Comparison with Hyundai ioniq?
Discussion in 'Gen 4 Prius Main Forum' started by SkepticBuyer, Jan 17, 2016.
Tags:
  1. Bluecar1
    Bluecar1 Active Member
    204
    272
    Kent, UK
    at 60-70mph on the flat my Ioniq can make 2-3 miles on EV power only, then takes 3-4 miles to recharge then flips back into EV again and the cycle repeats on highway / motorway depend on gradient of the roads
  2. GasperG
    GasperG Senior Member
    1,169
    601
    Slovenia
    2018 Prius
    And this is normal operation? On cruise control?
    IMO that is not healthy for the battery, at that speed on the flat it drains 10-15 kW of power, that is 10C drain for 40% of time and charge for the other percent of time.
    OK, if by "flat" you mean just a little downgrade, then Prius operates similar and battery is not so aggressively drained.
  3. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    50 mpg US = 62.5 mpg UK in a Prius
    60 mpg UK = 48 mpg US.
    RCO likes this.
  4. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    No, it would be fine for the battery - HYUNDAI will have already built in a significant buffer, just like TOYOTA did. I wouldn't worry about it - that's the way a hybrid achieves great fuel savings.
    Bluecar1 and RCO like this.
  5. Bluecar1
    204
    272
    Kent, UK
    also different battery tech, Ioniq = LiPo while majority of Prius are NiMh
  6. bisco
    52,803
    prius are all li-on now, except pkg 2.
    edit: in the u.s.
    RCO likes this.
  7. alanclarkeau
    7,045
    7,593
    And Japan only has Li-ION - most of the rest of the world has NiMH except USA which has got it on most packages now.
    kithmo likes this.
  8. Bluecar1
    204
    272
    Kent, UK
    yep, no LiPo in UK on any Prius
  9. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Li Po, as in liposuction? (n)
    If you meant lithium ion, my Prius certainly has it! And while many a Cornishman believes Cornwall is not part of the UK, IMHO it still is.:ROFLMAO:
  10. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    I think you'll find it's NiMh, no Li-ion batteries on UK spec Gen 4 models, only on the Prius+.
    RCO likes this.
  11. alanclarkeau
    7,045
    7,593
    And, as far as I can ascertain, PRIUS uses Li-ION, not LiPo (though mine is NiMH).
    RCO likes this.
  12. bisco
    52,803
    mine are LIFO last in, first out.
    RCO likes this.
  13. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    My brain hurts me! :sick: I was sure UK Prii all had Li Ion having ditched the Ni M H.
  14. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    You've not been wearing your tin foil hat enough in the Prius have you :rolleyes:
    alanclarkeau, RCO and bisco like this.
  15. Bluecar1
    204
    272
    Kent, UK
    just checked, still lists NiMh in brouchure
    RCO likes this.
  16. snipercoder
    snipercoder Member
    76
    40
    CA
    Three Touring
    Looks like the 12v battery portion is underneath the Ioniq next to the gas tank. It's separate from HV battery but it is Lithium, saving about 26 lbs. Conversely, the EV version of the Ioniq has the traditional 12v battery.
    Battery flat - Page 5 - Hyundai Ioniq Forum
  17. bisco
    52,803
    that was very confusing. hyundai quote: 'the 12v battery, which is modularized within the larger package, can be serviced'. i'm still going with a dedicated part of the hybrid battery until there are specs available.
    funny that jan treur and bluecar1 don't know, but that was a month ago.
    also, i don't believe the prius battery weighs 26 pounds more than whatever hyundai is using. lion batteries are not that light. but again, we don't know what the 12v battery really is.
    #97 bisco, Mar 23, 2017
    RCO likes this.
  18. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    I believe the 12V battery is physically integrated with the overall HV pack but can be modularly removed and replaced and is located under the rear seat. However, I did not look closely to see exactly where it is located. The 12V portion is electrically separate and probably uses a different cell design although I'm not certain of that either.
  19. bisco
    52,803
    potential nightmare. do you think they really knocked 26 pounds off the prius battery?
  20. snipercoder
    snipercoder Member
    76
    40
    CA
    Three Touring
    What's more confusing is that this is only available in North America. The rest of the world gets a traditional 12v battery in the trunk. That box underneath the Ioniq is still a mystery unless someone look inside it.
