Comparison Test: 2012 Honda Civic Hybrid vs. 2011 Toyota Prius Five
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Tideland Prius, Sep 9, 2011.
  1. Tideland Prius
    16,073
    Full Article: Comparison Test: 2012 Honda Civic Hybrid vs. 2011 Toyota Prius Five
    2 people like this.
  2. ydooby
    ydooby Junior Member
    29
    32
    CA, USA
    Good win, but I wonder how the Prius ended up with less than 40mpg overall.. Did they average the figure from their performance test or what?
  3. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    they stated something about a very empty highway.... that means high speeds... a prius only get 25mpg or so while doing 100 in an open desert... or so i've heard ;)
  4. Tideland Prius
    16,073
    Not sure. I know CR got 44mpg overall with the Gen 2 so I was surprised the 3rd gen got a lower number (yes I know, it's a different group of testers). Still, it's a surprisingly win. I honestly thought they were gonna say the Civic was better because it handled better despite lower mpg. First time they've actually acknowledge the both cars for its purpose/mission. Toyota has done well with the 3rd generation.
  5. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    I was about to post this article until I realized Tideland had already done and I'd thanked him before it. Whoops.
    Yeah, I'm puzzled. The Edmunds people must be really terrible drivers for mileage (and with a way out of alignment car w/underinflated tires?) given that
    Yeah... I was thinking too that they must've been driving 85+ mph. For the rest, who knows what they were up to? Very short city drives and driving it wrong for mileage (e.g. misusing EV button and babying the throttle all the time to stay in EV)?
  6. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    they lost me at 38MPG, meh
  7. Trollbait
    11,329
    or tire pressure simply low.
  8. Skoorbmax
    Skoorbmax Senior Member
    2,641
    264
    Western NY
    Honda's hybrid technology is second-rate. No matter how they dress up that pig it will remain so until they drop this hybrid assist nonsense and integrate properly.
  9. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    How could you get a 2011 Prius to do under 40 MPG?
    Load it to the max, drive it with high cabin heat, lower tire pressures under 30 PSI, drive it like you stole it?
  10. PriusSport
    PriusSport senior member
    1,498
    88
    SE PA
    We have an Insight and a Prius 2. The electrics are different (series vs parallel), but the result the consumer sees isn't that much different. Gas mileage: Insight 42 mpg, Prius 47 mpg. Both cars similarly quiet (Prius slightly quieter). Both same CVT transmission. The Green eco readouts on the Insight are a bit more advanced, but it's a later model, 2010. The Prius is higher inside(more spacious feel), slightly smoother ride. The Insight handles better and has more pickup.
    The biggest difference? the price. Insight was about $18.5K in 2010; Prius $23.5K in '08.
    The Insight is a better value at that price, though I prefer the Prius.
  11. V8Cobrakid
    3,790
    152
    I tend to only get below 40mpg when I'm towing my 6x8 trailer. Sometimes I get up to 48mpg while towing though.... I'm sticking with high speed runs and jackrabbit starts as the cause... basically never coasting or cruising below 70mph (then again, my bro gets 50's in his 05 with 200k while at 70mph). Maybe Cwerdna is right about 85+
  12. Mendel Leisk
    38,255
    Actually, I like Honda's approach: they don't push too hard on any one facet of achieving better mileage, it's a a lot of smaller nudges. At least with the second gen, gas engine displacement was a paltry 1.3 liter. That, coupled with off-the-mark heavy lifting being liberally assisted is the cornerstone of their mpg effort.
    Then they added autostop, sequential dual sparkplugs per cylinder, and dual lift valves (mild for the most part, agressive only under heavy acceleration needs). The underside has aeropanels, there's aluminum suspension components.
    Where they tripped is expecting too much from the diminutive Integrated Motor Assist battery. Where they did a face plant is their corporate reaction when the IMAs (and to a lesser extent the Continuously Variable Transmissions) started packing it in.
    Anyway, I notice after the article, the first comment says in part:
    Toyota perpuates the delusionalism with their in-dash mpg fudging.
  13. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    Yeah... at CR, they got 55 mpg on their highway portion of the test at Most fuel-efficient cars on the 3rd gen.
    http://www.consumersunion.org/Oct_CR_Fuel_Economy.pdf says
    On the 2nd gen, they got 50 mpg on the highway portion per Most fuel-efficient cars.
