200K miles and more without replacement. My '79 Vette (Chevette) 1.6L engine had 170K miles on it and was still running strong. The body rusted out underneath it. :LOL:
  5. Patrick Wong
    18,210
    6,517
    Yes, it also depends upon what kind of car you are talking about. For example, my 1976 VW Dasher was burning oil and producing visible blue smoke at ~90K miles while my 1985 Jaguar XJ6 Vandenplas required the cylinder head to be rebuilt at 70K miles.
  6. Bruce Cameron
    Bruce Cameron Junior Member
    Victoria
    I've just rebuilt my 2005, engine and was utterly amazed at the distinct lack of wear evident. This car was ex government fleet with a less than enviable service history, regularly skipped and out to 25-45,000km between services. I'm astonished it didn't run dry and seize. To my surprise, despite frequent neglect it was like new inside, not requiring big-end shells at 214,000km. I simply replaced the rings because the oil control rings were stuck in the grooves due to excessive carbon, lack of servicing, light cylinder hone and head checked and cleaned. That's it!! These engines are very robust but, BUT, check your oil and change it frequently for best service life. The rings are tiny by any standards, Top-0.8mm, Second, 1.0mm, oil, 1.5mm. Despite small size, low tension and horrible neglect, they were not worn out, simply stuck up with oil residue from old oil, (lack of maintenance). These cars continue to amaze me, having 2, I can say they are by far the best cars I have ever owned.
    blaisep and telmo744 like this.
  7. Tony2009
    Tony2009 New Member
    Winnetka, California
    annoying buzzing noise when i Break or release from breaking. Any clue ?
  8. JC91006
    16,926
    8,637
    That's normal for the prius. Brake accumulator pump
    SM-N900P ?
  9. Ian H
    Ian H New Member
    Murray, Utah
    I ran out of fuel once, driving into a 60+ mph headwind with a kayak on top. Luckily, I also had my bike, so went and got some fuel. After putting some fuel in the tank I just had to wait a minute or so, and the car started right back up with no problems. That was 4 years ago.
  10. satwood
    satwood Member
    107
    16
    Webster, MA, New England, USA
    2014 Prius v wagon
    Hi Patrick,
    I'm surprised about your oil consumption. My 2007 just turned over 200K miles and at my oilchange intervals I still get out about the same as I put in. I don't think it even burns 1/4 quart. In fact, the old oil looks so good I run the old stuff in my lawn mowers and tractors for a while. I've had synthetic in there since the first change off the dealer's lot. Maybe that helped?
    SA
    PriusGuy32 likes this.
  11. JC91006
    16,926
    8,637
    [/QUOTE]
    Hi Patrick,
    SA[/QUOTE]
    I believe living in a colder climate and using a quality synthetic oil helps tremendously with oil burning. That's very impressive you have over 200k and still burn minimal amounts of oil. I'm jealous :)
  12. jqmello
    jqmello Junior Member
    70
    DC
    *raises hand*
    The car alarm kept going off. It's not actually an alarm that can be set off by anything other than the panic button. Dying battery (possibly combined with dampness) caused the old key fob to keep setting it off... had to remove the fob battery to fix the problem. Key is easy to get out, lock works fine, and we've not a non-SKS car so it wasn't weird one inside.
    Another situation where you need to know where the mechanical key is happens when the 12V battery dies. This has happened to me twice now.... well, a bunch of times in a row when the old 12V was on it's way out and I was waiting for the optima yellow top replacement, and once on the replacement - have no idea what got left on. After a day of driving everything was back in spec though.
  13. Jibrail Khan
    Jibrail Khan New Member
    Australia
    nice thread. it will help me . Getting much solution for this thread.
    Thanks for sharing .
  14. jdenenberg
    jdenenberg EE Professor
    3,960
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    When this happened to me it was a stuck alarm button in the FOB.
    JeffD
  15. jqmello
    70
    DC
    Hmm... this happened again with the new battery in. I just replaced the entire fob. However, it should be noted that the car came used without the rubber button covers on the fob, so although the panic button didn't appear to be stuck, the internals may have become dirty/damp/shorted and caused the problem. This was apparently not a battery-related issue.
  16. jqmello
    70
    DC
    Just be aware that some things might be different for your car - 2010 is a Gen III vehicle, and we're talking about common Gen II problems. I'm sure a lot of it carries over, though.
  17. Bobby T
    Bobby T Junior Member
    Chicago
    I have a question. Bought used Gen 2, now has 148k miles. The car icon (with object inside icon) is blinking after powering down. Manual is saying this could be any part of the electrical system. What is the typical point of failure for this mileage? Headed to dealership tomorrow.
  18. Patrick Wong
    18,210
    6,517
    Please take a sharp photo of the light and post. Maybe you are just referring to the security system light which is supposed to blink when the car is IG-OFF and locked.
  19. Bobby T
    Chicago
    Thanks, it is. I just checked on some Google photos. Oops, rookie mistake. Thanks for the reply. I checked the manual as well, and it is the immobilizer system.
  20. Paul Schenck
    Paul Schenck Active Member
    524
    307
    Fresno, California
    I disconnected the muffler at the exhaust manifold, I now sound like a Harley Davidson motorcycle coming in for a landing!
    Pioneerscot and Data Daedalus like this.
