Common failures after 125000 miles?
Discussion in 'Prius c Main Forum' started by swoop_ds, Mar 27, 2019.
  1. swoop_ds
    swoop_ds New Member
    Saskatchewan, Canada
    I have a 2013 Prius C that is right around 135000 miles on it. Up until a couple months ago I haven't had to do any repairs other than routine maintenance and tires.
    All of a sudden, the head gasket was leaking and I fixed that for $2500ish. Then a few weeks later, it wouldn't start. I thought it was the 12V but it turns out a large power cord running underneath the car had been ripped open (likely from gravel road driving apparently) and then moisture got in and rotted it out. It's being repaired and they're telling me it'll be about $3000 to fix.
    Anyways, I was wondering if there are some other things I should expect to fail soon? I know the batteries could go soon, but are their other things that I should be worried about?
    52,351
    welcome!
    i think you've got it covered. are you sure rodents didn't chew the wiring?
  3. Max Taiwan
    Max Taiwan Active Member
    428
    384
    Taipei
    2018 Prius v wagon
    I've not heard much about gaskets and wire going. I too have a 2013 prius C butb my has 41k km. Sounds like a lot of $ to spend on a car just like that out of nowhere. You can't even prevent it kinda.
  4. Mendel Leisk
    41,865
  5. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    It's not a common thing with the cable, but it is exposed, so rough roads could do it.
    As far as the head gasket, you're the first one I can recall with that issue. Are you sure it was leaking, or is that just what your dealership told you?
  6. swoop_ds
    swoop_ds New Member
    I took it into my local (non-toyota) shop to fix an unrelated thing (the heater blower motor) and he told me that it looked like the head gasket was leaking and recommended I take it in to Toyota. So I called and made an appointment with Toyota and they seemed surprised and said that they wanted to look at it. Once I got it in there, they confirmed it was a head gasket and fixed it.
    ztanos likes this.
  7. Mendel Leisk
    41,865
    How long did that take? All warranty?
  8. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    Yeah, I've been posting to this forum for a few years now and as I mentioned, you're the first I recall with a head gasket issue. I'm not surprised they were surprised. :D
    Sorry it happened though. Bad luck and murphy's law and all that.
