Compatible bike rack for 2017 Prius Prime?
Discussion in 'Prime Accessories and Modifications' started by EK2017, Aug 25, 2019.
  1. EK2017
    EK2017 Junior Member
    Tarrytown, NY
    I'm looking for a bike rack for my 2017 Prius Prime. From what I've read on this site, it seems the most popular option that owners have pursued is to install a hitch. It also appears from the posts that Toyota does not recommend putting a hitch on the Prime, and may even void some portion of the warranty on the car if you do (This second part is unclear to me.)
    So has anyone successfully put a hatchback-type bike rack on the 2017 Prius Prime? If so, what's the brand and model of the rack?
    For those who have attached a bike rack to the Toyota roof rack, what brand and model did you install? How many bikes does it carry?
    Thanks for your advice!
  2. eroeder
    eroeder Junior Member
    72
    22
    Dallas
    2018 Prius Prime
    Hmmm. I simply got Curt class I tow hitch and use a Hollywood Bike rack. Works great with no worry of scratching car or denting.
  3. avongil
    avongil Member
    67
    56
    Easton, PA
    I have a 1.25" hitch on my gen 3. When we put a hitch on my wife's prime, it will certainly be a 2" you have way more options for bike racks with a 2" hitch.
    I would go for this next time, but I am sure others will chime in with what 2" hitch works best.
    Torklift Central | Select Your EcoHitch Style
  4. avongil
    avongil Member
    67
    56
    Easton, PA
    1.25" hitch will net you 2 bikes in the back of the car.
    2" hitch will get you 3+
    I have a Yakima rack for the roof that could do 2+ bikes.
    On a gen3 I think it is safest to do 2 on top and two on the back. Handling suffers a bit with 2 bikes out there.
    I used this bike rack.
    Transfer - Kuat Racks
    It works very well. Do not love that there is so much plastic on it. Every bolt needs blue lock tight.
    It gets really expensive to haul more than 2 bikes, how many bikes are you looking to transport?
  5. avongil
    avongil Member
    67
    56
    Easton, PA
    BTW in the unlikely event you need warantee work, there are just 4 bolts to loosen. What hitch are you talking about?
  6. noonm
    noonm Senior Member
    575
    595
    2018 Prius Prime
    It may only be 4 bolts, but it looks like several hours of dissembling/reassembling your rear bumper:
  7. avongil
    avongil Member
    67
    56
    Easton, PA
    It took 15 min to mount my regular under the bumper curt hitch on. You just lay under the car and bolt on...
    Not as nice as that 2" but it does the job.
    That 2" hitch does have the two hidden mounting options.
  8. noonm
    noonm Senior Member
    575
    595
    2018 Prius Prime
    That may have been the case for the gen3/original plugin prius, but it looks like the gen4/primes require significantly more work for installation/removal of the hitch.
    Here's a curt hitch install:
    Here's a draw-tite hitch install:
    They all seem to attach by being wedged between the bumper bar and frame, which means removing the bumper bar and all of the associated coverings (e.g. fascia, underbody panels, etc). Also, it appears to require some cutting of the fascia/panels so it would probably be pretty obvious to the dealer that a hitch was installed even if you removed it before any warranty work.
  9. avongil
    avongil Member
    67
    56
    Easton, PA
    Oh dang... 4th gen just didn't compute in my brain.
    They ll look like a pain in the rear. Going to have to put aside 2-4 hours. That is really going to suck when my wife wants one.
    I would certainly go for the 2" hitch. Get it done once and never look back!
  10. avongil
    avongil Member
    67
    56
    Easton, PA
    Interesting rabbit hole I just went down...
    The manual says it does not recommend towing. It says it does not recommend the installation of a tow hitch for any purpose.
    It does not say anywhere in the warantee or owners manual that it will void anything. The maintenance manual even has maintenance intervals for those that tow with it. The footnote says some vehicles are not designed to tow. Looks like a bunch of BS to me and they are trying to CYA in every way possible.
    Seems like its not legal in the US to reject coverage because of something like this but if they want to give you a hard time it will be you against them in court. I cannot imagine this happening, but anything is possible.
  11. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    You won’t void your warranty putting a hitch in to haul bikes.
    noonm likes this.
  12. m8547
    m8547 Senior Member
    951
    630
    Colorado
    2018 Prius Prime
    A hitch is the way to go. On another car I pulled the trunk latch out of alignment with 3 bikes on a trunk mounted rack. I'm sure the carbon hatch was not designed to carry a lot of weight, although it feels pretty sturdy. And a roof rack would add so much drag, plus the bikes get bugs on them, and they get in the way of driving into parking garages.
    jb in NE likes this.
  13. VTBIGDOG
    VTBIGDOG Active Member
    211
    146
  14. sdcruiser
    sdcruiser Junior Member
    31
    Do you have a picture? My bike rack is a Transite and very similar to the Hollywood. But I think the Hollywood has a very straight connecting section that will hit my bumper. How far is the Curtis pin hole from the end of the bumper? Just bought the Prime and need to get a hitch very soon for my mtn bike. Thanks
