Communication module inop
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by crewdog, May 1, 2017.
  1. crewdog
    crewdog Acting Ensign Prius Prime
    492
    388
    Woodstock, GA
    The green light on the SOS switch that indicates Safety Connect is ok went out this weekend.
    Upon activating vehicle to get ready to drive, the light will flash on for 1 second then turn off.
    Pushing the SOS button a voice says "Communication Module not active"
    This being down also terminates updated mpg/ev results on Entune app, as well as any remote vehicle apps.
    Called the 800 number for Toyota Safety Connect to verify my Safety Connect ID is still good.
    Going into dealer Wednesday for 5k service anyway, will have them check.
  2. badasset
    badasset New Member
    17
    Northern Virginia
    I have the same issue (no lights on the SOS button and no more status information to entune). The last update from the car to entune was Apr 28. Scheduled an appt to the dealer to check it out on Wednesday.
  3. jburke313
    jburke313 Member
    48
    North Shore, Massachusetts
    hmmmmm. I will have to check my lights.. I am wondering if this is the same issue as the one I am having, just representing in a different way: Entune stopped connecting to the car | PriusChat
    Seeing badasset comment above that the last update was 4/28, same as mine, is what leads me to this conclusion.
  4. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    From what so far the comments have shown, it looks like an east coast problem, maybe the cell service that entune sos uses is down, here in the midwest it seems to be working ok
  5. crewdog
    492
    388
    Woodstock, GA
    My entune app shows last update on 4/28 as well, and cannot connect to car, don't get emails when charging done, but the rankings show that many others are showing up as generating data for the ev and eco ratings.
    Will see what dealer says tomorrow.
  6. jburke313
    jburke313 Member
    48
    That makes sense. Too bad after 45 minutes with Entune and Toyota they did not have a clue. I was told no reported issues similar to mine.
  7. badasset
    badasset New Member
    17
    Northern Virginia
    Yes jburke313,
    I also get the same error message on the entune app as you when checking the status of the charge or to turn on remote climate (worked up to April 28). If your safety connect light is not on, try pressing the SOS button - I get back a voice message saying "Communication Module not active".
  8. jburke313
    jburke313 Member
    48
    I just checked and have the same issues. Light flashes on for a second and then gone. So this is likely an issue larger than each of us, and perhaps isolated to the east coast based on cellular network or otherwise. What a shame we all have to bring our cars in. Of well, I have been meaning to have them fix my faulty USB port on the console anyway. Thanks, all.
    #8 jburke313, May 2, 2017
  9. Puzzler1
    Puzzler1 Junior Member
    FL
    I also just checked mine and I also get the same issue. Green light on for a second then off and message saying "module not active, call. . . ". My last notification was 12:38 PM April 28th. This is definitely an issue on their side. I don't think all our cars failed at once on the same day. I will be calling them too.
  10. huskers
    huskers Senior Member
    2,543
    2,486
    Nebraska
    When this is resolved let us know what the issue was. April 28th seems to be a bad at.
  11. liskipper
    liskipper Member
    373
    79
    Long Island, NY
    I believe safety connect uses Verizon. Maybe Toyota didn't pay its wireless bill.
  12. badasset
    badasset New Member
    17
    Northern Virginia
    I got my car back from the dealer - no solution to the safety connect issue. My dealer eventually had to contacted the Toyota's TechLine out in CA. The Toyota TechLine group walked the dealer through checking the antenna, the communication module and SOS button - everything looked okay. Next, they had my dealer reset all computers (no changes in the problem) in the car and then run some computer diagnostics. The results were sent back to theToyota TechLine group so they could analyze and research the problem. The Toyota TechLine is to contact the dealer sometime tomorrow to determine the next step (dealer is at a lost since there is no service bulletin on the issue as of yet). Have to just wait and see.
    At least I got the dealer to change the backup beeping to just beep one time :)
    Prius from Dad likes this.
  13. crewdog
    492
    388
    Woodstock, GA
    At least your dealer service felt confident enough to go thru troubleshooting with Toyota Techline.
    When I speak with tech support case mgr I'll mention this.
  14. huskers
    2,543
    2,486
    Nebraska
    Did you share with the dealership that this seems to be happening to many Prime owners on the East Coast and all on April 28th?
  15. badasset
    badasset New Member
    17
    Northern Virginia
    I did share with the dealership about this happening to several other people, starting after April 28, but since there is no service bulletin on the issue, the dealership need to wait for the TechLine to decide what the next step is. They said my car was the first one logged to the Toyota TechLine group on this issue. I guess more people with this issue need to contact their dealer's service desk so it will get logged to the Toyota TechLine group.
    I also have a Toyota Prius Plug-in (2012) with the same safety connect service (with entune mapping, climate, status, emails, etc.), and it does not have any problems, so cell service in my area is working. I just guessing, but it is like several new Primes were recently disconnected/dropped from the cell service provider - I would hope Toyota would be able to check this out.
  16. huskers
    2,543
    2,486
    Nebraska
    It does appear to be a mystery. Least the dealership can do is get you a cage full of carrier pigeons in case you are in an emergency and need to send for help. If that would fit in the hatch area.
  17. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,321
    Central Virginia
    Then you could use this network protocol. RFC 2549 - IP over Avian Carriers with Quality of Service
  18. badasset
    badasset New Member
    17
    Northern Virginia
    Did a little searching and found on a toyotaproblems website and found an entry with a similar problem on the 2014 Highlander.
    Date Reported: May 14, 2014
    NHTSA Reference: #10056054
    TSB Reference: #PSD-TC-019
    Description: TOYOTA: SEE DOCUMENT SEARCH BUTTON FOR OWNER LETTER. DUE TO AN UNPLANNED EXPIRATION OF MOBILE IDENTIFICATION NUMBER/MOBILE DIRECTORY NUMBER, IN SOME VEHICLES, THE SAFETY CONNECT SYSTEM HAS BECOME DISABLED AND NEEDS REPROGRAMMING.
    If it happened once before ...
  19. crewdog
    492
    388
    Woodstock, GA
    Badasset:
    Thanks for that info!
    I've added that to my case number with Toyota, and maybe it will be helpful.
  20. badasset
    badasset New Member
    17
    Northern Virginia
    I found some additional information on the safety connect problem I posted previously with the 2014 Highlander and what was done to resolve it. I provided this information to my dealer's service manager to see if it could assist. They will get back to me later.
    Subject: Limited Service Campaign (LSC) E0K
    Certain 2014 Model Year Avalon, Highlander and Sienna Vehicles.
    This is not a Recall, it is a Warranty Enhancement.
    Background
    The subject vehicles are equipped with Safety Connect, which allows drivers to contact the Toyota 24/7
    response center at the touch of a button. Toyota has identified that the Safety Connect System in the subject vehicles has become disabled due to an unplanned expiration of the Mobile Identification Number/Mobile Directory Number.
    Limited Service Campaign (LSC) Remedy
    Toyota dealers are requested to initialize and verify proper operation of the Safety Connect System by
    reprogramming the Data Communication Module (DCM) with the valid Mobile Identification Number/Mobile Directory Number at NO CHARGE to the vehicle owner. This LSC will remain available until May 31, 2017.
    The following vital information is provided to inform you and your staff of the owner notification timing and your degree of involvement.
    Owner Notification
    The owner notification will commence in late May, 2014, approximately one week after the dealer notification. In addition to owner mailings, Toyota’s Customer Experience Center will contact customers whose vehicles are involved in this LSC.
