Common Problems with the Prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by boostin, Jun 21, 2005.
  1. Mozaffor Sarker
    Mozaffor Sarker New Member
    Australia
    ----Australia----
    Thanks
  2. Mendel Leisk
    42,295
    P0AA6 Code / 526 Information Code--need help! | PriusChat
    ^ This thread involves the same code P0AA6. I just skimmed, but the story as far as I read:
    Car displayed this code.
    Dealership proposed to replace battery
    Battery was replaced
    Problems came back, with code--613 (as well as the standard DTC P0AA6/info code 526)--which indicated a faulty transaxle
    Transaxle was replaced
    No further problems reported. While the owner was happy to have a gratis new battery, that appears to not be the problem, it was in fact the transaxle.
  3. Mozaffor Sarker
    Australia
    ----Australia----
    Thanks
  4. Mendel Leisk
    42,295
    I guess it could be the battery, the transaxle, the computers, hopefully they can eliminate guesswork. Is this all coming out of your pocket?
  5. Duddy03
    Duddy03 Junior Member
    22
    Crossville, TN
    2018 Prius Prime
    From my experience with a 14 year old Prius: Don't loose the FOB. A new FOB and a new (small) small battery cost me $600. The other thing is tire wear if you don't rotate the tires. My thought used to be that seldom rotated tires meant you could "read" the tread and correct alignment issues without ruining all four tires. However, on some tires the back tires develop cupping if not rotated. It could also be caused by structs that need to be replaced after several years. I have a few tips if you do your own maintenance. But basically, the Prius is tops for reliability and I seldom visit the dealer except for recalls. My '18 Prime is my third Toyota and this is the first time that I decided NOT to buy the expanded warranty. Only time will tell . . . Good luck.
  6. DonJuan1943
    DonJuan1943 Member
    64
    53
    Northern Illinois
    One of the downsides of owning the Gen 4 Prius is finding a place to drain off some of the extra gas this excellent mileage provides. People look at me funny when I try to just drain it out along the road.
  7. Ruby2005
    Ruby2005 Junior Member
    17
    Hey, y'all.
    I'm completely new to having a Prius. I've always had a Corolla up until now. Now I have a 2005 Prius with about 51,000 miles on it, but I'm having problems.
    I only drive it about 15 minutes twice a day, about 5 days a week on average since I live close to work. I also live in Florida and play my stereo each time I go out.
    Unfortunately now, I've lately been having the problems of:
    1) The squeaking of some kind of pump that happens when I start it up, or am stopped for more than a couple of minutes.
    **2) THIS ONE REALLY WORRIES ME
    My car has started randomly flashing the Master Warning Light ⚠️ at short intervals. It happens when I slow down and stop, or when I take my foot off the gas and let it glide.
    Tonight when driving home, it:
    -Flashed, no error code
    -Flashed, and the console pit up the oil icon
    -Flashed and the center console screen showed "PROBLEM".
    Does anyone have any idea what I should do, or what's the problem?? I'm super-anxious about this, as I just started working after moving back from overseas and don't have much savings.
    Also, I've been reading about needing to CHARGE your battery or something? What's that entail??
    Thanks, everyone!
  8. dolj
    dolj Senior Member
    8,634
    4,388
    Wellington, New Zealand
    Have you checked the oil level? If not, do NOT drive the car until you do. If you do not see oil between the L and F dimples on the dipstick add at least 1.5 qts of 5W-30 oil and then recheck. For your information, the amount of oil to take the level from the L mark to the F mark is just shy of 1.6 qts.
    jerrymildred likes this.
